Author Topic: tank restoration  (Read 720 times)
Offline evinrude7
  • not a kung-fu
  • something to hüsker
tank restoration
« on: March 14, 2017, 04:56:59 PM »
tank on my bike doesn't have the honda lettering badge.  i assume the POs probably removed them and filled the bracket area with bondo.  looking for suggestions on getting back to the brackets?  should i have the thing glass blasted?  other media?  sand to a point and blast after?  eventually painting the tank.
cb750 k6 - ugly
Re: tank restoration
« Reply #1 on: March 14, 2017, 05:14:47 PM »
 Good paint stripper will probably take it out if you go that route. Some guys burn it out. Lotsa different ways.
Online pjlogue
« Reply #2 on: March 14, 2017, 05:17:55 PM »
Carefully sand it down to expose what the filler is and go from there.  Most likely it's bondo.  Use a heat gun (make sure inside of tank is dry and aired out!) and heat and pick, heat and pick.  Nothing I know of will dissolve it after it cures.
-P.
Offline calj737
  • I refuse...
« Reply #3 on: March 14, 2017, 05:31:13 PM »
Chemical stripper for the paint. Then glass bead blast the filler out wherever you find it.
Offline evinrude7
  • not a kung-fu
« Reply #4 on: March 14, 2017, 05:35:14 PM »
thanks for the replies.  the inside of my tank is pretty damn clean. what can i do to keep it from rusting during the process?  some kind of fog?
« Last Edit: March 14, 2017, 05:42:10 PM by evinrude7 »
cb750 k6 - ugly
Offline calj737
  • I refuse...
« Reply #5 on: March 14, 2017, 06:05:16 PM »
Fog it is fine.
Offline evinrude7
  • not a kung-fu
« Reply #6 on: March 14, 2017, 06:26:18 PM »
sorry to be a dope newbie but what kind?  what should i look for or avoid?
cb750 k6 - ugly
Offline T100
« Reply #7 on: March 14, 2017, 07:19:10 PM »
Go buy some Marvel Mystery Oil and pour some of that in there and slosh it around. You can put that stuff anywhere and it'll be good.
Offline evinrude7
  • not a kung-fu
« Reply #8 on: March 14, 2017, 07:38:26 PM »
thanks t100.  i have plenty of that stuff on the shelf.  use it at the end of an oil change cycle on my truck.
cb750 k6 - ugly
