Author Topic: My gear lever fell off!  (Read 2650 times)
Offline wwatkins2016
    • na
« on: March 17, 2017, 12:32:37 PM »
Hey guys, I got an almost pristine '76 CB400F a while ago, and I was on my way to FINALLY get it inspected and registered this afternoon. Well I'm riding along and reach to shift down - only to find that my gear lever wasn't where I left it! It turns out that it slid off the shaft it was sitting on and was hanging by the gear linkage. I pulled over and was able to put it back on, but I saw that the shaft had a groove in it - is that where a snap ring is supposed to fit in place to hold it on? I've done research and I haven't been able to find any reference to anything holding it in place. Can y'all help me with this?
Sent from my SAMSUNG-SM-G935A using Tapatalk
Offline Scott S
Re: My gear lever fell off!
« Reply #1 on: March 17, 2017, 12:55:48 PM »
 Yes, there is a snap ring that holds it in place. If you look closely, you can see it in this pic.
« Last Edit: March 17, 2017, 12:58:37 PM by Scott S »
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #2 on: March 17, 2017, 12:59:58 PM »
Offline Scott S
« Reply #3 on: March 17, 2017, 01:12:52 PM »
 Yes, don't forget the washer!
'71 CB500 K0
'81 Yamaha XS650
    • na
« Reply #4 on: March 17, 2017, 02:15:05 PM »
Cheers. I'm about to call a Honda shop in town to see if they have the snap ring and washer, if not I'll order them from cmsnl.
« Reply #5 on: March 17, 2017, 02:19:14 PM »
you can order them from anywhere as long as you have the part number.
CMSNL(Holland) is pretty far  ;)
http://www.cmsnl.com/honda-cb400f-1976-usa_model443/partslist/E++17.html#results
    • na
« Reply #6 on: March 17, 2017, 05:35:11 PM »
Unfortunately it almost looks like cmsnl is the only place I'll be able to get the OEM parts. All the other websites I've visited either don't list them or say not available.
« Reply #7 on: March 17, 2017, 07:46:27 PM »
Use a oittle google fu and search 'Honda '  followed by the part number
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #8 on: March 17, 2017, 08:34:29 PM »
David Silver US store shows 8 in stock. I didn't check for the washer.
http://www.davidsilverspares.com/parts/by-part-number/partnumber_37187/
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline Scott S
« Reply #9 on: March 17, 2017, 09:40:56 PM »
 If you have a Honda dealer near you, they can order it and you can pick it up.
'71 CB500 K0
'81 Yamaha XS650
Offline przjohn
« Reply #10 on: March 18, 2017, 04:14:23 AM »
A good hardware store will have one that works. I did that on a 400f restoration.
Offline MoMo
  • Ride like you're invisible
« Reply #11 on: March 18, 2017, 11:52:27 AM »
Rather than use the e-clip, I drilled a hole and used the washer along with a clip(can't thing of the proper name but it is the type where the straight side goes through the hole and the other side goes around the shaft). Never coming off again.   senior moment on the terminology, sorry..Larry
« Reply #12 on: March 18, 2017, 05:51:49 PM »
hitch pin
Offline MoMo
« Reply #13 on: March 19, 2017, 03:51:42 AM »
hitch pin
thanks but I'll probably forget the next time
    • na
« Reply #14 on: March 21, 2017, 09:12:21 PM »
I ended up just going to a hardware store in town that had the washers and retaining clips and sticking then on there. Not the most elegant solution (the washer outer diameter is waaaaay too big), but it worked to get my bike to the inspection station and get it registered.
« Reply #15 on: March 22, 2017, 10:26:05 PM »
Actually it is not a Hitch Pin that MoMo described. It is a cotter pin.
MoMo, next time you have that you can tell anyone, when they get old they will have the same problem of having such a large vocabulary that it is easy to have those events.  At least it is not a song you can't get out of your head.  The Germans call those an Ear Worm.
Both could drive you mad.
David
hitch pin
Offline MoMo
« Reply #16 on: March 23, 2017, 06:35:47 AM »
David,  hitch is correct term for what I used.  Head is a tad clearer today ::)...Larry
