Author Topic: Cb400f idling rough  (Read 1213 times)
Offline Doom64
Cb400f idling rough
« on: March 26, 2017, 01:21:44 PM »
Hello everyone, I have had my 1977 400f for a while now and it has always idled rough, I had new Pistons, piston rings, cam chain, skimmed barrels, electronic ignition and a few other bits about 1500 miles ago, when it was first fired up the timing was set up and the carbs balanced.
When that was all sorted it started first push of the button but it slowly started getting worse, it got hard to start and idling got rougher it would sit at 1200 and go up to 2000.
Last week the timing was adjusted so now that's correct and today i cleaned the carbs out and they were a bit dirty but one carb was dirtier than the rest with a couple blocked jets (cleaned the emulsion tubes too).
Took it out for a spin it runs better but it still idles rough going up and down, the rubbers are all on correctly.
The previous owner put all new jets and emulsion tubes in but i am not sure if they were genuine Honda ones, could that make a difference?
Could the carbs need balancing again?
When it's not idling it runs lovely and accelerates smooth and fast.
Any help with be great as this it getting on my nerves  ::)
Offline gwallis
  • 1976 Honda CB550F 1973 Honda CB750
Re: Cb400f idling rough
« Reply #1 on: March 27, 2017, 06:11:37 AM »
I also have a 1977 CB400F and have experienced the same problem.  When first starting I use the choke and the idle goes up and down until I make some kind of small adjustment to the choke or until it warms up.  Other than that the bike runs very strong!
Any info on this situation would be very helpful.
Offline innovativems
    • Innovative MotoSports
« Reply #2 on: March 27, 2017, 06:23:10 AM »
I would definitely sync the carbs
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline gwallis
« Reply #3 on: March 27, 2017, 06:29:53 AM »
Yeah... I did that several months ago, with my Carbtune, and they were 'right on'.  Hard to imagine that they would be out of sync with only a few miles on them.
Oh well... it's not a major problem... nothing that I can not live with at this time.
'Thanks' for the reply!
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #4 on: March 27, 2017, 09:26:04 AM »
I was informed the vacuum carb sync should be checked/adj. when you do your 3k service.
Offline Doom64
« Reply #5 on: March 27, 2017, 01:42:55 PM »
Hello thanks for the replies, I synced the carbs today, I done it when the bike was warm and two were out, it idled nicely but when I took it for a spin the idling was better but it was still going up and down, should I redo them tomorrow but take the bike for a ride first then adjust them?
Also I was just reading the throttle stop screw can make the bike idle funny if not adjusted right, is that true?
When I push the throttle round the revs go down a bit.
« Last Edit: March 27, 2017, 02:04:16 PM by Doom64 »
« Reply #6 on: March 27, 2017, 02:22:43 PM »
Recheck everything for vacuum leaks.
Pull the boots and inspect each one.  Over-tightening them over the years can introduce tears not seen until the boot is bent.
Offline Tim2005
« Reply #7 on: March 27, 2017, 02:37:21 PM »
Does it have the stock airbox and filter?
Offline Doom64
« Reply #8 on: March 27, 2017, 02:51:00 PM »
I will check the boots thanks.
Yes it has stock airbox and filter but the exhaust is a shorter reverse magaphone but it still idles rough with the standard end can on.
