Author Topic: K3 rear turn signals (winkers)  (Read 2160 times)
Offline MauiK3
  • A K3 is saved
  • Old guy
« on: April 26, 2017, 09:58:36 PM »
Hi all
On my slowly started project to restore my K3 I just worked through a problem. I bought new rear turn signals and mounting clips, they have the ground wire riveted to the clip. Right away I had an intermittent ground. I narrowed it down to the rivet. I drilled it out, cleaned off the paint, tapped the hole 8-32 and made a short screw to assemble it with. Works like a charm. I know it's not stock but NOS parts are hard to come by and I need to get the bike inspected.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline calj737
  • I refuse...
Re: K3 rear turn signals (winkers)
« Reply #1 on: April 27, 2017, 03:28:16 AM »
...tapped the hole 8-32 and made a short screw to assemble it with. Works like a charm.
Imperial threads on a metric bike!  :o Have you lost your mind? Do you know what horrible demons you have just embedded into your bike? Best get 2 Angle Bells before you ride that cursed thing now-  ???
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #2 on: April 27, 2017, 09:10:42 AM »
I know, I thought about that but at the time I had the screws. At some point I am going to re-order the clips and maybe I won't have to do the mod, or if I do, I'll go get some metric screws. For good luck I have my lucky rucksack on the rack, been using it for many years.
1973 CB 750 K3
