Author Topic: Parts for CB750F  (Read 1939 times)
Offline Kawahonda
Parts for CB750F
« on: March 19, 2017, 01:30:49 PM »
Putting together a fully restored F0.
I'm having trouble finding some basic parts, though.
2 x 61312-392-000
2 x 80106-329-690
Any help is appreciated!
Re: Parts for CB750F
« Reply #1 on: March 19, 2017, 03:36:59 PM »
 So you wanna give us a hint what that might be or do we have to google it for you ?
Offline Kawahonda
« Reply #2 on: March 19, 2017, 04:36:22 PM »
« Reply #3 on: March 19, 2017, 04:53:35 PM »
 Ah yes the rubber grommets at the bottom of the headlight frame and the metal inserts for the top. Those do seem to be not available anywhere. Have you cruised the bins in a well stocked old school hardware store yet to see if anything could be modified a little ? Hopefully someone on here has a couple extra of each or try the parts wanted or maybe a suggestion.  I remember shopping for that bracket on a bike that came to me with a fairing and had to look awhile to find one with all those pieces still intact.  Good luck on your hunt.
« Last Edit: March 19, 2017, 04:56:11 PM by ekpent »
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #4 on: March 19, 2017, 07:09:43 PM »
Never mind...  ::)
« Last Edit: March 19, 2017, 08:23:11 PM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #5 on: March 19, 2017, 07:42:03 PM »
 Those I believe are for the headlight bucket the ones he need (2) are bigger for the headlight frame bracket. For that spot actually just a couple flat washers would work probably. Those bushings (2) at the bottom of frame are more important.
« Reply #6 on: March 19, 2017, 08:24:39 PM »
You are correct. I guess I should have gone straight to the parts fiche first, as much as I was trying to avoid doing so...  :P
TAMTF...
Wilbur
Projects:
Offline Kawahonda
« Reply #7 on: March 20, 2017, 07:22:36 PM »
Yea, I had a feeling they were going to be touch parts. :(
Offline kerryb
  • Not a very
« Reply #8 on: March 20, 2017, 07:53:18 PM »
See topic 101949.0 by tugboat in Feb of 2012.  They talk about these as fender mount parts on fenders.
« Reply #9 on: March 20, 2017, 08:15:07 PM »
 I wondered if 400F sidecover grommets would work. Aren't they similar?
Offline Kawahonda
« Reply #10 on: March 22, 2017, 11:58:47 AM »
Hmm. Hopefully I don't have to go into the experimentation :(
Offline przjohn
« Reply #11 on: March 22, 2017, 05:35:21 PM »
For the bottom ones I used an expander plug bought at the hardware store and burned it through with a hot 5/16 drill bit. The top ones I had in my boxes of rubber goodies from a Kawasaki restoration, they fit just fine. You should be able to also rig something up with those from the hardware store, they don't have to be perfect, just rubber mounting the headlight. Oh, and when I say a hardware store I don't mean Home Depot. I mean a REAL hardware store.
Offline Kawahonda
« Reply #12 on: March 24, 2017, 11:04:12 AM »
Awesome. Yep, we got some "real" hardware stores around here, which is great.
Do you have any pictures to share of what you did?
Offline Johnny340
« Reply #13 on: March 24, 2017, 12:37:50 PM »
Let me know if you find something before I go digging through my stuff.  I took all that off of my F0 and don't need any of it.  Are the grommets on the headlight bracket or the triple clamp...I can't tell from that picture link..
1975 CB750F0 Super Sport
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
« Reply #14 on: March 24, 2017, 04:33:48 PM »
 Usually they are on the bottom of the  bracket but could be stuck in the lower triple. Lotsa help eh  :D
Offline przjohn
« Reply #15 on: March 25, 2017, 09:00:46 AM »
Pretty sure I mentioned it in my build report.
http://forums.sohc4.net/index.php/topic,152712.0.html
Offline Kawahonda
« Reply #16 on: April 02, 2017, 10:33:36 AM »
Thanks. I picked up some of those at the hardware store. Do these have to be a certain length?
« Reply #17 on: April 02, 2017, 04:33:01 PM »
 Next time I go to my shop,probably a day or two, I will grab a 750F headlight bracket I got with those parts and can give you some good pics and dimensions if those are still needed. At one time in the not to distant past member Chewbacca (or however its spelled  :)) had one unit he would sell and think it had its bushings,might still be available. Selling in the sellers column now.http://forums.sohc4.net/index.php/topic,163824.0.html
« Last Edit: April 02, 2017, 04:35:14 PM by ekpent »
Offline Kawahonda
« Reply #18 on: April 03, 2017, 10:13:48 AM »
Thanks everyone.
Nothing more is needed at this point. I wound up using a larger expander plug for this at the hardware store compared to the one shown in pictures here. It was large enough to have a "snug fit" inside of the holes in the opening, which I would think is more ideal vs the smaller expander plugs that is shown here which has a little bit of flop. I'll take some pictures if you guys are curious.
Also, the larger expander plug requires no drilling.
