Author Topic: 1977 CB550K Engine # and VIN Are Different?  (Read 1024 times)
Offline cb_n00b
« on: April 26, 2017, 04:08:58 PM »
So I strangely never noticed this before, but the VIN on my 1977 CB550K is CB550K-2010964, but the number on my engine is CB550E-2010955.
Is this normal? I know the K and E are supposed to be different, but does this mean that my bike doesn't have the original motor in it? Just trying to figure out if my bike had the motor swapped at some point in its life.
Thanks as always! I can provide pictures if needed.
1977 CB550K
- MotoGP Werks Exhaust / Stock Airbox
- Dyna S Ignition & Coils
- Motogadget M-Unit Blue
- 069A CB550F Carbs
- Beringer front brake kit
Offline calj737
  • I refuse...
Re: 1977 CB550K Engine # and VIN Are Different?
« Reply #1 on: April 26, 2017, 04:15:52 PM »
They do NOT match from the factory. Not on any SOHC. You're fine. the VIN and engine serial tell you the year in which they were made, not which frame had which motor. The VIN tag and the neck should always agree (etched into he right side is the correct frame VIN).
Offline cb_n00b
« Reply #2 on: April 26, 2017, 04:16:46 PM »
A couple of pictures just to clarify:
1977 CB550K
- 069A CB550F Carbs
Offline cb_n00b
« Reply #3 on: April 26, 2017, 04:18:23 PM »
Appreciate the insight Calj...I finally have my bike purring really well and running like a top, I was starting to worry I had a frankenstein or something. Thanks again.
1977 CB550K
- 069A CB550F Carbs
« Reply #4 on: April 27, 2017, 07:00:41 AM »
Very few bikes have VINs as close as yours are.
« Reply #5 on: April 27, 2017, 07:23:59 AM »
Yep- yours are closer than normal.
