Author Topic: Paul Smart by KDI -Homage (re) Build-  (Read 10443 times)
Re: Paul Smart Replica
« Reply #25 on: March 09, 2017, 12:35:00 PM »
When it comes to a custom bike, do not build it with a dream of flipping it for a profit.  You will almost NEVER recoup your costs from building a full custom motorcycle.  Unless you have some fame as a custom builder, people will simply not pay the labor and parts that go into the build.
Build a motorcycle to please YOU and with the mindset that you will not be reselling it.  Keep your receipts for insurance purposes, but refrain from sharing them with your better half.
Offline calj737
  • I refuse...
« Reply #26 on: March 09, 2017, 12:40:49 PM »
Boys, you are forgetting yourselves! He's building this for his most lovely and wonderful wife. She doesn't need a HiPo 650 on a super cool, custom built by her hubby bike; he does! Let him save his money this time to pour into a 650/715 version of the PS. Then he will be rocking it High School  8) 8) 8)
Offline materializer
« Reply #27 on: March 10, 2017, 03:39:57 AM »
Forget the budget. All that will do is depress you in the end. If you want something, go for it. Most of use have WAY more into our bikes than they will ever be worth to anyone else. I'll be near $20K with mine and there are a ton of things I have not even accounted for yet, but it will be mine and I will be very proud of the end result. That's all that matters.
My kind of thought, honestly i dont have a budget in mind as I will just progress as budget permits..
And actually, I spent 6K on my bike (VT1100C2-97) and Im still working on her. The PS CB550-650 I'm starting off on now is for my wife, not intended to ever sell anyways.. But I would be happy to spend at least the 6K on hers aswel.  I know the effort put into these projects will never ever be rewarded in money ever again by someone.. Its the love man, the twisting of necks and pride of getting one's own taters out of the fire.
Monk
« Reply #28 on: March 10, 2017, 05:06:09 AM »
If it's for "her" then prioritize getting the correct ergonomics for her. (peg to seat, handlebar to seat, handlebar to peg, seat height) If it "fits" her she'll be more comfortable and enjoy the ride. That ought to be your first focus, then any replica ideas you have can come to play.
Have fun with it. but I see so often, bikes built to "look" like something else and would be completely uncomfortable to ride. They can look good & be comfortable, sometimes it just needs to be said out loud.
« Reply #29 on: March 10, 2017, 05:37:32 AM »
Hiya Man,
Yes, very true. The ergonomics are priority to me yes! Having a somewhat different bar and different peg set up is fine with me..
#$%*e, I should have never labeled this topic Paul Smart Replica.. Its to be an homage to it.. I just like the feel of the bike from photo. I figure if I'd do an interpretation and tweak it to fit my wife (not make it to extreme racy with low bars and such) I'll just look as sexy :)
Monk
« Reply #30 on: March 10, 2017, 05:51:07 AM »
Whether you glass bead or vapor blast (preferred), you will definitely need to completely disassemble the engine -- AND thoroughly clean it after blasting and before re-assembly.  Blasting media gets into the oil galleys.  You will want to blow compressed air through all of the passages AND clean all tapped/threaded parts of the engine.  IF you don't, you'll end up with blasting media in the oil or blocking oil flow.
Running early  (1969-76) 750K carburetors is a good performance upgrade.
If you are going to disassemble the engine, definitely mill the mating surfaces of the head and cylinders flat to help prevent leaks.
Concerning the milling of the cylinderhead and cylinders. As i've come to understand: mostly it is the cylinder head that might warp for various reasons. Would just milling that one do or are there obvious reasons (which?) for the cylinders themselves to need milling aswel?
Monk
Offline calj737
  • I refuse...
« Reply #31 on: March 10, 2017, 05:54:30 AM »
The head surface (mating surface against cylinders) is prone to warping. If you have the motor apart, it is only prudent to have the top of the cylinders "decked" to insure as flat a surface as possible. Honing the cylinder bores is a good idea simply to refresh them and provide best compression and oil sealing. If your pistons and rings are good, re-use them. Just check the end gap of the rings, and bores for measurement to spec. These parts should be fine given the mileage, but, with the neglect the bike has seen, its difficult to know for sure.
