Author Topic: New build, who dis? 76' CB550K Build  (Read 5297 times)
Offline rocs
« on: April 26, 2017, 09:09:04 PM »
Picked up this 1976 CB550 from some guy who had it sitting in his barn for 30 some odd years. Trailered it home from New Jersey with a buddy to give him something to do to keep his mind off his woman problems. Needless to say he took it all apart and lost interest in it before he even started putting it back together.
So now i Have a Frame, engine, and a few boxed of nuts and bolts and other motorcycles parts. The entire bike is there as you can see it was a complete bike in the pictures. I just have to figure out what goes where and put it back together. Plan is to keep it as cheap as possible but make it look decent. Ill also be trying to use all parts I've had laying around accumulating dust in the shop the past few years. So far i have $500 into this as thats how much i have him for the "Bike in a box".
Bike build plans:
 - Weld rear frame hoop
 - De-tab frame and remove center kick stand
 - Prep, Prime and then paint frame with Rustoleum Appliance Epoxy Black paint
 - Paint front forks and wheels semi gloss black
 - Find a wiring diagram and rewire entire bike while trying to hide as much wire as possible.
 - MotoGP Works Four into 1 stainless exhaust system (Pulled this from a bike i bought a while back)
 - Billet Aluminum top triple tree (Bought this off a guy on instagram)
 - Henry Abe Breadbox filter (http://forums.sohc4.net/index.php?topic=144402.0)
 - Cheap eBay Clip-on's
 - Possibly try and find a set of modern CBR controls. (Anyone have any suggestions?)
So to start, heres the bike on Day 1. We had her running about 4 hours later (Including 1.5 hour commute home HA). Friends suggested I kept the bike as is because of how rad it looks but it wasn't mine initially and my buddy had other plans for it.
« Last Edit: April 26, 2017, 09:14:35 PM by rocs »
1975 CB550k's
Offline rocs
Re: New build, who dis? 76' CB550K Build
« Reply #1 on: April 26, 2017, 09:17:41 PM »
Heres the frame and the engine on the left as it was when i got it. Everything else is in boxes.This is probably about 5 months ago.
« Last Edit: April 26, 2017, 09:55:54 PM by rocs »
1975 CB550k's
Offline rocs
« Reply #2 on: April 26, 2017, 09:57:01 PM »
Found this guy advertising on Craigslist. I think I'm gonna give him a call and bring the frame to him to have a seat made
http://www.vintagesykles.com/home.html
Anyone know of him?
1975 CB550k's
« Reply #3 on: April 26, 2017, 10:33:23 PM »
Never heard of him, but his prices are cheap.
Online calj737
  • I refuse...
« Reply #4 on: April 27, 2017, 03:23:58 AM »
The seats look nice, but they appear to be really thin gauge sheet. That makes the shape easy to create, but makes the seat very delicate to being deformed by pressure upon it. The hard brake line in the seat pan edges should be radiuses, not broken at a 90* to better conform to round hoop tubing as well.
Looks like nice work, but those are my snooty criticisms  :o For $110 though, easy enough to afford a replacement!
Offline rocs
« Reply #5 on: April 27, 2017, 05:49:34 AM »
Hes local to me so maybe ill see if he will let me swing by with the bike once its a roller. If i do use him, ill be sure to let you guys know.
1975 CB550k's
Offline rocs
« Reply #6 on: April 27, 2017, 06:03:49 AM »
Heres som shots wrestling with the engine and frame. The bottom front frame bolts seized and had to be cut out.
1975 CB550k's
Offline rocs
« Reply #7 on: April 27, 2017, 07:08:41 AM »
Some engine prep pics before paint and after. I must've done 10 rounds of degreasing. I used all sorts of degreasers but my favorite by far is Mineral Spirits. Watched a video on youtube of a guy using it on a transmission bell housing. I was amazed.
I used VHC's cast aluminum paint after using a high temp primer. Did a few engines like this in the past and worked out well. I will be polishing all of the engine covers.
1975 CB550k's
Offline rocs
« Reply #8 on: April 27, 2017, 07:26:41 AM »
BTW, if anyone sees anything I'm doing wrong please let me know! Ive only been at this stuff for about 3-4 years.
Youtube educated.
