Author Topic: Left side cover cb750  (Read 4764 times)
Offline Keith
« on: April 08, 2017, 03:53:52 PM »
Why is it so hard to find the left-side side cover for a cb750? eBay has many r/s covers but very few left. I finally found a NOS sunrise orange cover to replace my slightly faded original. Almost ten years looking!
Offline iFart
Re: Left side cover cb750
« Reply #1 on: April 08, 2017, 04:02:54 PM »
I feel ya. I have a little broken off piece on the part that faces the airbag on the left side but can't both repairing as I think it's near impossible to paint back and not stand out.
Victory though, right? How much did it cost you?
Offline Keith
« Reply #2 on: April 08, 2017, 04:33:54 PM »
$185.00!!
Offline Airborne 82nd
« Reply #3 on: April 08, 2017, 04:36:52 PM »
What kind of airbag did yours come with :o ;D
Offline jonda500
« Reply #4 on: April 08, 2017, 04:41:15 PM »
$185.00!!
sheeeze! they must be getting very rare - sometimes you just have to pay up.. i payed $65 for an oem flasher relay!
Glad you found one, John
A starter clutch thread:
« Reply #5 on: April 08, 2017, 04:47:05 PM »
Think about it, L side needs to come off to access electrical, R side does not.
They typically get broken when being removed forcefully.
Offline Keith
« Reply #6 on: April 08, 2017, 05:15:19 PM »
Kinda what I figured, but the r/s has the hole for the oil cap and seems weaker.
Offline iFart
« Reply #7 on: April 08, 2017, 07:56:54 PM »
Damn. That's a lot of pretty pennies. Once the JB weld repair of the cracks on my covers fail they're probably going to be thousands! I should learn how to perform the Honda paint job.
You know, the airbag that runs air to the carb-a-mabobs, to the metal square vroom vroom box.
Damn autocorrect.
Airbox*
Offline iFart
« Reply #9 on: April 09, 2017, 07:49:42 AM »
So shiny. I'd never forgive myself after buying new nice ones and damaging them.
Offline Jarrett_Honda
« Reply #10 on: April 09, 2017, 09:45:30 PM »
Can't you get a blank one and paint it? Many sites sell blank covers. I'm in the same situation. My left side cover shattered when attempting to remove.
Sent from my SM-G930T using Tapatalk
« Reply #11 on: April 10, 2017, 03:15:23 AM »
I bought fiberglass covers to my K6 in early 80's. Honda OEM cracked very easy. I know since then that is not good to lean bike to the leg pressing on the cover.
The fiberglass version is very durable. Maybe not available.
Find a local painter and buy these http://www.ebay.com/itm/Honda-CB750-Side-Covers-71-76-Set-/172619009759
Offline Keith
« Reply #12 on: April 10, 2017, 04:53:07 AM »
Yes, I could have done that, but I wanted original paint to match the rest of the bike.
Offline iFart
« Reply #13 on: April 10, 2017, 07:25:55 AM »
I think it's also near impossible to match the honda paint job. I've seen kits out there. Has anyone used these with success?
Offline Geeto67
  • A grumpy
« Reply #14 on: April 10, 2017, 12:21:20 PM »
Because when the bikes were just old junky used bikes the side cover rubber would shrink and harden and then the wind on the highway would peel the left sidecover off the bike above 60mph. The right is held in by the oil cap and will bang about and eventually crack and break but won't instantly be set free to the wind. After I lost 2 that way I started buying all the left side covers I could find at swap meets and yard sales (pre-internet days). I'm sure I am not the only one hoarding these.
Maintenance Matters Most
« Reply #15 on: April 10, 2017, 01:48:41 PM »
Even if you use the same paint codes?