« Reply #32 on: March 10, 2017, 06:13:39 AM »
Cal,
Ah, kind of felt that would be the answer, just have the head decked..
I just found a wet blaster in my town, he'll do the whole engine for €60 :))))
On a forum in NL for car tuning I found a link to a guy that does cylinder head milling for €40
Ánd, I may have tracked down the carbs for a 750 to accomodate the pod filters..
About honing the cylinders: am I correct to assume that a smooth surface needs no touching up? And scratches or rough surface-> hone?
Cost involved with cylinder honing is €38 per cylinder locally. Which is a relief, figured it to be an expensive chore.
With these kind of prices i'll be able to get a lot of stuff done over the next couple of months.
Monk
« Last Edit: March 10, 2017, 07:13:42 AM by materializer »
Offline calj737
  • I refuse...
« Reply #33 on: March 10, 2017, 08:10:23 AM »
Actually, the cylinders are best if they have a "cross hatch" pattern. Smooth is the result of wear, hatching shows "fresh". The hatches help trap oil so the piston is lubricated on the downstroke and the rings wipe on the down stroke preventing oil from being introduced into the combustion cycle. Its a small price to pay for good compression and actually, you can purchase a Flex Hone stone and DIY this, saving the $130. You simply buy the Flex Hone (https://www.summitracing.com/parts/brh-bc23824/overview/) like this and use some good lubricating oil, a drill, and plunge down and up quickly a few times until you achieve a desired result.
« Reply #34 on: March 10, 2017, 08:20:46 AM »
Cal,
I actually saw these DIYs when googling for a honing business.. I think I dare to do it myself  :)
Indeed cost about €30, so saves €100 FTW
Monk
Offline Lostboy Steve
« Reply #35 on: March 10, 2017, 08:44:13 AM »
So are you saying "decking" the cylinders is a good idea? I have heard both opinions and can't decide what's right and wrong as far as these engines go. I had my head cut as minimal as possible but didn't do anything with my cylinders other than clean and hone them on my 550. It was a low mileage motor anyway but had been sitting for 25 years.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #36 on: March 10, 2017, 09:26:47 AM »
I figure Cal ment to say deck the head as i think those are most prone to warping. (But i see the typo? )
Verstuurd vanaf mijn HUAWEI GRA-L09 met Tapatalk
Offline calj737
  • I refuse...
« Reply #37 on: March 10, 2017, 09:36:25 AM »
I didn't specify having the head surfaced in that reply as it was a direct explanation to your prior reply.
For clarity, head warps most. Mill the head. In your situation given the neglect and mileage, I would also have the cylinders decked. Then both surfaces are flat and true. Decking/milling should always be done for the minimum amount, unless a specific HiPo goal is being designed.
Hope that clears it up.
« Reply #38 on: March 10, 2017, 09:55:02 AM »
Correct.  It's common sense.  If the surfaces between the head and cylinders are warped, decking one and not the other only fixes half of the problem.  Decking both will help insure a good seal.
Offline JoeCooley
  • Long time lurker, but now I'm a
« Reply #39 on: March 10, 2017, 12:11:27 PM »
Sounds like a cool project. Do you have any pictures of the build so far? These builds are more interesting with pics. Also, you can easily modify the first post to convey a more "homage" build.
Joe in San Diego - Quick Cyles
78 CB750K 836cc Highway Racer - http://forums.sohc4.net/index.php/topic,162264.0.html
Rickman CR750 Restoration (SOLD)
« Reply #40 on: March 11, 2017, 03:42:25 AM »
That's what I thought you meant. My questioning was genuine. It's always good to know a little more and possible ways of doing things. Thanks Cal.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #41 on: March 11, 2017, 07:44:00 AM »
Cal,
Monk
Honing isn't rocket science. Just don't overdo it. I like the head planing diy videos. Anyone wanna try that? Get yourself a piece of granite and glue some sandpaper to it... waalaa home made head decking.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #42 on: March 11, 2017, 10:30:03 AM »
So I tracked down two types of single side swing arms of the VFR RC36. And I'd like to ask you all some advise on which one to choose.
