Author Topic: Cylinders 1 & 2 Not firing, ideas?  (Read 1341 times)
Offline 63SSRagtop
    • My stuff and friends toys..
« on: April 10, 2017, 11:10:55 AM »
Hola all, started working on the '77 CB750 now that is finally starting to warm up some..   Bought this bike and parked it.. When I first checked it out you could tell from the exhaust it's running really rich and I do believe it was spritzing gas out the tail pipe..  loaded it up and brought it home anyways lol..
I figured it was a coil/plug problem so I went ahead and put in a pamco timing kit with coils, got it installed yesterday and I'm still dead on 1 and 2..  Ok, so put in new D8EA plugs.. same same.  Pulled out the plugs one at a time and checked for spark which it seems to be getting, new plugs had fuel on them for these two cylinders..
Suppose a compression check is next then look at the low idle side on the carbs?
Offline innovativems
    • Innovative MotoSports
Re: Cylinders 1 & 2 Not firing, ideas?
« Reply #1 on: April 10, 2017, 11:18:11 AM »
If you give it throttle do they fire?
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #2 on: April 10, 2017, 11:33:28 AM »
Not gas out the tailpipe...its condensation from not bing run for so long.
Too bad you went with an electronic ignition as this is a carb issue.
Remove and clean your carbs and clear tube test your bowls for adequate fuel levels.
Offline 63SSRagtop
« Reply #3 on: April 10, 2017, 11:44:22 AM »
Not sure what you mean here, I just pulled them and grounded against frame and they are sparking
I don't mind the electronic ignition at all, do like eliminating it as the issue.. Understand the fuel supply side is paired 1&2 and 3&4.. which is why I started thinking low idle jets.. Might explain why the guy said it ran like a scalded ape on the highway but only on the highway..
Those carbs are going to have to probably be done.. This bike for everything I can see is completely original.. even the coils looked to be the originals but she is in great shape..
« Reply #4 on: April 10, 2017, 12:25:25 PM »
Clean the carbs and perform the 3000mi scheduled maintenance.
This will take care of 90+% of the issues these bikes have.
« Reply #5 on: April 10, 2017, 12:34:43 PM »
I'm referring to with the bike running, at idle neither 1,2 is firing correct?  If you give it some throttle, do they begin to fire?  That would mean a plugged pathway in the carbs
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline 63SSRagtop
« Reply #6 on: April 11, 2017, 09:08:57 AM »
Ah I got you.. no I didn't notice them firing then either.. pipes stayed cold no matter what the throttle position was... They way the previous owner described it running fine on the highway does tend to lean that way though..  going to go ahead order carb kits.. who's the best source these days??
Offline Brian G
« Reply #7 on: April 11, 2017, 02:33:50 PM »
There was another thread on two adjacent cylinders not firing recently -
http://forums.sohc4.net/index.php/topic,163992.0.html
Lots of good ideas there.
Regards,
1975 Honda CB400F
1978 Honda CB550K
1979 Honda CBX
1969 BSA Rocket 3
1976 Kawasaki KH400
2008 Kawasaki C14 Concours
Offline 63SSRagtop
« Reply #8 on: April 17, 2017, 10:24:11 PM »
Yeah, that's money!  thanks for the link!  Didn't get a chance to mess with it this weekend, hopefully this week.. I've got clean plugs (new) with fuel on them.. I'm getting spark but to me it looked week.. only kicker is for the bike to run its gotta be on full choke..
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #9 on: April 18, 2017, 05:47:28 PM »
i'd pull the carbs, clean them and bench sync.  put them back on and see what you get.
cb750 k6 - ugly
Offline Spanner 1
« Reply #10 on: April 18, 2017, 07:40:10 PM »
'For the bike to run it needs to be on full choke '... there is your problem. Nothing to do with plugs/ ignition, need to remove the carbs and clean them by the full and proper procedure  ;). Plenty of help at the FAQ section... good luck.
Offline Deltarider
« Reply #11 on: April 18, 2017, 11:43:41 PM »
Forgive me for asking but you do know when chokeflaps are opened and closed, don't you? You wouldn't be the first...
CB500K2-ED Excel black
« Reply #12 on: April 19, 2017, 01:22:31 AM »
Start spray into carbs 1, 2 will not help? This to find if this is a fuel issue.
Skickat från min iPhone med Tapatalk
Offline DaveBarbier
« Reply #13 on: April 19, 2017, 04:25:44 AM »
Don't replace the brass with the ones in the kit you get. Clean and reuse the stock brass.
