Author Topic: Repaint '75 CB750  (Read 8280 times)
Offline PetesPonies
Repaint '75 CB750
« on: April 20, 2017, 05:40:39 PM »
Doing a repaint for a member here. Thought I would document the work. Beginning pics, 2 large dents on left side. And once the trim was removed you can see the actual color it was.
Pete's Ponies
Mustang RUSToration & Performance
Offline irish44395
Re: Repaint '75 CB750
« Reply #1 on: April 20, 2017, 06:25:19 PM »
I'll be following,
Pete
« Reply #2 on: April 20, 2017, 06:41:35 PM »
That original color was something!
Offline PetesPonies
« Reply #3 on: April 20, 2017, 08:52:17 PM »
You guys know better than me, but I believe it is Flake Apricot Red.
Pete's Ponies
« Reply #4 on: April 21, 2017, 12:43:29 PM »
Not Flake Sunrise Orange?
Offline PetesPonies
« Reply #5 on: April 21, 2017, 01:47:52 PM »
No it is definitely red.
Pete's Ponies
Offline PetesPonies
« Reply #6 on: April 21, 2017, 01:54:05 PM »
Removing paint from damaged side you can see the dents better.
All paint removed and then dents circled.7 dents, two very large and one more that is significant.
About 40 pulls using a stud welder.
Base coat of Z-Grip filler, knocked down with 40 grit on a DA.
And finally a second coat of filler, this time  a lightweight USC product.
« Last Edit: April 21, 2017, 01:55:36 PM by PetesPonies »
Pete's Ponies
Offline 77379
« Reply #7 on: April 21, 2017, 05:13:31 PM »
I think the flake apricot red was a one year only color for 1975 on the cb750. 42 years of Texas sun took a toll on that tank. So did the previous owner apparently.
Offline onetruepunk87
« Reply #8 on: April 21, 2017, 06:17:05 PM »
I'll be painting a spare tank and side covers in flake sunrise orange, from vmr, in the near future. Interested to see how yours comes out. I've painted three tanks before with good results but never used the multi step candy colors.
Offline jamesw
« Reply #9 on: April 22, 2017, 10:48:40 AM »
It's definitely flake apricot red. I've got 3 of them.
When flake red fades, it looks exactly like flake orange.
I'm getting a set of covers re done locally in flake red as well.
It's not cheap since it's a 4 stage process; base coat, sparkle, candy, then clear.
Flake red was only available in 75, along with Planet Blue.
72K-F 750 Cafe
75K 750 Cafe
75F 750 Restoration
« Reply #10 on: April 22, 2017, 11:48:21 AM »
I believe you it's red, I'm doing mine orange  ;D
Offline CycleRanger
  • No comment about being an
« Reply #11 on: April 22, 2017, 12:22:06 PM »
The two best colors! :)
My K5 was repainted with a poor imitation of Apricot. It looks more like Antares red but they did do a good job.
Offline jamesw
« Reply #12 on: April 22, 2017, 02:43:25 PM »
I couldn't agree more *thumb up*
In newbie haste last year I bought a tank on ebat thinking it was flake red...realized it was Antares when I got it lol.
72K-F 750 Cafe
75K 750 Cafe
75F 750 Restoration
Offline PetesPonies
« Reply #13 on: April 23, 2017, 03:00:26 PM »
The tank has been sanded and then slimmed again with filler. The shape is there, just some final sanding. Much of this filler will be sanded off.
Pete's Ponies
Offline PetesPonies
« Reply #14 on: April 26, 2017, 03:54:58 PM »
Bodywork is finished and the tank has been primed. A coat of epoxy primer, followed by a few of polyester primer. The poly will be blocked, to be followed by more epoxy. The final epoxy will be block sanded and then painted.
Pete's Ponies
Offline JoeCooley
  • Long time lurker, but now I'm a
« Reply #15 on: April 26, 2017, 08:48:25 PM »
Nice restoration of that battered tank. How does the inside look?
Joe in San Diego - Quick Cyles
78 CB750K 836cc Highway Racer - http://forums.sohc4.net/index.php/topic,162264.0.html
Rickman CR750 Restoration (SOLD)
Offline PetesPonies
« Reply #16 on: April 27, 2017, 03:32:42 PM »
Inside is a little rusty, solid tank though.
The blocking of the poly primer is finished and the tank has had a few more coats of epoxy. I call this paint ready. There is nothing that needs to be corrected, it just needs it's final sanding ,then paint.
Pete's Ponies
Offline Menno
  • www.tanklackieren.de
« Reply #17 on: April 28, 2017, 02:15:54 AM »
I did a couple of them. Although flake apricot red was never available in Europe a lot of customers like it very much.
Offline PetesPonies
« Reply #18 on: May 12, 2017, 03:13:42 PM »
The color is done now. I'll give it a couple days, then sand and get the tank ready for the black that gets painted on the sides and the decal along with it.
Pete's Ponies
Offline irish44395
« Reply #19 on: May 12, 2017, 04:33:08 PM »
I have got to do a little filling on my tank on my project wondering what type of filler I should get for the job are some better than others ?
Peter
« Reply #20 on: May 12, 2017, 04:39:56 PM »
That tank is beautiful Pete. How'd you pick the color?  It is stunning...
Offline PetesPonies
« Reply #21 on: May 12, 2017, 04:48:25 PM »
It's a stock color. The owner had the paint sent to me. Apricot Flake.
As for filler, not much difference between polyester fillers. I use Z-Grip as a base filler. Then for skimming on top I use a lightweight filler. Now I'm using a gold USC product for that.
Pete's Ponies
Offline CycleRanger
« Reply #22 on: May 12, 2017, 06:45:55 PM »
Stunning indeed! :o
Can you get a close up of the flake?
Offline PetesPonies
« Reply #23 on: May 12, 2017, 06:52:36 PM »
When it's out in the sun I'll get a pic. Under florescent lighting it isn't going to pop.
Pete's Ponies
Offline irish44395
« Reply #24 on: May 13, 2017, 09:52:52 AM »
Thanks Pete now I feel better about what to get
Pete