« Reply #16 on: April 10, 2017, 02:15:25 PM »
There are no paint codes.  Plus new paint would never match 40 year old faded paint
Offline Geeto67
  • A grumpy
« Reply #17 on: April 10, 2017, 02:23:53 PM »
yes, no, maybe. Depends how good you are. Even if you use the same paint codes some of the honda paints are "candy" paints like Candy Ruby Red and Candy Blue Green (There are 9 different candy colors across the years for just CB750s). The thing about a candy paint is that it carries the color in the clear itself instead of the opaque base coat. That means that each successive coat darkens the color's hue and depending on the base coat can change the color's tint. For example Candy Bacchus Olive is not a green paint, it is the result of Candy Gold over Metallic Blue base (or vice versa but I think that's right - let's just assume it is). Too few clear coats and the color is too blue, too many and the color shifts back to too gold but it also gets darker and harder to see the flake through. The skill is getting just the right amount of coats to emulate the factory paint.
The other problem is...does anybody know what the original color's hue and tint is actually supposed to be? paint is susceptible to fade and candy paint is twice if not more "fragile" when it comes to fade. So unless you have a NOS part that has not seen the light of day in 40 years it's hard to say what is "correct". Professional restorers struggle with "correct" hue on cars with single stage opaque laquer paints so candy paints...forget about it there is no "100% accurate replica"
Finally candy paint is subject to variation. Hondas painted on an overcast Monday may be a different shade from Hondas painted on a sunny Friday due to weather conditions and human error. So there is a "range" to get it right.
It's one of those things where close enough is good enough and honestly don't sweat it too much. As long as the bike is shiny and it's approximately the right shade you are good.
Offline Geeto67
  • A grumpy
« Reply #18 on: April 10, 2017, 02:31:53 PM »
There are "Paint codes" they are just meaningless because they belong to a company that is long out of business. Honda America endorsed a company called Lubri-tech to be the aftermarket supplier of touch-up and collision repair paint for honda motorcycles because Honda was not supplying any itself. When you see a honda paint code it's usually a Lubri-tech code. The problem is that there is no rosetta stone to translate a lubri-tech code into a PPG, dupont, or BASF paint code so it's worthless.
« Reply #19 on: April 10, 2017, 02:34:00 PM »
I know for sure that there are paint codes. My bike would MV and PB27MC for Planet Blue Metallic.
Offline Geeto67
  • A grumpy
« Reply #20 on: April 10, 2017, 02:52:30 PM »
those are colorrite paint codes. They are NOT honda factory paint codes. They were determined by color-rite matching the paint to an existing piece of bodywork, it does not correspond to anything official from honda and is completely dependent on how good a piece of bodywork colorrite used to match.
Are there paint codes? sure - anybody who has color matched is going to have a code for the paint they used.
Are there Honda Paint codes? sort of -they are technically Lubri-tech codes that were officially endorsed by Honda
Are there Honda factory paint codes that can be used to purchase a modern paint formula? No.
Close enough is good enough, or as good as you are going to get.
« Reply #21 on: April 10, 2017, 02:55:26 PM »
I think I'll get the tank and the sides covers painted at the same time so they at least match. Like you said close enough is good enough.
« Reply #22 on: April 10, 2017, 04:18:08 PM »
There are "Paint codes" they are just meaningless...
Correct, let me rephrase it:
There are no usable Honda paint codes.
Offline pjlogue
« Reply #23 on: April 10, 2017, 04:32:48 PM »
You can get a pretty close representation of original color under the tank/side cover badges.  My left side cover cracked like many others.  I tried the cyanoacrylate/baking soda method and it has held up better than I expected.  I had a crack in the upper left part and the bottom nubbin that attaches to the frame broke off.  The cyano/baking soda is damn strong!  I am VERY careful when I remove it and have silicone greased the attachment rubber to ease stresses.
-P.
Offline Keith
« Reply #24 on: April 10, 2017, 05:48:30 PM »
 The reason I needed the cover is because I entered my 750K2 in the grand national meet of the Antique Motorcycle club.  I scored 93.5 out of a possible 100 points. The faded left cover cost me half a point. Modern tires cost another point. This year I should be at 96 to 97 points. (Sunrise orange color)
