Author Topic: Cb750 starts revving...  (Read 1974 times)
Offline koendd
« on: April 04, 2017, 10:49:34 AM »
So last ride last year 5mins before i got home my k2 750 started acting up...
When idling and between shifting gears  the bike started revving. One blip on the throttle and it would idle fine again.
Few weeks ago first ride of the year same problem...
Yesterday started with ignition, cam chain, valve adjusment and carbs synch.
Lube the cables and slide shafts, checked all manifold rubbers and thightend if necessary, same problem!
Only does it when warm, with one (sometimes 2) pulls on the throttle it idles again after a split second.
My guess is it isn't drawing any false air, checked with brake cleaner, no change in rpm...
Any ideas?
Verzonden vanaf mijn iPhone met Tapatalk
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Re: Cb750 starts revving...
« Reply #1 on: April 04, 2017, 11:00:48 AM »
check for throttle cable binding, return spring function, slides snap closed...etc.
do you have both push/pull cables?
does the 'push' cable help bring the idle back down?
Offline drumstyx
« Reply #2 on: April 04, 2017, 11:03:27 AM »
Vacuum leak maybe? I've never had any luck testing for small vacuum leaks with a spray can of stuff. Smoke is probably a better way to see, but do you get this issue when you're idling in your garage?
Offline koendd
« Reply #3 on: April 04, 2017, 11:16:48 AM »
I have pull push yes. Checked when revving and cables and shaft are free so cables not involved. Pushing the cable has no effect.
And will check again for vaccuum leaks...
Does the same not under load so when i got back home after test ride earlier left it running at idle on the driveway. Twisted the trottle, started revving again...
No idea where it would be takkng false air though. Bought new oem
Boots last year. Ran fine ever since all summer until last ride last year in november.
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Offline drumstyx
« Reply #4 on: April 04, 2017, 11:23:00 AM »
Could you be describing a hanging idle? This can be caused by a lean condition, or, as I've discovered, very unbalanced carbs that have been compensated for with the idle screw being set too high.
« Reply #5 on: April 04, 2017, 11:23:38 AM »
All your vac sync port screws securely in place?
Boots removed and checked for cracks not visible unless the boot is bent out of round?
when was your last vacuum sync?
Offline Grabcon
« Reply #6 on: April 04, 2017, 11:28:40 AM »
Have you checked you ignition advance? Is it clean and does it move freely?
CB750   1974 - Gone
CB750F 1976 - Gone :(
CB550   1978 - Gone & now back
CB900F 1981 - Gone
ST1100 1991 - Gone
ST1100 2000 - Gone
VFR800 2008 - Gone
ST1300 2008 - Gone
BMW F700GS - Wife's
VFR1200X 2016 - Mine
Offline Spanner 1
« Reply #7 on: April 04, 2017, 11:34:54 AM »
I believe this is caused by one float bowl overfilling, maybe a float valve 'cocked' a little sideways. When the fuel level is too high the engine vacuum will pull fuel from the main jet at idle and cause the engine to rev as if you had twisted the throttle . An air leak between the carbs and motor would do the same thing, but you say you have checked that. I would take the carbs off ( ugh ) and polish the float tabs where the float needle sits to be sure there is no' wear spot' the float needle can get stuck in, doesn't take much to upset the float needle !
Offline koendd
« Reply #8 on: April 04, 2017, 11:46:41 AM »
Well it ran fine last year with same setup. Original airbox only open 4/1 exhaust but no problems with it ladt year...
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Offline koendd
« Reply #9 on: April 04, 2017, 11:47:35 AM »
Did a synch 2 hours ago as last part of the tune up. Weren't to much out of synch though. No improvement
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Offline koendd
« Reply #10 on: April 04, 2017, 11:48:08 AM »
I did and not jammed ...
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Offline koendd
« Reply #11 on: April 04, 2017, 11:50:00 AM »
Ok maybe but only revvs when twisting throttle. Idles perfect otherwise....
Guess i'll just have to pull the carbs and check boots carbs etc as suggested... Grrr
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Offline koendd
« Reply #12 on: April 04, 2017, 02:04:16 PM »
pulled the carbs earlier.
didn't find anything disturbing. boots still in excellent condition. One float valve had a slight 'ring' so polished it with 800grit.
other then that nothing really. So will refit them tomorrow.
I did notice however there's much more tension on the spring of the return when off the bike. they don't close as fast when the cables are attached. So maybe some tweaking needed on the cables after all...
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
« Reply #13 on: April 04, 2017, 02:12:49 PM »
Aftermarket cables?  Check cable routing...no sharp bends.  Slides should forcefully snap shut.
A friends cb750 had slides that wouldnt snap shut.
Aftermarket return cable was tight(short) beyond adjustment, runs without it now with no issues.
« Reply #14 on: April 04, 2017, 02:12:58 PM »
 I had a K4 750 doing that once and all was good when I cleaned the slides/needles in the carbs,one may have been hanging up with some build-up. When was the last time your carbs were off the bike for a service ?
« Last Edit: April 04, 2017, 02:15:15 PM by ekpent »
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #15 on: April 06, 2017, 05:49:56 AM »
koendd, did you ever solve this issue?  i have the same.  although as i ride the bike more and more it improves.
cb750 k6 - ugly
Offline koendd
« Reply #16 on: April 06, 2017, 11:15:51 PM »
well maybe didn't have time for a testride yet.
I have another 750 in the shop and when you release the throttle it snaps back, mine didn't.
Have an aftermarkte cable grip so opened it up again, lubed it al again and now it snaps back as well.
Because I noticed when I would loosen the 2 bolts a bit it would snap back to...
So now that is fixed, will try to do testride tonight and get back to you ;)
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Offline evinrude7
  • not a kung-fu
« Reply #17 on: April 07, 2017, 12:37:07 PM »
Looking forward to it.
Sent from my LG-D850 using Tapatalk
cb750 k6 - ugly
Offline koendd
« Reply #18 on: April 14, 2017, 04:27:29 AM »
did a testride, no change unfortunatly...
Snaps back when not running, but when I ride it and stop to check when it's revving again it idles again with a little push on the accelerator arm on the carbs.
So defitinatly something in the carb linkeage or maybe throtlle cable has to much tension.
so I can allready rule out an airleak..
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Offline evinrude7
  • not a kung-fu
« Reply #19 on: April 14, 2017, 06:26:26 AM »
keondd, here's the list of things i plan to go over to try to solve my revving issue.  i also have a back fire issue with 1 and 3.  3 is worse.
replace advance springs, points gap, timing, vacuum leaks, tappet valve clearance -again
jet needle clip settings? fix those for stock air box
657A  floatheight26mm  main110  slow40  jn4 screw1out
service carbs again
clean all air passages in carb including air screw mixture holes.
check plug wires and boots (boots should be 10K ohms)
i did find a vacuum leak on #3 airbox boot even after i tightened the hell out of it when i finally got my stock airbox on.  over the course of 2 weeks the clamp on there was loose.  someone on here pointed out that attaching the boots then pulling the airbox back to it's attachment brackets was the way to go.
keep us posted on your progress.
cb750 k6 - ugly
« Reply #20 on: April 14, 2017, 07:07:25 AM »
do the carb slides snap back just as well with the bars turned right or left?
Offline evinrude7
  • not a kung-fu
« Reply #21 on: April 14, 2017, 03:51:50 PM »
mine do.
cb750 k6 - ugly
