Author Topic: Help for 1973 CB350F - Pipes for cylinders 1,2,3 hot but 4 is cold  (Read 594 times)
Offline nessandpaula
I have no idea what it could be.  I don't think it is the carbs not giving gas to 4 cause the runoff from that carb drips gas.  all the other cylinders are firing great, but 4 just won't.  Any ideas?  thank you
Offline Gordon
  • 750K1, 550K2
Re: Help for 1973 CB350F - Pipes for cylinders 1,2,3 hot but 4 is cold
« Reply #1 on: March 29, 2017, 07:26:00 PM »
If the overflow is dripping gas then either the float is stuck or the valve isn't closing completely.  Either way it's getting too much gas, which would cause that cylinder to not fire.
Offline whizzer
  • Be safe
« Reply #2 on: March 30, 2017, 09:11:46 AM »
How about unscrewing spark plug caps and if wire corrosion, snip off tad so contact with cap is good.  The cap has a spike that must screw into wire. Eighth of an inch freshens the contact.  This fixed intermittent firing problem on my bike. Could test caps' resistance, too, and replace if worn out.
72 cb350f
66 cb77 sold
72 Suzuki gt750 given away
59 Vespa given away
06 Whizzer sold
« Reply #3 on: March 30, 2017, 09:15:32 AM »
+1^^  -  fuel level is too high there.
revisit float height/ float valve function, and BEFORE you put the carbs back on the bike, do a clear tube test to verify your fuel level is 3mm below the bowl gasket seam.
Offline DaveBarbier
« Reply #4 on: March 30, 2017, 12:04:20 PM »
Also just check the plug is firing by removing it and holding against the motor to see if there's a spark.
Motor off, remove plug, reconnect to cap and plug wire, hold threads against motor, fuel off, key and ignition on, crank motor. Best in a dark shop.
Hold it with rubber gripped pliers :)
