Author Topic: intake o-rings  (Read 3980 times)
Offline evinrude7
  • not a kung-fu
  • something to hüsker
intake o-rings
« on: April 25, 2017, 06:51:06 PM »
where to buy?  common size had at auto parts?
cb750 k6 - ugly
Offline Ridem32
Re: intake o-rings
« Reply #1 on: April 25, 2017, 07:00:57 PM »
I bet a good hardware store can match them up. Try ACE
Re: intake o-rings
« Reply #2 on: April 25, 2017, 07:25:57 PM »
Why take a chance with some yahoo trying to "match them up"?
Why not just buy the proper, high quality Honda part? To save a buck?
Offline riverfever
Re: intake o-rings
« Reply #3 on: April 25, 2017, 07:36:02 PM »
I agree. While it might work, it would suck to be chasing an issue and then second guessing if what you thought would work is actually working.
Offline Ridem32
Re: intake o-rings
« Reply #4 on: April 25, 2017, 07:36:41 PM »
Not trying to save a buck.  He just ask a question.
Offline Ridem32
Re: intake o-rings
« Reply #5 on: April 25, 2017, 07:38:20 PM »
O ring is either metric or standard.   Honda don't make o rings
Offline Ridem32
Re: intake o-rings
« Reply #6 on: April 25, 2017, 07:48:12 PM »
That's a o ring for a 1977 Honda cb400f. Note the Honda part #. The look at the size. Can be bought by size and not Honda part #.
Offline evinrude7
  • not a kung-fu
Re: intake o-rings
« Reply #7 on: April 25, 2017, 08:15:27 PM »
well i think my question was fairly straight forward stev-o.  tell me where you got yours.  what size are they and is there a part number?  i ride a 76 750.
cb750 k6 - ugly
Re: intake o-rings
« Reply #8 on: April 25, 2017, 08:50:46 PM »
 Where exactly is the location your wanting to use these o-rings on the 750 intake ?
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: intake o-rings
« Reply #9 on: April 25, 2017, 11:39:34 PM »
+1 Local honda dealer might have some on hand.
Offline evinrude7
  • not a kung-fu
Re: intake o-rings
« Reply #10 on: April 26, 2017, 07:08:09 AM »
after the carb boots. the stub outs on the head.
cb750 k6 - ugly
Re: intake o-rings
« Reply #11 on: April 26, 2017, 07:33:23 AM »
There is no oring there on a 750 [550 has em]
I thought you meant the intake valve tappet cover part # 91302-001-020  $2.42
http://www.partzilla.com/parts/detail/honda/HP-91302-001-020.html
Offline evinrude7
  • not a kung-fu
Re: intake o-rings
« Reply #12 on: April 26, 2017, 07:55:43 AM »
Hmm I was under the impression that was a place where vacuum leaks could occur. After the carb holders.
Sent from my LG-D850 using Tapatalk
cb750 k6 - ugly
Re: intake o-rings
« Reply #13 on: April 26, 2017, 08:15:27 AM »
Use the fiche, man!  ::)  ;D  helps everyone know what part we're talkin'bout.
Viton o-rings can be bought cheap at theoringstore.com with the size listed on the fiche, or directly thru a honda dealership if you have the part #
https://www.cmsnl.com/honda-cb750-750-four-1976-cb750k6-usa_model494/partslist/
Offline Ridem32
Re: intake o-rings
« Reply #14 on: April 26, 2017, 09:04:15 AM »
@flybox.  +1
Offline drumstyx
Re: intake o-rings
« Reply #15 on: April 26, 2017, 12:03:33 PM »
I never even managed to get those intake spigots off -- I assumed they were some kind of special case with permanent threadlocker or something. I doubt MRieck removed them when he did my head either. I don't think it's something to worry about.
Offline evinrude7
  • not a kung-fu
Re: intake o-rings
« Reply #16 on: April 26, 2017, 01:50:40 PM »
I looked thru that fiche fly. The view is sorta whack with it being at the back of the picture.
cb750 k6 - ugly
Re: intake o-rings
« Reply #17 on: April 26, 2017, 02:02:21 PM »
well...which one was it?  ;D
Offline Ridem32
Re: intake o-rings
« Reply #18 on: April 26, 2017, 02:03:22 PM »
The carb boots clamp to the stub outs on the head no oring.  You can still buy new OEM boots from Davidsilverspares.com
Offline evinrude7
  • not a kung-fu
Re: intake o-rings
« Reply #19 on: April 26, 2017, 02:28:23 PM »
I was thinking there was an o-ring behind the stub out on the head. 76 750.
cb750 k6 - ugly
Offline evinrude7
  • not a kung-fu
Re: intake o-rings
« Reply #20 on: April 26, 2017, 02:30:29 PM »
Guess not on the 750. The 550 does?
cb750 k6 - ugly
Re: intake o-rings
« Reply #21 on: April 26, 2017, 02:36:37 PM »
Yes on the 550.  no on the 750
Offline evinrude7
  • not a kung-fu
Re: intake o-rings
« Reply #22 on: April 26, 2017, 02:42:59 PM »
Gotcha.
cb750 k6 - ugly
Offline turboed13b
Re: intake o-rings
« Reply #23 on: April 26, 2017, 10:31:07 PM »
Harbor freight has every size of oring you will need.
Re: intake o-rings
« Reply #24 on: April 27, 2017, 04:21:24 AM »
I checked out one of those cheap kits but seem to remember that some specific sizes I needed for a 750 engine were not in the kit. Found a good seller on E-bay and ordered the specific sizes I needed for the engine and carbs. That kit is handy though to have around the shop I'm sure.
