Author Topic: 500 vs 550 airbox and air filter??  (Read 2049 times)
Offline JBCB500
  • Really enjoying this!
« on: March 29, 2017, 09:08:04 AM »
Yesterday I picked up an airbox from a salvage yard.  They believed it to be from a 550.  I have a 500 and hope it will work - any reason it wouldn't?
Also, from 4into1 parts I note that the 500 and 550 air filters look slightly different?  If this is indeed a 550 airbox and I put a 500 filter in, will I have a problem?
Re: 500 vs 550 airbox and air filter??
« Reply #1 on: March 29, 2017, 09:22:36 AM »
This Honda 17313-323-040 HOUSING, A/CLNR ELEM is used on these models and components:
Models with no year CB500 A AIR CLEANER + SIDE COVER
Models with no year CB500K1 A AIR CLEANER + SIDE COVER
Models with no year CB500K2 A AIR CLEANER + SIDE COVER
^^^ this means the CB500 air filter housing is only used on the K0, 1 & 2....and no other 5xx models.
Its probable that the shape of the 550 housing you picked up wont fit, regardless of the filter used.
« Last Edit: March 29, 2017, 09:25:06 AM by flybox1 »
Offline JBCB500
« Reply #2 on: March 29, 2017, 09:31:30 AM »
Thanks flybox! Now I wonder if there would be any problem using a 550 airbox with 550 filter on a 500?
« Reply #3 on: March 29, 2017, 09:54:19 AM »
that's what I just answered  :-\
The the part numbers are different.  If they were the same, then it would be a direct swap.
Im almost certain the 550 filter element is used in several CBs, so the filter is not the issue....its the shape/mounts of the housing itself.
Offline JBCB500
« Reply #4 on: March 29, 2017, 10:07:01 AM »
Haha, apologies! Yes, I miss-read that badly!
« Reply #5 on: March 29, 2017, 10:08:11 AM »
No problem.  search ebay by the part number i listed.  you might get a few listings.
Offline Scott S
« Reply #6 on: March 29, 2017, 10:08:16 AM »
 I think the only difference is the breather/EPA stuff. The 500 boxes/plenums don't have the barbs for some of the EGR hoses. Otherwise, they're the same until you get to the '77-78 plenum, and even then you can make it work with the right air box to carb boots.
 I don't see any reason why you can't use the one you picked up.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #7 on: March 29, 2017, 10:10:32 AM »
That would be cool.
Offline jonda500
« Reply #8 on: March 29, 2017, 04:08:16 PM »
+1  I think any cb500/550-4 airbox will fit. I believe the air chambers (plenums?) are nearly exactly the same and are all interchangeable too (and all use exactly the same boots between the carbs and the air chamber)
I think a 500 filter would fit/work in a 550 airbox - I have both, let me know if you want me to check?
John
A starter clutch thread:
Offline JBCB500
« Reply #9 on: March 29, 2017, 07:47:43 PM »
All good folks, thanks!
In fact, today I installed a 550 lower box with a 500 upper box and 500 filter.  Looks great! I'm looking forward to seeing if there's much difference between this and pods as soon as I get my petcock situation sorted!
Thanks as always for all of the input!