Both have slightly different fitting / width. I measured that the fitting between the two axle holes on my CB are 23,7mm.
Type one of the VFR rear end measures 22,8 mm
The other 24,2 mm
I'm temped to choose the one thats slightly under the required width and fill up the gap with spacers to match 23,7 mm.. : any reasons thinkable why I shouldn't?
Also I noticed that there's a bracket on the swing arm to attach the/a shock onto, which might make the build a little less complicated.
In the PS version I noticed the shock appears to go "through" this hole in the swing arm and this in turn needs a complicated customisation to keep it in place:
Any thoughts of you guys on why KDI might have gone down this road other than having a taller shock, or having it installed low in the frame as it is?
It's very difficult to make out in the pictures how exactly they they designed the geometry of the lower part.. Has any one ever seen a similar approach and would you be able to point me to images of that instance?
Monk
« Reply #43 on: March 11, 2017, 10:39:30 AM »
Remember that just because a show bike was featured in blogs doesn't mean that it's even run or functions well.  When it comes to suspension linkage, if you don't understand the engineering involved please consult someone who does so that it functions well and is safe (especially since this is for the wife!).
As for adapting the swingarm width, you are talking about either milling the larger cast arm or making spacers to fill in the width.  Remember that you want this portion of the swingarm to be as stable as possible.  Maybe creating gaps in this high stress area with spacers is not a good idea.
« Last Edit: March 11, 2017, 10:42:09 AM by CB750 Cafe Racer Fan »
Offline Steve_K
« Reply #44 on: March 11, 2017, 04:04:29 PM »
You will also need to check that the front and rear wheels line up.  I would not be surprised if some machining will be needed. You cannot be sure the other frame was centered the same way as your bike.  Research is your friend.
Good luck with the build.
Steve
Steve_K
« Reply #45 on: March 12, 2017, 04:17:33 AM »
Steve
Now Thats a good pointer! This will surely be a decisive point in deciding how to advance this part.
Monk
Offline calj737
  • I refuse...
« Reply #46 on: March 12, 2017, 04:25:12 AM »
Actually, you would easily center the rear wheel with spacers inside the swing arm. The swing arm is going to lay beyond the frame where it lays. You position your rear wheel and use spacers and offset sprockets to align the drive chain and tire centers.
Still have to do some geometry and math-
« Reply #47 on: March 12, 2017, 07:17:15 AM »
The other 24,2 mm
Monk
I know the cylinder head works in that bike because I did it. The fella that built that bike is in Connecticut.
Offline calj737
  • I refuse...
« Reply #48 on: March 12, 2017, 08:17:11 AM »
Mike - is he really running '29s? Seems awfully big for a 550 head...? Know anything about how the motor performs overall? Curious to the effect of that exhaust (so short and open).
« Reply #49 on: March 12, 2017, 10:24:02 AM »
The other 24,2 mm
Monk
Hi Mike !,
So you actually worked on this bike!?! I noticed your name pop up in one of the blogs covering this build, fantastic to find out your part of this forum!
I m not attempting to do the kind of engine pimping done in the one KDI did but I am very eager to approach the styling of this build.
In particular the tank, swing arm, front end and bodywork. I've tracked down most of the parts and am confident that i can get this done.
The ONE thing that will or will not have me do this build is whether or not the installing of the swing arm is a go or not. (if...if...if...:S)
I would be very grateful, like really-REALLY grateful if in some way you could introduce me to Kevin Dinsmoor. I have not yet tried to contact him as there's no website and just a facebook page.. and contrary to others I refuse to take part in that.. Is there any way you could introduce me to him so that I may work out with him how exactly the handled the rear end engineering?
There's just too much research involved in working out how to do this safe as some have pointed out. And since this build will be a gift to my wife, be my sole investment for the coming year or two I would need to have a certain base of knowledge and reference to definitively go ahead and put all my eggs in the basket and do this.
Looking eagerly out for your reply,
Monk
