Author Topic: 1969 CB750K - 11,999 miles - The Patina Bike - SHE RUNS!!!  (Read 27853 times)
Offline murman1983
Re: 1969 CB750K - 11,999 miles - The Patina Bike
« Reply #175 on: June 01, 2018, 06:23:39 PM »
Awesome bike your building there, even cooler in person.
Offline Johnie
« Reply #176 on: June 09, 2018, 12:08:13 PM »
Got a little behind on this project. Had to replace the intakes and float bowl gaskets on my blue / green KO which was a 2013 project. As long as the carbs were off I cleaned them again. Out came the Morgan carbtune to dial it in. Now back to this current 69KO - got the vents, fuel line and air box back on. Next comes connecting my auxiliary tank and firing this up.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #177 on: June 15, 2018, 03:05:41 PM »
Will be great to see/hear it run!
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline luvmy71
« Reply #178 on: July 12, 2018, 09:08:21 AM »
When you sell this bike keep in mind a 1969 CB750 just sold on eBay for $148,000, yes you read that right $148,000.  Advertised as one of 4 pre-production bikes sent over from Japan.
https://www.motorcycleclassics.com/black-side-down/honda-cb750-sells-for-148100
CB750 K1
'74 CB550 Cafe Project
Offline Johnie
« Reply #179 on: August 16, 2018, 07:22:22 AM »
Secured my WI title yesterday. Now to get the bike on the road. It’s been to blasted hot here and you know how busy summers are. Been riding a lot as time permits.
Oshkosh, WI  USA
« Reply #180 on: August 30, 2018, 05:09:28 PM »
Good to hear.
Blasted hot up there this summer?   I wish I had your heat.  There have been 40 days this year here that it's gone to 100 degrees.
Offline Johnie
« Reply #181 on: September 01, 2018, 12:33:08 PM »
Monumental day today...installed the battery & auxiliary tank for the first test run since the bike was last licensed in 1979. Started up amazingly fast. Got out the Morgan and did the carb sync and she idles smooth. Still need to clean the blue/green wrinkle tank, but used my spare for the test ride. She runs and shifts smooth through the gears. Never a miss or hesitation from 0 to a smooth run at 70. The speedo read 11,999 and I had the privilege to take this beauty over the 12,000 mile mark. With those few miles she should run the way I expected it would...HONDA smooth. I have videos of the start up, but never have luck posting those here. Today was a GOOD DAY!
« Last Edit: September 03, 2018, 09:15:00 AM by Johnie »
Oshkosh, WI  USA
Offline Old Scrambler
Re: 1969 CB750K - 11,999 miles - The Patina Bike - SHE RUNS!!!
« Reply #182 on: September 03, 2018, 06:01:36 PM »
Good on you ;) ;) ;)   Hint........FWIW...I've had good luck storing bikes for a year on 110 race-gas...........near empty fill to half-tank and ride a few miles to get mix in carbs............starts right up after 12 months.
Packing to get back on the road in 2 weeks...........
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Johnie
« Reply #183 on: September 03, 2018, 07:07:44 PM »
Thanks Dennis...appreciate the tip.
« Last Edit: September 03, 2018, 08:18:38 PM by Johnie »
Oshkosh, WI  USA
« Reply #184 on: September 04, 2018, 02:50:43 PM »
Congrats!
Offline Tews19
  • I am no
« Reply #185 on: September 04, 2018, 07:04:50 PM »
Johnie, I'm trying to order a Morgan Carbtune however the site keeps blocking my purchase. Did you have to email them to have it shipped here?
1970 Honda CB750 survivor.
Offline Johnie
« Reply #186 on: September 05, 2018, 06:53:55 AM »
No, I went through the normal ordering, but I got mine 10 years ago. Maybe some others will chime in on if the site works for them.
Oshkosh, WI  USA
Offline Johnie
« Reply #187 on: September 16, 2018, 10:00:57 AM »
Cleaning this wrinkle tank with Metal Rescue today.
Oshkosh, WI  USA
Offline Johnie
« Reply #188 on: September 17, 2018, 06:59:11 AM »
Tank cleaned up well. New petcock installed and now for some ride time.
Oshkosh, WI  USA
Offline Tews19
  • I am no
« Reply #189 on: September 17, 2018, 07:03:53 AM »
Teaser post! We need pics Johnie!!
Offline Johnie
« Reply #190 on: September 17, 2018, 07:05:36 AM »
Been trying...keeps saying they are to large. Can't understand it. The last one of the wrinkle tank worked? Will keep trying.
Oshkosh, WI  USA
« Reply #191 on: September 17, 2018, 07:57:04 AM »
Hey Johnie...is there a small hole in the top of the tank near the latch?  If yes, what was done?
Offline Johnie
« Reply #192 on: September 17, 2018, 08:17:29 AM »
No hole Stev-o...it's an optical conclusion :)  It is the bracket that holds the thumb latch. No leaks. In fact, I could hear the vent trying to breath once I got the gas inside. I had to clear the cap vent and install the new gas cap seal.
Oshkosh, WI  USA
Offline JamesH
« Reply #193 on: September 17, 2018, 10:13:03 AM »
Pics pics pics..:-)...great work..
Offline Johnie
« Reply #194 on: September 17, 2018, 11:26:59 AM »
I'm tryin' tryin' tryin'...in the mean time I will email you some James.
Oshkosh, WI  USA
Offline Johnie
« Reply #195 on: September 17, 2018, 12:47:18 PM »
Spoke to moderator Glenn and he changed a setting. Thanks Glenn!!!
« Last Edit: September 17, 2018, 12:51:20 PM by Johnie »
Oshkosh, WI  USA
« Reply #196 on: September 17, 2018, 02:31:07 PM »
That's a nice stable of ponies.
Offline tanner709
« Reply #197 on: September 17, 2018, 07:27:33 PM »
Great looking bike. Excuse the ignorance, but what is the reservoir under the right cover - oil/gearbox cooler?
Offline jus4selling
« Reply #198 on: September 17, 2018, 11:08:30 PM »
750s are dry sump motors, that's the oil tank
Offline tanner709
« Reply #199 on: September 18, 2018, 12:59:42 AM »
Interesting.
so supply and return is all done through ports?
