Author Topic: Gears not shifting properly on my CB750K3  (Read 808 times)
Offline Northern Flyer
  • 1973 CB750K The Precious
« on: April 26, 2017, 08:59:00 PM »
Hoping someone can shed some light on this.
The engine is out of the bike on a stand and I've only removed the side covers, oil pan, valve cover, etc for cleaning. I had also removed the neutral switch and had difficulty reinstalling it because the "gearshift drum" was inwards too far - I could see a "shoulder on the drum through the hole for the neutral switch that was preventing the switch from seating all the way. I used a screwdriver to pry the drum outwards slightly so that the neutral switch seated properly.
I then put on the shift lever to try the gear changes and found that some gears would not fully engage; the "stopper" would not seat between the "rollers" on the end of the drum. I then noticed that there seems to be a fair amount of backlash in the drive shaft that the sprocket attaches to and that if I put a little rotational pressure on the drive shaft, then the gears would change properly.
It appears to be about 1/2 a spline of backlash on the drive shaft - is this normal (engine has about 35K on it to the best of my knowledge).
I did drive the bike around the block when I bought it before taking it apart and never noticed any issue with gear changes at the time.
Any help or information would be appreciated, thanks.
Re: Gears not shifting properly on my CB750K3
« Reply #1 on: April 27, 2017, 04:28:28 AM »
 Usually turning the rear wheel or the countershaft sprocket will help it shift into gear if not rolling /running. Can't really comment though on what you are feeling with confidence.Might very well be normal.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #2 on: April 27, 2017, 04:58:09 AM »
All sounds normal to me.
There's a video out there somewhere of someone bench testing their motorcycle trans (i think it was a CB) using a drill to keep things "rolling".
As far as a bit of "slop" in the sprocket, that is normal.
--Evan
1975 CB750K "Rhonda"
« Reply #3 on: April 27, 2017, 06:51:47 AM »
Cases need to be mated to prevent this.
If it shifts thru the gears with sprocket rotation, carry on.