1975 CB550k's
Offline Jnel
« Reply #9 on: April 27, 2017, 06:06:47 PM »
I have a 750 agnd the engine was pretty bad with oxidation.   What did you use to get in there a clean up the fins?  Looks good.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Offline Jnel
« Reply #10 on: April 27, 2017, 06:11:52 PM »
Like you devise to hold the engine. Look similar to my contraption.
« Reply #11 on: April 28, 2017, 08:59:00 AM »
Vaporblasting. Restocycle.com
Offline rocs
« Reply #12 on: April 28, 2017, 10:34:42 PM »
I used this 20 pc engine brush kit from harbor freight. Worked great for me. I hooked it up to my drill gun
http://www.harborfreight.com/engine-brush-kit-20-pc-69020.html
1975 CB550k's
Offline Jnel
« Reply #13 on: April 29, 2017, 04:23:11 AM »
Sweet.... thanks for the info. I would love to have it blasted,  but i have a budget
Offline Jnel
« Reply #14 on: May 04, 2017, 04:01:40 PM »
Rocs... i tried to find this at HF.  No luck.  But.... at Wal-Mart, the have a similar product.  But... no luck, out of stock.  But....  while i was there i roamed thru the gun department.... bingo!  Great assortment of bore cleaning brushes.  Under $2.00 each.  Worked great on the drill.  Just like you said.  Great tip bro.
Thanks,
John
Offline rocs
« Reply #15 on: May 09, 2017, 06:26:54 PM »
@Jnel If i remember correctly the brush kit is in the same aisle as the paint brushes etc. Either way I'm glad it worked out for you. Hun department at Harbor Freight?!? Ok now your store has one up on mine  8)
1975 CB550k's
Offline rocs
« Reply #16 on: May 09, 2017, 06:50:46 PM »
I got the engine mounted with all new stainless nuts, bolts, washers etc. I used my micrometer to measure and ordered off of bolt depot.com. Their shipping was fast and prices were cheap. I probably got all of them for under 25 bucks (not including axles).
Rear shocks are some old Koni shocks i found on an other biked i picked up. I cleaned them up and freshened them up a bit with some paint. I don't think these will be "usable" shocks when the bike is finished but they are fine for now while assembling.
Will be mounting the front forks and wheels next.
« Last Edit: May 09, 2017, 06:52:19 PM by rocs »
1975 CB550k's
Offline rocs
« Reply #17 on: May 09, 2017, 06:54:48 PM »
Freshened the stock rotor up and installed the wheels tonight.
Tires are AVON Roadriders
90/90/19 fronts
120's in the rear
« Last Edit: May 09, 2017, 06:57:04 PM by rocs »
1975 CB550k's
Offline rocs
« Reply #18 on: May 09, 2017, 06:55:54 PM »
Wasn't planning on using this tank but damn does it look good.
1975 CB550k's
Offline SF
  • I burn gas very well
« Reply #19 on: May 09, 2017, 08:13:14 PM »
Looks great man......the koni's can be rebuilt
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
« Reply #20 on: May 09, 2017, 08:43:24 PM »
Agreed!
Offline rocs
« Reply #21 on: April 15, 2018, 02:35:43 PM »
Its been a while since ive updated this post. Ive done some small things here and there but started giving it more attention the last month. I am going for a more modern touch so ill be adding some new controls, levers and LED headlight. Ive since added some clip on's and the Motoworks GP exhaust pipe.
I also started wiring the bike last night. Going to hide everything under the seat and mount the battery behind the engine.
I also picked up a digital speedometer/tachometer i am going to try and install.
Now for some updated pictures
1975 CB550k's
Offline rocs
« Reply #22 on: April 15, 2018, 02:38:12 PM »
The speedo isn't installed yet but i have it sort of mocked where i think i want it. The controls, grips, levers etc are not in their final position. I am going to place everything where i want them and trim the clip ons if needed.
1975 CB550k's
« Reply #23 on: April 15, 2018, 03:14:33 PM »
 Those aluminum seats are the most basic simple form possible.
 Any one could makevtgat with a cheap brake and bending a piece over a log or pipe or post. The hard part is the welding.... no shrinking, stretching or panel beating..
 You get what you pay for.l
Offline riverfever
« Reply #24 on: April 15, 2018, 03:28:02 PM »
My god this looks tasty. That tank is gorgeous.
