Author Topic: Full throttle issue - CB 500  (Read 689 times)
Offline Norwegian CB-rider
« on: March 26, 2017, 02:39:05 pm »
Hi guys!
Please bear with my english, it´s a little rusty!
I have got a little problem with my CB 500K from 1977. If the bike is idling and I snap the throttle wide open the bike stalls immediately. The bike revs just fine until about 50% of full throttle at idle. On the road the bike behaves like normal until I suddenly snap the throttle open. The bike does not pick up speed immediately, and starts to hesitate. Eventually it picks up speed after a couple of seconds of coughing. If I open the throttle gradually the bike goes like a little rocket, even when it reaches wide open throttle. Seems like the mixture isn't right, to lean - right?
I guess a little more info about the will come in handy. I completely rebuilt the engine during wintertime, and had a new 4-4 exhaust (replica) hooked up. I swapped out the new air filter with a new one, and I run the original air filter box. Yesterday I removed all the plugs, one of them was a little black (cyl. 2). The other ones seemed okay. I cleaned off the black plug with a brush and screwed it back in.
I also removed the carbs, popped them open and removed the needle jets. Cleaned them out with a little needle and compressed air and made sure nothing was trapped inside the little holes. I often hear people talk about crap inside the bowls, well I wouldn't say my ones were messy at all. Some minor white and green contaminants on the needle jet bodies tho... The name of the carburetors I believe is Keihin PD46A. The little mixture screws found on the engine side of the carb body were not adjusted with the same amount of turns on the carbs, so I screwed the snug, then i opened them one and a half turn just to start. I probably should have taken the carbs further apart, because the problem is still there.
So what should I do next? The bike is definitely rideable, so it is not a major problem. But it would be lovely if like the bike responded to wide open throttle without any hesitation.
« Last Edit: March 27, 2017, 04:46:21 am by Norwegian CB-rider »
Offline Airborne 82nd
Re: Full throttle issue - CB 500
« Reply #1 on: March 26, 2017, 05:31:34 pm »
Do you have a accelerator pump on those carb?
Offline calj737
  • I refuse...
« Reply #2 on: March 26, 2017, 05:39:24 pm »
No.
Your issue is typical with older carburetor. They are not very tolerant of "snapping" the throttle open because you are switching from the idle to main jet and waiting n the engines vacuum pressure to pull the requisite amount of fuel into the engine.
If you ride with a smooth throttle action, you should be just fine.
« Reply #3 on: March 27, 2017, 04:45:34 am »
No.
Like you´re saying there is no accelerator pump, so I came to the same conclusion. The bike goes just fine as long as I handle it right. It is a little annoying, but I can live with it. I added a bottle of a fuel additive to clean carburetors and injectors, but it is a little early to tell if it made any difference. If anyone have got any tips and tricks let me know. Thanks for your help so far!
Offline calj737
  • I refuse...
« Reply #4 on: March 27, 2017, 05:13:57 am »
You have to realize this is not a modern, fuel injected, drive-by-wire variable vale timing machine. Its a 40 year old, vacuum inducing, gravity fed fueled SOHC. Treat it kindly and ride it wisely  ;) You'll have decades of enjoyment once you become accustomed to how it behaves best.
