I have been working on my 75 CB550 that I picked up a few years ago and I thought I would share some of the work I have been doing. I have been wanting to do a cafe project for some time so this is my first bike project.
I am doing a few modification to the suspension and frame.
The bike was a basket case with a non-running engine and two baskets of parts.
The front forks were pooched
Started disassembly
Picked up a front off a GSXR and 19" tire off a Harley
New bearings were needed to fit the GSXR shaft.
I found a used pull-shock off a Buell
Cleaning up the shock
Powder coating the spring
Looks better
Time to work in shock mounts
Mocking up
Using some EMT for mock up
Needed a pipe bender so I picked this up.
Making some test pieces but I need to clear the header.
So I made it out of sections to get the tight bends I needed to clear the header
Front mount tacked on.
Time for the rear mount
Mocking up
Made some end links for the rear mount
Made some mounting tabs for the shock
Bent the hoop and welded on the end links
Rear swing arm done
Next will be working on the frame modifications
