Author Topic: Drive Chain Types  (Read 1412 times)
Wayfarer
Drive Chain Types
« on: June 02, 2005, 11:42:43 AM »
Can anyone explain how 'sealed' and 'non-sealed' drive chains differ from  the O-ring chains that I'm familiar with?  These types of chains are offered by Dennis Kirk.  TIA.
Tim
Offline Einyodeler
  • Midnight bugs taste best!!!
Re: Drive Chain Types
« Reply #1 on: June 02, 2005, 11:52:00 AM »
O-ring and X-ring are sealed chains , Standard and  Heavy Duty Standard are non-sealed.
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline Somemonkey
  • somemonkey.com
    • 1976 Honda cb550
« Reply #2 on: May 30, 2008, 11:21:32 AM »
Ok, I'm bringing this one out of the closet and dusting it off......
I'm broke and can't afford a $80 x-ring chain so Dennis Kirk is offering up a 'non-sealed' chain for under $30. Should I wait until I collect enough change from under the couch cushions to buy the $80 x-ring chain or would a $30 non-sealed chain work for my 76 550?
What's the difference between these chains besides the obvious 'sealed vs. non sealed argument'? For example, are they different widths? Does one chain make the bike go faster than the other? If I buy the non-sealed chain will it break free and wrap itself around my ankle? Will an x-ring chain allow my bike to fly?
Thanks for the help!
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: May 30, 2008, 11:23:37 AM »
An o-ring or x-ring chain could very likely wear a hole in the side of the engine case on your 550.  Stick with a standard chain if you'd rather not risk it.
« Reply #4 on: May 30, 2008, 11:24:58 AM »
The oring and xring chains have the advantage of removing unwanted metal from the side of your engine case due to their extra width, when installed on the average 550.
edit: Sometimes, I wish I typed faster.  (Or, Gordon had other things to do.  Or, I would just go do some things away from this computer. Or....)
« Last Edit: May 30, 2008, 11:27:11 AM by TwoTired »
Offline Somemonkey
  • somemonkey.com
    • 1976 Honda cb550
« Reply #5 on: May 30, 2008, 11:33:07 AM »
Well, I currently have an o-ring chain that has worn a groove in the side of the engine. I just didn't know if it would be advantageous to buy a x-ring over a standard non-sealed chain. It sounds like I'll do just fine with a non-sealed chain.
