Author Topic: The rubber on my CB400F kickstarter is coming off.  (Read 1031 times)
Offline wwatkins2016
    • na
« on: March 21, 2017, 08:50:30 AM »
Hey guys like the title says, the rubber pad my kickstarter is sliding off. Is there a good way to get it back on? I.E. rubber mallet to the side of it, lubricant, etc.?
Thanks.
Offline markreimer
Re: The rubber on my CB400F kickstarter is coming off.
« Reply #1 on: March 21, 2017, 08:58:27 AM »
Thanks.
Just push hard. Being serious! No tricks.
Offline Ridem32
« Reply #2 on: March 21, 2017, 09:00:20 AM »
In the old days we put lighter fluid on the metal then put the rubber on I think it kinda melts the rubber to the metal. Used it on such as yours and hand grips. But nowadays they make a glue just for grips etc
Offline Jimray23
    • none
« Reply #3 on: March 21, 2017, 09:07:35 AM »
Yea just push and twist at the time.
Jimmy
1979 kz1000 ltd mkii
     dyna s ignition, dyna 3 ohm coils, solid copper core plugs, full rewire.
Offline Mooshie
« Reply #4 on: March 21, 2017, 12:35:36 PM »
try a dab of dishwash soap.  You don't need much
1976 CB550F
Standard disclaimer: Remember I am just a girl--so be nice fellows!
Offline DaveBarbier
« Reply #5 on: March 21, 2017, 05:24:50 PM »
Heat it with a heat gun. Any lubricant you put on there will definitely help it slide on...and off. Some people use hair spray for grips because as it's slippery when wet but sticks when dry. You could try that.
Offline Smudgemo
  • Maker of Stuff
« Reply #6 on: March 21, 2017, 08:11:50 PM »
I forgot about hairspray - great idea.  I was going to suggest plain old rubbing alcohol.  Super slippery until it evaporates.  Works great on bicycle grips, anyway.
-Ryan
Thread - How to fix your starter button (for real): http://forums.sohc4.net/index.php/topic,163170.0.html
Offline Feets007
« Reply #7 on: March 23, 2017, 03:37:07 PM »
Save weight, throw it away.
