Author Topic: Pilot air jet arrangement on Keihin PDs  (Read 1024 times)
Offline cjg1245
« on: March 08, 2017, 09:23:56 AM »
Hi, am stripping/cleaning/rebuilding the carbs on my 1977 750A. Anyone know if the tiny metal washer on the pilot air jet is essential ? One was missing from my carb set, and looking for a replacement from a spare set of carbs I have, there were none fitted.  Am wondering what the metal washer actually does, and if it is necessary.
Info gratefully received. Thanks in advance.
Re: Pilot air jet arrangement on Keihin PDs
« Reply #1 on: March 08, 2017, 09:27:22 AM »
yes, it is essential.
It keeps the spring from tearing up the tiny o-ring.
contact member harisuluv.  he has a plethora of carb parts.
Offline drumstyx
« Reply #2 on: March 08, 2017, 10:26:58 AM »
Are the carbs on the '77 A the same as the '78 K? If so, it's a pilot FUEL screw, and all the little washer does is press evenly on the o-ring so it's not the spring right up against it. I'm positive it'd run without it, but it's not the right way to do it. That said, it's just a washer, not a shim (someone correct me if I'm wrong) so if you can find something that fits -- i.e. from other bikes, other years (looks the same as a '78K to me...), etc.
« Reply #3 on: March 08, 2017, 11:11:11 AM »
Are the carbs on the '77 A the same as the '78 K? Yes for the most part.... small differences, needle adjustibility If so, it's a pilot FUEL screw, IMS= Idle Mixture Screw is the proper term, but yes, it does meter fuel during idle.  IN is leaner, OUT is richer  and all the little washer does is press evenly on the o-ring so it's not the spring right up against it. I'm positive it'd run without it, but it's not the right way to do it.  Certainly dont, as, over time, small bits of the oring can wear off and clog the circuit  That said, it's just a washer, not a shim (someone correct me if I'm wrong) so if you can find something that fits -- i.e. from other bikes, other years (looks the same as a '78K to me...), etc.
Offline cjg1245
« Reply #4 on: March 08, 2017, 11:43:42 AM »
[/quote
Thanks for the info. I thought it might work like that, but then saw on the schematic that it fits ABOVE the rubber ring and not between the spring and the rubber ring. That confused me a bit ! Since my post I have found a washer in my bits and pieces box.
Offline cjg1245
« Reply #5 on: March 08, 2017, 11:45:41 AM »
Thanks for the reply. Problem solved I think.
Offline cjg1245
« Reply #6 on: March 08, 2017, 11:48:39 AM »
Thanks guys, good info. Happily, problems sorted now.
Offline Jnel
« Reply #7 on: March 08, 2017, 02:12:18 PM »
A plethora.    Very good word
Sent from my SAMSUNG-SM-G935A using Tapatalk
« Reply #8 on: March 08, 2017, 02:28:14 PM »
Definitely more than a gaggle.
