Author Topic: Anybody running a CB550 with 16t front 37t rear sprockets?  (Read 4469 times)
Offline Klark Kent
« on: December 10, 2006, 10:46:20 AM »
I dont want to start another what does gear ratio do thread, but after reading this article from the sprocket FAQ i wanted some testimonial type feedback on lowering the front sprocket one tooth on a cb550.  is the increase in chain velocity at the front sprocket something to worry about? what will my rpms be at 75mph?  any sprocket advice for this particular bike will be appreciated but i am particularly interested in lowering the front by one or raising the rear by a few.
thanks
-KK
-KK
75 CB550k
95 KLR650
www.blindpilotmovie.com
download the shop manual:
you'll feel better.
listen to your spark plugs:
Offline scondon
  • Mmmm......tasty bugs
Re: Anybody running a CB550 with 16t front 37t rear sprockets?
« Reply #1 on: December 10, 2006, 11:26:44 AM »
Sorry, no testimonial. Z1 Enterprises has a page that shows how to calculate rpm's before changing sprockets:
http://www.z1enterprises.com/reference/chainsprockets.aspx
Offline puppytrax
« Reply #2 on: December 10, 2006, 02:28:07 PM »
I think I see what you're trying to do...
HondaMan in his Thoughts advises to go 4 teeth up on the rear sprocket or one less on the front sprocket, but I have yet to find a supplier of 41 tooth steel rear sprockets...
...and a 16 tooth front sprocket forces the sprocket to turn a tighter diameter circle (increased wear), plus drag on the swingarm during bumps...not good...   :-\
I'd be interested in knowing if anyone has a distributor of 41 tooth steel rear sprockets for the 500/550...JT doesn't...PartsUnlimited doesn't...SunStar doesn't...
Who's left??   ;D
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
caferacer550
« Reply #3 on: December 10, 2006, 10:25:06 PM »
I'm running a 41t on the rear of my 78 550k.
17t on the front.
Quick around town, but screams on the highway.
I find the gearing too high for general use.
I got it from Sprocket Specialties.
I think they are listed in the FAQ section.
Will probably go for a 39t in the future.
Or look for the mythical 6th gear modification.
Has anyone heard of this? A 6th gear for a 550?
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #4 on: December 10, 2006, 11:12:35 PM »
not sure, but i came to my shop yesterday and brad (southbound) had left this on my workbench. do you think it will make my bike go faster?
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline puppytrax
« Reply #5 on: December 11, 2006, 03:48:18 AM »
Sprocket Specialists http://www.sprocketspecialists.com/ only list a 34 tooth for either 500 or 550 in steel; don't try sprocketspecialties.com as it is a "placeholder" URL; and the link in the FAQ is dead (but the base sprocketspecialists.com is good)...   ;)
« Last Edit: December 11, 2006, 02:47:58 PM by puppytrax »
Offline paulages
  • 1976 cb735
« Reply #6 on: December 11, 2006, 09:55:08 AM »
i was able to get a 37 tooth from them. they have almost every possible combination of front and rear, actually, but the price jumps to about $65 once you leave stock (or the common 34 T). i wanted a 40, but at the time was running low on funds.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline cafe75-550
« Reply #7 on: December 12, 2006, 04:20:07 PM »
I'm running a 39 tooth rear on my CB550, ordered it from Z1. I'm running a 650 rear hub though. It's great for around town, but it definitely makes the freeway a little more interesting...I wouldn't want to go any bigger for general purpose riding unless I knew it would never see the freeway...
New bike!
'07 Triumph Speed Triple 1050
Never enough projects!
'75 CB550 "Cafe", '76 CB550 parts bike
'64 Norton Atlas featherbed/'71 Triumph 750 Triple (Triton project)
'68 BSA Thunderbolt (frame and cases, project in the wings)
'57 Triumph Thunderbird (frame and mostly complete engine)
Offline paulages
  • 1976 cb735
« Reply #8 on: December 12, 2006, 05:29:23 PM »
bryan--
do you that brad's homemade 16 T in the picture will work?  ;D
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline cafe75-550
« Reply #9 on: December 15, 2006, 09:48:49 PM »
bryan--
That sucker should add at least 10 horses at the wheel!!  ;)
New bike!
Offline paulages
  • 1976 cb735
« Reply #10 on: December 16, 2006, 12:31:56 AM »
i put it on my bike, and i'm hearing a strange noise coming from my engine. and it seems like it losing power. i'm so confused...shoudn't this be adding pep? and i've gone through 3 chains.  ??? ??? ??? ;D i think i might ask brad for my money back...
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Kevin400F
« Reply #11 on: December 16, 2006, 06:01:00 AM »
Paul, you should probably go back to a 17T front.  Here's a special "lightened" version:
Offline puppytrax
« Reply #12 on: December 16, 2006, 07:54:17 AM »
This one from the link above has to be the best..."Yes, I'd like a new one, please...same number of teeth"...   ;D
Offline paulages
  • 1976 cb735
« Reply #13 on: December 16, 2006, 10:40:20 AM »
who's holding that chain?!?? and why is he doing it in his underwear?  :D :D :D
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Klark Kent
« Reply #14 on: December 16, 2006, 10:42:04 AM »
This is one of those photos they use to route homosexuals out of the military.  if you see bike parts you pass, and its off to the front lines, but if you see package they promptly discharge you.
-KK
-KK
75 CB550k
95 KLR650
you'll feel better.
Offline paulages
  • 1976 cb735
« Reply #15 on: December 16, 2006, 02:36:01 PM »
maybe, i wouldn't make the military cut (good thing, since i don't have flat feet and wouldn't fire a gun for bush to save my life), but that package is hard to miss! actually, it took me a minute to notice, but then i couldn't stop laughing.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
southbound
« Reply #16 on: December 18, 2006, 10:54:43 AM »
Sorry dude, no refunds.  the product was "experimental", therefore i'm not liable...  I think the mistake was not grinding off a tooth on the other side as well.  that should balance it, right?
Next project- "on the go" chain replacer/ feeder.
