Author Topic: Round 2. 76 750SS Aka Dark Lord  (Read 11309 times)
Offline BPellerine
Re: Round 2. 76 750SS Aka Dark Lord
« Reply #25 on: April 08, 2017, 05:11:10 PM »
looks like you carry your talent over to guitar building as well!bill
I do like to dabble, Sir.   :)  I build maybe 12-18 a year right now.  But paint hundreds a year.  Here are a few shots of what I am doing for a customer right now.  :)
nice work,alot of detail there!bill
1978 CB 750K ard and webers
another anfob
Offline palepainter
    • Mike Learn custom paint and airbrush.
« Reply #26 on: April 08, 2017, 05:37:14 PM »
Today, I got a few hours in on the tank.  I grafted the original F tank mount that slides in the rubber strap and made front mounts out of all thread.  I drilled the frame no far from from stock position.  Then welded up the cups cut out of old tank.  I am also making filler pieces that will be used as well to really clean up the area.
Offline Ricky_Racer
« Reply #27 on: April 08, 2017, 05:38:49 PM »
Wow! Major skills!
RR
Offline WesTenRacing
« Reply #28 on: April 08, 2017, 10:13:21 PM »
I like the "clean up" panels at the front.  That's going to be slick.  8)
Offline palepainter
« Reply #29 on: April 10, 2017, 07:07:39 PM »
The tank is pretty much tacked together and ready for final weld.  Started messing with rear tail section cut from junk Victory fender.
« Last Edit: April 10, 2017, 08:26:43 PM by palepainter »
« Reply #30 on: April 10, 2017, 09:01:05 PM »
The tank looks good.  Are you leaving the end cut square (to be filled by the seat), or are you extending the downward curve toward the subframe?
Offline palepainter
« Reply #31 on: April 10, 2017, 09:05:24 PM »
I am going to leave it square and make the transition in the pan and seat.  The one thing I learned fast with my other bike was, it is nice to be able to get tank off with least amount of work possible.
« Reply #32 on: April 11, 2017, 05:31:13 AM »
Looking good. 8)   The tail section radius may interfere with the tire's radius - visually - if it is not in the right place.  I would like to see it with the rear wheel on.
I just want to make sure you're building your bike to suit me:o
« Last Edit: April 11, 2017, 05:34:03 AM by WesTenRacing »
« Reply #33 on: April 11, 2017, 11:32:50 AM »
Your added piece, are you using cold roll or satin coat ?
I just ordered a half sheet of satin to build an oil tank.
I heard you may have to grind off the edge for welding ?
Offline palepainter
« Reply #34 on: April 11, 2017, 11:35:56 AM »
THat is just factory e coat, I will use roloc disc to clean it up before welding. The Mig works so much better when any surface is scuff IMO. I have tried that weld through stuff.  It worked, but threw off a bunch of odor.
Offline palepainter
« Reply #35 on: April 11, 2017, 07:46:25 PM »
I got an hour in this eve working tail.  I hope to hide a small battery and electronics in there somewhere.  Using stock F model oil bag.
Offline innovativems
    • Innovative MotoSports
« Reply #36 on: April 11, 2017, 09:54:41 PM »
Those flow so well!
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #37 on: April 11, 2017, 10:27:10 PM »
Agreed.  I might suggest taking a .75-1.0" of height off the seat.
Offline palepainter
« Reply #38 on: April 12, 2017, 07:59:13 AM »
I agree, I am hesitant to cut it down just yet.  I need to do some research on battery dimensions so I can make a mockup box to use with the fabrication.  Any one have any dimensions?  I am not sure I want to go with Lithium Ion battery.
Offline budman
  • 1914X
    • LeCompte Electric Bass
« Reply #39 on: April 12, 2017, 05:02:56 PM »
I used an Anti-Gravity Lithium Ion battery on my build.  It's great.  I'm pretty sure they can be installed on their sides.  There are dimensions on their website.  I made a little cardboard mockup to test fit the battery box I made.  When I got the actual battery it fit perfectly.
Bud
1973 CB750K3 Chopper
2021 Indian Scout
Offline palepainter
« Reply #40 on: April 12, 2017, 05:25:50 PM »
Thanks Bud.  I am worried a bit about the Li Ion batteries from some of the stories I have heard.  They sure are small and could be easily tucked away in the tail.  Special chargers?
Offline budman
  • 1914X
« Reply #41 on: April 12, 2017, 06:43:57 PM »
I know Antigravity sells chargers.  My battery was low from all the testing I did during the wiring.   There wasn't enough juice when I tried to start the bike for the first time.  I hooked up a small Drag Specialties charger that I won as a door prize a few years back.  After about an hour on the charger I was able to start the bike.  I haven't had to charge the battery since.  Good sign my charging system is working and the battery isn't screwed up from the charger I used.
Bud
2021 Indian Scout
« Reply #42 on: April 12, 2017, 08:33:55 PM »
Lithium based batteries are great if you need to shave maximum weight (racing) or due to space limitations.  They have tons of cold cranking amps, but you need to make sure they never fall below a certain specified threshold voltage -- if they do, they will NEVER recover their charge.  Also, you should use the special proprietary charger for them.
Offline palepainter
« Reply #43 on: April 12, 2017, 09:07:36 PM »
I have a hobby charger for my RC racing that has a LI setting.  It has a Deans connector that I could run externally and not have to remove the tail section to charge.  Will investigate further.
Offline palepainter
« Reply #44 on: April 12, 2017, 09:11:28 PM »
Any one of these particular Anti Gravity batteries you guys recommend for the bike?  Amps...etc.
This one do the job?  Appears so from info.
http://www.motosport.com/product?pssource=true&segment=badger&key=Antigravity-Small-Case-Lithium-Battery&cc=us&utm_source=Bing_PLA&utm_medium=cpc&creative=11073941556&device=c&matchtype=e
« Last Edit: April 12, 2017, 09:17:14 PM by palepainter »
Offline budman
  • 1914X
« Reply #45 on: April 12, 2017, 09:18:39 PM »
Here's the 8 Cell I'm using next to the mockup.
« Last Edit: April 12, 2017, 09:24:44 PM by budman »
Bud
2021 Indian Scout
« Reply #46 on: April 12, 2017, 10:47:28 PM »
You decided to nix the "fender" tail section for a fabbed one?   I liked the fender one.  There may not be as much room to house stuff but with the batt that Budman pictured I'm sure you'd be fine.  IMHO
Offline palepainter
« Reply #47 on: April 13, 2017, 07:32:55 AM »
Nothing is off the table at this point.   :)  I have a surplus of potential tail sections.  I still may carve one out of foam then glass.
« Reply #48 on: April 13, 2017, 09:25:02 AM »
I've run probably 8 lithium ion batteries and only had one go dead on me.  But it was my own fault for using the wrong charger.  When charged correctly, they are great.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline palepainter
« Reply #49 on: April 13, 2017, 01:17:51 PM »
Hey Bud.  What were final dimensions of your battery mockup.  Also, did you give room for rubber padding of any kind in your box?
