Author Topic: Crane Camshaft for cb750 - anyone ever run one?  (Read 6673 times)
Re: Crane Camshaft for cb750 - anyone ever run one?
« Reply #25 on: March 04, 2017, 11:04:18 AM »
Note the recommended 5000 rpm minimum on the fat 400 unit ;)
No sh!t......the valves never close. I wouldn't recommend that thing for the street (unless you start off with a ton of static compression).
min 5000 rpm, must be idle! ??? Or when engine runs stable
for the strip, must be impossible to ride that cam on the streets.
Offline BPellerine
« Reply #26 on: March 04, 2017, 02:35:11 PM »
salt flats maybe?bill
1978 CB 750K ard and webers
another anfob
Offline dragracer
  • CB750F Dragbike
« Reply #27 on: March 05, 2017, 11:20:34 AM »
Definitely a  cam for high rpm use only. The valve springs would need to be replaced quite often because they'd get beat to hell during every run.
« Reply #28 on: March 06, 2017, 11:03:13 AM »
Win the race, it cost a few engines that sponsors gladly can provide when their visible names sells products. I understand that formula.
It would be nice with a chart where different cams are runned in same engine on dyno.
Different displacements and CR too.
To visualise the extra hp and torque the added amount of pain on engine and wallet will give except for less durability.
Offline corky
« Reply #29 on: November 15, 2019, 08:54:33 AM »
Hey BPellerine,
i actually found the cam card for that crane cam you have.  Here it is.  Sorry for the late reply.
Thanks,
Daniel
Offline BPellerine
« Reply #30 on: November 15, 2019, 09:26:41 AM »
thanks ,I never did know the specs on it,found in a stock motor,where the valves were just kissing the pistons.bill
another anfob
« Reply #31 on: November 16, 2019, 08:25:54 AM »
They made a lot of different cams for the CB750.
A very popular bike!
Offline Tracksnblades1
« Reply #32 on: November 16, 2019, 10:16:51 PM »
Did you get to hear it run...?    🙏
Age Quod Agis
Offline BPellerine
« Reply #33 on: November 17, 2019, 06:46:42 AM »
no never heard it run,motor was apart.bill
another anfob
« Reply #34 on: November 17, 2019, 03:48:59 PM »
That's to bad....
Once tore down a 350sbc, everything wrong by the accepted rule...
Big Crane .670 intake .625 exhaust...286@ .050 lift,  roller...1.5:1 crane roll rocks with double bar girdle
Stock cast iron Qjet intake with adapter to square 850 Holley DP...
Stock 8.5 cast pistons........
Stock 1.74 intake 1.50 exhaust 78cc cast iron heads bowl ported below valves w/ screw in studs and big 1.437 or 1.500 valve springs....
Unmatched header adaptors to Schoenfield 1 3/4 headers.....
Variable pitch stock th400 converter with manual body th400...
Ran like a screaming chicken....idled very decent @ 900....power brakes worked at stop sign...
Smoke the 3.73 posi street 60's anywhere anytime....
Still have the Crane Cam #...and still offered......
Do you want to sell it....?
« Last Edit: November 17, 2019, 08:06:28 PM by Tracksnblades1 »
Age Quod Agis
Offline BPellerine
« Reply #35 on: November 18, 2019, 01:39:38 PM »
don"t think I would sell it to anyone,looks to be some wear,might be ok might not be.bill
another anfob
