Author Topic: what oil to use.  (Read 15151 times)
Offline katman
what oil to use.
« on: March 04, 2017, 11:07:26 AM »
I know the manual says to use 10w40 in my 75 cb750. Am I right in seeing somewhere here on the forum that 20w50
is better
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=ddm8vj4tam87cfhgfjns6h9u50&/topic,60973.0.html
Re: what oil to use.
« Reply #1 on: March 04, 2017, 11:22:01 AM »
think that 10/40 is a bit thin..and make the engine rattel..some more then using thikker oil..but thek the handbook..in the running  tempreture make the oil thange over the range..10/40 is only a universel idea..
i hate all this v-w.... vords
Online PeWe
« Reply #2 on: March 04, 2017, 11:32:36 AM »
10W-40 Ok if pistons or rings are new. Oil for motorcycle and wet clutch. Car motor oil will probably cause clutch slip due to the antifriction stuff in it.
Oils have been up before, just search. Maybe you'll find Spectro motorcycle oil or Red line motorcycle oil. 20W-50 is the common choice.
10W-40 if using the bike when weather is colder. This has been up in the forum. Maybe 5-15*C
« Last Edit: March 05, 2017, 02:33:29 AM by PeWe »
Offline drumstyx
« Reply #3 on: March 04, 2017, 11:38:56 AM »
There's a can of worms.
I ran 20w50 motorcycle oil for the first 15 minutes on the rebuilt engine, now I'm running rotella t5. I think maybe it's 15w40.
Offline strynboen
« Reply #4 on: March 04, 2017, 11:41:11 AM »
i had used 15/40 agri oil for diesel engines..its better for summer use..but better use a vet clutch oil..just to be safe.(.i dont)
Offline drumstyx
« Reply #5 on: March 04, 2017, 12:31:37 PM »
It's a diesel oil, but word is it's great for old motorcycles because of its zinc content, and for some reason doesn't have friction modifiers like gas engine oil does (presumably because diesel is an oil itself)
« Reply #6 on: March 04, 2017, 12:40:17 PM »
That is a good question, what is the best oil to use?!
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #7 on: March 04, 2017, 01:01:38 PM »
I thought there was a rule against this question  ;D
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #8 on: March 04, 2017, 02:10:11 PM »
15/40 if running a stock air intake, 20/50 for pods.
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline eigenvector
« Reply #9 on: March 04, 2017, 02:50:06 PM »
Cod liver oil.  Keeps your heart healthy.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
« Reply #10 on: March 04, 2017, 03:47:06 PM »
Getting popcorn  ;D
« Reply #11 on: March 04, 2017, 05:38:43 PM »
Can i get a vote for virgin baby seal oil?
Offline 78whiteorbs
« Reply #12 on: March 04, 2017, 05:46:37 PM »
Only run strictly Organic Non-GMO Gluten Free Beard oil at sea level or below. Hard to come by around here so I buy it by the 50 gallon drum!
Offline edwardmorris
  • Youngish
« Reply #13 on: March 04, 2017, 07:45:17 PM »
is better
http://forums.sohc4.net/index.php/topic,119643.msg1700716.html#msg1700716
  • Youngish
« Reply #14 on: March 04, 2017, 07:46:05 PM »
My fav response to this age old queston:
It has been over 5 years since we discussed which engine oil is preferred.
No it hasn't...
Which oil do you use/recommend in my situation?
100% Pure Extra Virgin Olive Oil...
Where do you buy your oil?
At an olive farm that sells virginal olives...
Thanks!
Don't mention it! ;)
Offline Dunk
« Reply #15 on: March 04, 2017, 08:14:27 PM »
Well it's still winter, someone had to stir the pot...
« Reply #16 on: March 04, 2017, 09:40:53 PM »
 Yeah, lets get to some serious less arguable questions, like what tires to use?
Offline scunny
  • don't call me expert
« Reply #17 on: March 04, 2017, 09:53:58 PM »
I have been searching for ages on this site, oops sorry, wrong thread.
15/40 for our winter in NZed, 20/50 for summer time running.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline DaveBarbier
« Reply #18 on: March 04, 2017, 10:44:39 PM »
This post from back in '05 is interesting. Saying that the oil temp/weight table is a printing error.
http://forums.sohc4.net/index.php?topic=5930.0
If it is an error, and it looks like it is, it's saying anything close to or above 60°f should be using 20w 50.
I'm going to sleep now. Hopefully this thread doesn't self destruct by the time I wake up.
Offline strynboen
« Reply #19 on: March 05, 2017, 02:00:26 AM »
hnmmm..... oil to use on a stering damper.. 8)
Offline Deltarider
« Reply #20 on: March 05, 2017, 07:16:24 AM »
Can I cool the debate a bit down by introducing the oil cooler?  ;D
Now in seriousness. I remember having read that back then Honda tested several oils to determine which oil reached the cam first. That's essential because that's where wear takes place at every cold start and the cams actually suffer most at idle. Automotive engineers usually say that every cold start effects in more wear than 200 kms of riding.
CB500K2-ED Excel black
Offline strynboen
« Reply #21 on: March 05, 2017, 08:42:02 AM »
..all oil drain aut and back in the sump. on the simpel Honda filter..,
,,so a good idea to build automobile types filters on..they have a  return oil valve..so the oil dont running back aut of the filter.
.so no priming of the vhole filter housing is needet..its just go to pressure at almost first kick..
Offline Airborne 82nd
« Reply #22 on: March 05, 2017, 01:19:50 PM »
Offline jonda500
« Reply #23 on: March 05, 2017, 04:31:06 PM »
+1 During my automotive apprenticeship I was told that over an engines lifetime, 80% of the engine's wear happens when it's cold...
John
Taxis are almost never run cold and have been known to clock up over 1000000 k's between rebuilds!
A starter clutch thread:
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #24 on: March 05, 2017, 05:49:26 PM »
because of my ignorance i used car motor oil in my "new to me cb750 k6".  if i switch over to motorcycle oil will it improve clutch response?  i'm not necessarily saying my clutch feels bad but i'm sure being a 40 year old bike that sat for over two years with the PO it would be wise to check the clutch for proper adjustment and use the correct oil.
cb750 k6 - ugly
