Author Topic: Wiring in cb400  (Read 1773 times)
Offline Dingo707
Wiring in cb400
« on: March 28, 2017, 04:40:21 PM »
Hi all... i got a project bike from a good neighbor.. its a 78 cb400t.  Runs great. I want to basically strip it down to only have essentials... head light and tail light... my question is... is there away to figure out what wires are only needed for those or is there a simple wire harness i can buy? I'm asking bc he has already stripped it down and now wires are a bit everywhere
Offline CBJoe
Re: Wiring in cb400
« Reply #1 on: March 28, 2017, 06:16:34 PM »
The Honda Twins forum may be better served for that type of Info
http://www.hondatwins.net/forums/15-sohc-twins-125-250-400-450-cb-cm-n-rebels-1978-2008
Cheers, Joe
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline calj737
  • I refuse...
Re: Wiring in cb400
« Reply #2 on: March 28, 2017, 07:02:49 PM »
Here's what you need to know-
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=3937tdmetkof97fkpvls83gn71&/topic,60973.0.html
Re: Wiring in cb400
« Reply #3 on: March 29, 2017, 06:55:31 AM »
cb 400/n- twin are a newer bike then sohc..and use a different ignision system..so nothing/ in common vith cal"s simpel diagram..better go to a spec forum for korrekt help. ..
.like cb- joe already..vrote..
« Last Edit: March 29, 2017, 06:58:30 AM by strynboen »
i hate all this v-w.... vords
Offline calj737
  • I refuse...
Re: Wiring in cb400
« Reply #4 on: March 29, 2017, 09:32:27 AM »
I wasn't offering it as "wire per this" diagram, I was answering the question of "what minimal requirements" are needed. Wire colors and CDI will be different. Hopefully the OP is sharp enough to know that  ;)
Offline strynboen
Re: Wiring in cb400
« Reply #5 on: March 29, 2017, 11:28:15 AM »
yes you are just send a vrong  simplyed diragram to make him Sharp and ready for a nice vire hack job.. 8) 8).
.just like the" cut  in half trippel" cbx engine ..
its not only ignision..the battery load system are elektronic..and dont match the sohc area bikes either
« Last Edit: March 29, 2017, 11:30:28 AM by strynboen »
Offline calj737
  • I refuse...
Re: Wiring in cb400
« Reply #6 on: March 29, 2017, 01:35:18 PM »
Your inability to understand context is what's "wrong". What I wrote is, "...what you need to know" to imply the functional components needed. Whether they be electronic or mechanical, SOHC4 or T. The principles are the same.
You'd do better to trim your nose than poke it where its not appreciated.
Offline strynboen
Re: Wiring in cb400
« Reply #7 on: March 30, 2017, 06:51:03 AM »
think its you vho pokes the vrong place..Again.
.but im aut of this thread.
.thred starter have prob faund the right place to find exact info..
so ve can go back to stering damper and oil and tires..and popcorn..and some motorcycling..
