Author Topic: intake boots  (Read 1416 times)
Offline evinrude7
  • not a kung-fu
  • something to hüsker
intake boots
« on: March 07, 2017, 08:03:08 PM »
well my attempt at dot 3 fluid and wintergreen oil to soften up these rubber intake boots and airbox boots returned mixed results.  it sorta worked.  some spots soft, some still hardened.  definitely better but i can tell i'm going to need new at some point because there will probably be some shrinkage.  likely i'll go ahead and drop the $150 for all new sooner than later.  has anyone noticed a major difference between the oem boots and the replicas?  good, bad, ugly?  in the mean time i'll use a heat gun to work them on/off.
<a href="https://m.popkey.co/266176/NlLb4.gif" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">https://m.popkey.co/266176/NlLb4.gif</a>
« Last Edit: March 07, 2017, 08:35:51 PM by evinrude7 »
cb750 k6 - ugly
Re: intake boots
« Reply #1 on: March 07, 2017, 08:15:42 PM »
I bought these and recommend them. Shipping is fairly quick considering he is in Europe.
http://www.ebay.com/itm/281252745222?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Offline evinrude7
  • not a kung-fu
Re: intake boots
« Reply #2 on: March 07, 2017, 08:26:10 PM »
cool.  hey know how to make a gif work on the board?
cb750 k6 - ugly
Re: intake boots
« Reply #3 on: March 07, 2017, 08:35:56 PM »
No
Offline evinrude7
  • not a kung-fu
Re: intake boots
« Reply #4 on: March 07, 2017, 08:40:45 PM »
basterd
cb750 k6 - ugly
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: intake boots
« Reply #5 on: March 09, 2017, 10:25:07 AM »
--Evan
1975 CB750K "Rhonda"
Offline evinrude7
  • not a kung-fu
Re: intake boots
« Reply #6 on: March 09, 2017, 04:28:18 PM »
did it work?
cb750 k6 - ugly
Offline Gene
  • Chat enuf you too can be a
Re: intake boots
« Reply #7 on: March 09, 2017, 05:17:41 PM »
It did. But I like Scarlett better . . .
*1973 CB750K3 (Bow)
Re: intake boots
« Reply #8 on: March 09, 2017, 05:25:07 PM »
No kidding, why's the noobie posting up a nude guy?
"Not that theres anything wrong with that"
Offline markreimer
Re: intake boots
« Reply #9 on: March 09, 2017, 07:33:07 PM »
To your original post/question - I bought some $40 aftermarket boots. Three years later one of them ripped in half when I removed the carbs.
I replaced them with OEM ones. Should have done that from the get go.
Offline evinrude7
  • not a kung-fu
Re: intake boots
« Reply #10 on: March 09, 2017, 07:42:56 PM »
haha.
thanks mark. yeah i'll get the oem.  old ones softened up a bit with some chem tricks.  also stuck them in the toaster oven on warm before i installed carb.  my wife wasn't too happy about me doing so but i did put them on foil, not right on the pan.  smelled good to me.
cb750 k6 - ugly
Re: intake boots
« Reply #11 on: March 10, 2017, 04:16:58 AM »
I bought cheap ones from cruzinimage. I saw cracks in 2 of them after a short while, around 2000 km.
http://forums.sohc4.net/index.php?action=dlattach;topic=155043.0;attach=316000;image
Back to the good old working ones, ordered original Honda that never had cracked for me before, only become hard.  Good idea to check the cheap ones after while. Inside, not visible from outside.
« Last Edit: March 10, 2017, 04:36:25 AM by PeWe »
Offline evanphi
  • Apparently I'm an
Re: intake boots
« Reply #12 on: March 10, 2017, 04:46:50 AM »
My cheap ones also cracked. Might have been partially my fault, but they still were destroyed.
Original hard ones back on, might buy some new ones eventually.
--Evan
