Author Topic: Bought a '77 750 Super Sport . .  (Read 2237 times)
Offline PetesPonies
« on: March 19, 2017, 02:09:03 PM »
really, really nice shape. Has only 12K miles, previous owners went crazy with dealership tuneups and repairs . . . .  all good for me  :)  This is my first SOHC Honda. Previous owner upgraded all three calipers to twin piston types, had them powder coated as well. It has the stock exhaust, that has been ceramic coated. It has a $450 Corbin seat, etc, etc. I will be changing a lot of it though. I love the performance aspects of the F with the triple discs, etc, but am going to change it to a more vintage CB750 look. That's me, I make everything look older. I brought it home yesterday, so I tinkered a bit today. It had a lot of engine noise at idle. I adjusted the cam chain a couple times and got rid of any noise there. Only noise left is from the clutch at idle with the lever not pulled. Once the engine warms this rattle goes away. Is this normal? Or should I adjust the clutch tolerance with the lever not engaged? I tested the charging system and have over 14V at 3Krpms . .but at idle not much, if any, over battery voltage. is this normal for these bikes? I want to fit an older tank, side covers, a seat that works, older fenders, etc. I'm technically capable, but would listen to views from others who have done similar things, as the best parts to seek, etc.
I'm including a couple past bikes ( Harley I still own )that have had extensive modifications . .even if they don't look like it  :) That's the trick.
« Last Edit: March 19, 2017, 02:10:55 PM by PetesPonies »
Pete's Ponies
Mustang RUSToration & Performance
Offline slikwilli420
  • Master of Disaster
Re: Bought a '77 750 Super Sport . .
« Reply #1 on: March 19, 2017, 02:33:48 PM »
Letting the Corbin go?
Offline PetesPonies
« Reply #2 on: March 19, 2017, 02:52:59 PM »
Eventually, when I find the pieces that will replace the current setup. It was bought last July, not even a year old, like 500 miles on it  :)
Pete's Ponies
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #3 on: March 19, 2017, 03:13:10 PM »
holy #$%* on the 77F
cb750 k6 - ugly
Offline suprafabs
« Reply #4 on: March 19, 2017, 03:18:44 PM »
looks like in  good shape
Offline PetesPonies
« Reply #5 on: March 19, 2017, 04:39:10 PM »
Any answers to my two questions?
Pete's Ponies
Offline MoMo
  • Ride like you're invisible
« Reply #6 on: March 19, 2017, 04:43:16 PM »
Idle rattle you described is normal as is the charging scenario.  Pull in clutch and rattle goes away, hit 3000 rpm and voltage goes to 14+,  right?  Welcome....Larry
Offline PetesPonies
« Reply #7 on: March 19, 2017, 04:49:28 PM »
Exactly right MoMo . . .  so typical huh? OK  :)
Pete's Ponies
« Reply #8 on: March 19, 2017, 05:50:05 PM »
Get ahold of me if you want to sell any of that bodywork.  That's is a nice bike.
Offline MoMo
« Reply #9 on: March 19, 2017, 07:17:13 PM »
sure is, and nice bike  BTW
Offline PetesPonies
« Reply #10 on: March 20, 2017, 08:33:46 PM »
Any ideas on what calipers were used on my bike? All three were changed, powder coated as well. They fit the stock mounting, but are dual piston. Did the '79 up Fs use dual piston? Maybe from them????
Pete's Ponies
Offline Pat_at_APE
    • APE Race Parts
« Reply #11 on: March 21, 2017, 11:45:46 AM »
My best guess is the calipers are from a CB900F/CB1100F from a few years later.  I've got some ready to fit to my 77 CB750F as well.
Pat
« Reply #12 on: March 21, 2017, 11:50:47 AM »
Not many people with the corbin seat for the F's.  Did the bike come from a member here?
Its normal for things to quiet down when temps come up and the idle settles.  Gotta get the juices flowin'
Dont forget the vacuum sync of the carbs.  This really helps quite things down.
Offline PetesPonies
« Reply #13 on: March 21, 2017, 03:47:58 PM »
No the bike wasn't from anyone here, I don't think. I didn't purchase it through a contact here.
« Last Edit: March 21, 2017, 08:47:44 PM by PetesPonies »
Pete's Ponies
Offline PetesPonies
« Reply #14 on: March 21, 2017, 08:48:12 PM »
Pat
Thanks Pat.
Pete's Ponies
Offline b1jackson
« Reply #15 on: March 22, 2017, 06:36:50 AM »
Yes. Thats what they look like.  My 75 supersport has a different brake caliper mount and I'm looking to figure out a dual disc option for that bike as well without a fork swap or major $$.
Old Honda Rescue Centre
ohrc_vintagemoto on Instagram
Offline PetesPonies
« Reply #16 on: March 23, 2017, 04:46:48 PM »
I like this bike for the performance potential But I like the looks of the Gen 1 CB 750. So I will be switch some things. I wish I could switch my fork. But I like the dual disc and certainly like how these calipers are operating.It's easily the best brakes I have ever had on a  bike. I could get rid of the black on my lower legs, polish the leg. That would help. But I wish the leg had mounts for fender stays. I may have to create my own mount if I want to run a fender with stays. I don't want to give up the calipers   :)
Pete's Ponies
Offline SKTP
« Reply #17 on: March 23, 2017, 05:47:16 PM »
I think it sounds like a bad idea to turn the 77F into an older K...but to each their own...I think it would be way easier to just get a 70-76K and go from there...either way, have fun.
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #18 on: March 23, 2017, 06:17:44 PM »
+1 Hell, someone would probably trade ya.
Offline PetesPonies
« Reply #19 on: March 24, 2017, 07:35:37 AM »
 I'm not interested in getting rid of it? I'm not. I guess you didn't read how I like the performance of the F. If you ever look at my builds, both bike and cars, you'll see I have done some interesting transformations.
Pete's Ponies
Offline PetesPonies
« Reply #20 on: March 24, 2017, 07:37:10 AM »
So interested guys, it looks as if I will be getting rid of everything on the top of the bike, tank, seat, rear fender and either the entire exhaust or at least the muffler. What kind of money do you think they should bring?
Pete's Ponies
« Reply #21 on: March 24, 2017, 09:41:57 AM »
The brakes are the only thing on the bike that perform significantly better than earlier models.  You will have a much nicer bike if you start with something close to what you want.  Stock resto are worth more with these.  If you want to post some better pics of your tank and tail section, I would give you an offer.
Offline PetesPonies
« Reply #22 on: March 24, 2017, 04:13:16 PM »
This is what I do, I make major transformations. Piece of cake.
Tell me what these were originally . . .
Pete's Ponies
Offline PetesPonies
« Reply #23 on: March 27, 2017, 04:46:08 PM »
I bought a chrome 550 rear fender. I have it only bolted through the top two bolts, but it fits. I'm feeling my way here, so I wasn't sure how many of the factory mounting points would work. The F tail section will be leaving, just trying it on for size.
Pete's Ponies
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #24 on: March 28, 2017, 12:04:45 AM »
+1 on the performance thing.
Probably more noticeable difference in performance when they were factory fresh 40 years ago, but you'd struggle I reckon to find a K and F in similar state of fettle and wear to make a comparison today. Interestingly, I rode a mate's '74 K chopper a few years ago, no performance mods other than pods and jetting, and (in a straight line) it was equally as fast, if not quicker than either of the two F's I have subsequently owned. Butt-dyno testing obviously.  ;D
Build threads:
1977 CB750 F2
1958 Norton Model 99
