Author Topic: will 1982 cb650 carbs work on the 82 nighthawk? (650sc)  (Read 796 times)
Offline liersemann
« on: February 26, 2017, 02:53:28 PM »
Hi everyone,
I'm needing to buy a new carb set for my 1982 Nighthawk 650sc.  I found a set on ebay, but they were taken from an 82 cb650 so not the nighthawk.  My nighthawk has removable slow jets where I believe the regular cb650 has them pressed. The seller is stating that the carb set will work on either bike- is this true or will I be running into problems?
Thanks!
Offline cb650
Re: will 1982 cb650 carbs work on the 82 nighthawk? (650sc)
« Reply #1 on: February 27, 2017, 02:15:11 AM »
If they are 82's the will be screw in.     81 was press in
Offline liersemann
« Reply #2 on: March 01, 2017, 06:45:59 PM »
Thanks cb650. So since they're both screw in- the carbs on the 82 650 and 650sc (nighthawk) are interchangeable?
Offline cb650
« Reply #3 on: March 02, 2017, 02:57:43 AM »
yes    81 will work to but has a press in idle jet.
Offline liersemann
« Reply #4 on: March 03, 2017, 09:16:34 AM »
That's good to know as there seems to be a lot of 81 carb sets out there, but the 82's seem to be pretty hard to find. And more expensive!
Thanks cb650
