Author Topic: Speedometer disassembly/Reassembly  (Read 1817 times)
Offline Calaya
« on: April 14, 2017, 10:09:04 AM »
I'm continuing work on my 81 CB650 rebuild and need to clean the inside of the speedometer/tachometer.  I read that the snap ring must be carefully removed in order to disassemble the units.  Can anyone provide any advice?  Is there a special tool that's needed?  Can you reuse the existing ring or is it best to buy a new one?  I appreciate any help you can give.
Tony
Offline Calaya
Re: Speedometer disassembly/Reassembly
« Reply #1 on: April 14, 2017, 10:14:12 AM »
Another question is:  Would it be best just to replace them with new (reasonably priced) aftermarket units and, if so, any recommendations / warnings / things to look out for?
« Reply #2 on: April 14, 2017, 10:22:50 AM »
You might want to move this thread to SOHC Bikes.  You might get a swifter response there.  This thread is for complete build projects.
Offline Calaya
« Reply #3 on: April 14, 2017, 11:49:37 AM »
Thanks.  Will do.  It's part of my overall rebuild project but I can see how the title is misleading.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #4 on: April 14, 2017, 01:22:24 PM »
Try this. Ignore the link in the article to the 750 gauge restoration as it is dead now. http://www.motorcycleclassics.com/black-side-down-replacing-Honda-CB-face-plates
And I think this is an acceptable place for this question although the regular board would work too.
« Reply #5 on: April 14, 2017, 02:20:55 PM »
Not to bust your chops, Danny, but http://forums.sohc4.net/index.php/topic,58514.0.html
Offline Bankerdanny
« Reply #6 on: April 14, 2017, 02:30:18 PM »
I knew there was one here somewhere
« Reply #7 on: April 14, 2017, 02:36:33 PM »
Friends don't let friends recommend Harleys. ;)
