Author Topic: K1 750 shock Idenification  (Read 1204 times)
Offline dcalvert
« on: April 23, 2017, 12:38:51 pm »
Can anyone. ID the shock from the photo? I have no clue what it is. I want something that looks stock. Wondering If these are Koni's
dcalvert
Re: K1 750 shock Idenification
« Reply #1 on: April 23, 2017, 12:41:53 pm »
Nope...Look like f bike stockers to me
Offline dcalvert
« Reply #2 on: April 23, 2017, 04:29:27 pm »
Okay not Koni's!
Thx,
D.
« Reply #3 on: April 24, 2017, 04:02:00 am »
 Or stock K shocks with the top chrome cover removed and the spring painted black. If you are doing a perfect resto the stock K1 shock is a little different then the K2 and later.
« Reply #4 on: April 24, 2017, 06:02:30 am »
F shockers, lowering kit, custom chain guard, 16? inch wheel, exhaust bracket welded to frame, so lots of non-original stuff. Sweet! ;D
Offline Kevin D
  • SE Michigan
« Reply #5 on: April 24, 2017, 01:49:44 pm »
I removed my K1 OE shocks a couple years back and replaced with Hagons, chrome body, chrome spring, polished cover is a bit shorter than the OE cover.  You might be able to swap the covers, I don't know if any custom work is required to do so. The black piece is some kind of plastic spring guide to keep the spring off the body. That might swap out as well, but I am not a slave to detail.
 Tha Hagons are good, probably sprung a bit stiff. The OE shocks are shot.
2012 purchase from Dave Quinn $351
Sorry about the sideways picture.
« Last Edit: April 24, 2017, 01:58:19 pm by Kevin D »
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #6 on: April 24, 2017, 01:58:51 pm »
 As seen in Kevin's picture the k1 stock shock has a black inner body and black top mount only used the first couple of years.
Offline dcalvert
« Reply #7 on: April 24, 2017, 06:54:33 pm »
Good call Terry, all the comments you mention are on the to do list. Just starting out on this project and my goal is to bring it back to stock. Not a perfect restoration but a good rider the resembles the on I had 42 years ago.
Dcalvert
« Reply #8 on: April 24, 2017, 07:00:51 pm »
Dcalvert
Good job mate, I'm in the process of doing something similar with my 1969 K0, but I'm guessing yours will be an easier task! ;D
Offline dcalvert
« Reply #9 on: April 25, 2017, 06:41:58 pm »
Wow that's an ambishous job. Lots of work and $$$. I feeling pretty good about my project now!
One piece at a time.
D...
« Reply #10 on: April 25, 2017, 07:59:00 pm »
Ha ha, I've started a build thread mate, it's not gonna be a concours resto, more like "Barn Fresh" as I'll be using lots of good original used parts rather than kill it with new chrome and paint. It'll even have some period mods............ ;D
http://forums.sohc4.net/index.php/topic,165263.msg1908670.html#msg1908670
« Reply #11 on: April 26, 2017, 12:24:52 am »
Ir can be done rather easy by order new parts. But that cost a lot. Finding fresh parts of correct years  for low $$ must be the hardest....
