Author Topic: front end wobble  (Read 3071 times)
Offline Jimsun
Re: front end wobble
« Reply #25 on: March 21, 2017, 06:09:19 PM »
Updating this thread.
The issue was that the valve didn't seat properly and it was pinching the tube. My friend also noticed back then that my valve stem wasn't seated perpendicular to the rim - like a 90 degree angle.
Anyways, I rode the bike today since the weather and I'm happy to say that it's buttery smooth again. No wobbles what so ever.
I hope this thread helps someone in the future
74 cb550
Offline Deltarider
« Reply #26 on: March 22, 2017, 03:22:28 AM »
Thanks for reporting back to us. We now know what to check extra whenever a tired is changed.
CB500K2-ED Excel black
Offline markreimer
« Reply #27 on: March 23, 2017, 08:50:20 AM »
Glad you got it sorted out. I'll just add for anyone searching this in the future, I had the same issue with Avon Roadrider's on my '74 CB350F. There was a bump that I initially thought was an out of balance tire. No amount of weights or beads would fix it. Finally I noticed a spot that was just ever so slightly not seated properly. It looked like the tire wasn't being pushed up onto the bead shelf, or whatever you call it. I couldn't get it to sit until I removed the tire completely, polished the rim to a shine (there was some VERY minor pitting right in the spot in question, amazing how little will cause you problems), used tire lube and inflated it back up. Pop! The tire slide right into place and the pulsing was completely gone. Smooth as butter now.
