Author Topic: 550 rear cush hub removal  (Read 734 times)
Offline my name is nobody
  • I like Pontiacs and Hondas
« on: March 27, 2017, 07:07:56 AM »
Any tricks to getting cush drive hub loose? I've pryed, beat from inside drum outward, used sprocket
as a slidehammer, all till I'm blue faced to no avail. what am I missing? Am I fighting an internal o ring? Hub/sprocket should just pull out yes? thanks..
Offline FridgeRaider
Re: 550 rear cush hub removal
« Reply #1 on: March 27, 2017, 07:35:37 AM »
Do you have the bearing retainer out? If not, you must drill out the stakes in the 4 places. Then carefully unscrew the retainer. That removes, allowing the cush drive to be pulled out.
Part #3 in the diagram
http://www.cmsnl.com/honda-cb550-k1-four-1975-usa_model466/partslist/F++04.html#results
I had the same problem this weekend. I did exactly as Cal says above but my retainer (K3) was reverse threaded. I had to turn it clockwise to remove. The retainer is accessed by removing the sprocket.
1972 CB750K2 Resto-mod (836cc Upgrade) - http://forums.sohc4.net/index.php/topic,161782.0.html
« Reply #2 on: March 27, 2017, 08:19:47 AM »
Thanks guys. I'd have been there for a long time otherwise. Definately different than my 750.
