Author Topic: Need Some Yamaha Help - Cluth Question  (Read 1337 times)
Offline RRRToolSolutions
  • I love old Japanese bikes!
« on: December 14, 2006, 07:33:47 PM »
Guys, can someone tell me why the old Yamaha XS650 (pre- 1974) had 4 fiber/fiber friction disc and 2 fiber/aluminum friction disc?
I've been putting some final touches on my 1973 TX650 Yamaha. 3-4 months ago I replaced the old, original 5/6 plate steel/fiber clutch with an aftermarket 6/7 steel/fiber one. The original design is no longer available from Yamaha. I've never been happy with the aftermarket set-up (MikesXS). It grabs, it chatters and just doesn't release during shifts and it's not Mike's fault - it's just the throw-out is not enough to give adequate spacing when the lever is pulled. The original one came with 5 rubber cushions (almost like 4" diameter o-rings) which help to seperate the fibers and steels when the lever is pulled, but these won't work with the newer 6/7 set-up due to spacing. The old style fibers are .140 thick while the newer style are .119. I've spent a crazy amount of money to buy all of the NOS pieces from an old inventory specialty dealer, but my 6 fibers are all fiber/fiber frictions. Yamaha hasn't had these in many years, but the parts fiche shows them superceded to the same part. They aren't - 2 of the plates were originally fiber bonded onto aluminum. My dumb self threw the old fiber/aluminum frictions away months ago. They had been sitting since 1981 and several crumbed in my hand during separation from the steels.
Do I put the $24 a piece fibers in there and risk them coming apart? What does the 2 fiber/aluminum frictions have to do with the set of 6?
Sorry to post this Yamaha question here, but these answers aren't in the book. I'm hoping some here were mechanics in the day and know why it was done the way it is. If you think about it, those 2 aluminum plates don't work unless the other 4 are there. If the fiber/fiber was going to shatter or fail, the 2 remaining plates aren't going to work/hold either. I'm lost.
Thanks,
Gordon
« Last Edit: December 14, 2006, 07:39:49 PM by Ilbikes »
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
Offline medic09
Re: Need Some Yamaha Help - Cluth Question
« Reply #1 on: December 14, 2006, 08:03:14 PM »
Gordon,
Wish I knew your answer.  Just wanted to complement you on your nice looking ride, there.
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #2 on: December 14, 2006, 08:10:19 PM »
Gordon,
        I just wanted to add an AMEN to what the medic said. That is one nice looking Yam 650. Wish I had your answer. Maybe PJ (crazypj) or Daniel (dgfischer) does.
                                                     Later on, Bill :) ;)
Member # 1969
Offline crazypj
  • I'm brill, me
« Reply #3 on: December 15, 2006, 06:47:20 AM »
I don't have experience of the 'early' models but I can direct you to somewhere where someone will know
 They are specific in location, either out side or inside where heat build up is greater?
All the later plates as far as I know are alloy/friction material, maybe someone has swapped a few over the years?
http://xs650temp.proboards29.com/index.cgi?
Bike looks great BTW
PJ
« Last Edit: December 15, 2006, 06:50:40 AM by crazypj »
