Author Topic: CB750 what is this electric component  (Read 1751 times)
Offline edosm
« on: December 11, 2006, 11:14:50 AM »
Hello,
I have a CB750F 1975
Can anyone tell me what this PART is because it looks like I need a new one..it broke a Tab off
Where would I be able to order it online.
Is there a Place in general to order from inorder to replace Electric Parts
Thanks
Mike
"Fix it! and it will Run!"
Re: CB750 what is this electric component
« Reply #1 on: December 11, 2006, 11:18:07 AM »
It's your voltage regulator.
Offline dusterdude
« Reply #2 on: December 11, 2006, 11:52:29 AM »
dude,i dont know how long you`ve been back,but im damn glad to see ya.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Raul CB750K1
« Reply #3 on: December 11, 2006, 12:01:34 PM »
Good luck. The regulator is hard to find and generally expensive. If it's just a broken tab and you can fix it easily, I would go that way.
Raul
Offline 750goes
  • it will live
« Reply #4 on: December 11, 2006, 12:39:37 PM »
Pick one up from ebay or see your local wrecker - not that expensive either....
Offline Clutch Cargo
« Reply #5 on: December 11, 2006, 12:44:12 PM »
1976  CB750K6
1976 GL1000
1994 - ST1100
1985 - HRS21
Offline GoatBaSS
  • Could someone find an
  • To weird to live, to rare to die.
« Reply #6 on: December 11, 2006, 01:20:14 PM »
Check this out:
http://www.sohc4.us/forums/index.php?topic=16153.0
Same guy twice, But I am vote three, and I will tell you that so far it has been a MAJOR improvement over all the stock regulators I have ever dealt with. It is worth every cent to take the old manual reg out of the system. I have a few of my old regulators for back ups, but I am that type of guy. L
Leethal # 3046?
1972 CB750K/900CC Red Headed Dunstall, 1975CB750FSS Gone BNF: 1974CB500T, 1976CB750K X 2
« Reply #7 on: December 11, 2006, 02:32:22 PM »
I just don't understand why people have such a problem with the stock regulator.  It's so simple.  It has a level of complexity just above that of a straight piece of wire in that it has a switch contact and spring in it.  Perhaps it's the dreaded adjustment that throws people in such a tizzy.
Okay, I admit, the switch contact can become dirty.  A bit of burnishing and you're good for another thirty years.  I haven't ever seen the adjustment change without ham fist intervention.
Certainly people have a right to toss money at whatever tickles their fancy.  But, I think I'll toss mine somewhere else.
Offline Jonesy
  • Shop Rat
« Reply #8 on: December 11, 2006, 02:54:03 PM »
Mine still works fine.. why change it?
Oh yeah.. a new-fangled one will make up for other problems in the electrical system.
But then, fix those problems and the stock one will work again...
This once again proves my theory: Time is the inverse of money. Spend a lot of money, spend little time. Spen a lot of time, spend little money. Spend lots of money and buy a modern regulator. Spend a bit of time cleaning electrical connections and check over the wiring and you're off and running...(this sound familliar with me, TT? :) You taught me a valuable lesson through that excerise with the 550. Welcome back, BTW)
Of course, our fellow here has a legitimate problem with his as the connectors have broken off.
Offline eurban
« Reply #9 on: December 11, 2006, 06:48:47 PM »
Well I know this has been "argued"/ discussed before but I swear to God that with the Oregon fella's voltage regulator on my 750 that I get a consistent 13.5 volts at 1000rpm idle.  The stock regulator does not in practice seem capable of matching that!  Definitely an nice uprgrade in my opinion (not too much $ either) , and yes I spent the proper time cleaning up and inspecting my entire electrical system too. . . . . .
« Last Edit: December 11, 2006, 06:53:33 PM by eurban »
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« Reply #10 on: December 11, 2006, 08:19:32 PM »
There's also this option- http://www.sohc4.us/forums/index.php?topic=12465.0
Inexpensive, electronic, and... um... cheap.
Works fine for me.  I've seen here that these will also help your battery to last longer,  but I can't give first hand confirmation of that.
Dave
Offline edosm
« Reply #11 on: December 12, 2006, 07:34:15 PM »
Thanks guys,
I just went ahead ordered part from
www.oregonmotorcycleparts.com    $50 Bucks with Shipping..should get it by the end of the week.
Thanks for the help everyone
Offline GoatBaSS
« Reply #12 on: December 12, 2006, 07:57:16 PM »
 ;D You will be glad you did,
Leethal # 3046?
