Author Topic: Cut my chain three times and it's still too short!  (Read 1884 times)
Offline DaveBarbier
« on: May 06, 2017, 12:27:13 PM »
Decided to venture out of the safety of my build thread for this one.
So I just cut my DID 520 x-ring chain one link too short like a moron. What are my options?
This is how the chain is right now:
This is what I have left over:
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Cut my chain three times and it's still too short!
« Reply #1 on: May 06, 2017, 01:03:20 PM »
Can you run the rear wheel farther foward on the swing arm?
Otherwise you're looking at having to reinstall that link the hard way.  Riveting the thing back together is a chore.
Offline eigenvector
« Reply #2 on: May 06, 2017, 01:28:43 PM »
I've done that before on my old Tiger 1050 - re-riveting some back onto the chain IS a pain.
Having done that - if it was me I'd just buy a new one.  I value my time way more than the cost of a new chain.
Maybe you can find a 2nd tie plate set and then it's not such a pain to splice on additional links.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Online PeWe
« Reply #3 on: May 06, 2017, 01:45:14 PM »
One more master link to make chain longer. Before that you need to make it 2-3 links shorter and add a correct series of links with the 2 master links.
Offline DaveBarbier
« Reply #4 on: May 06, 2017, 02:10:26 PM »
I can't move my wheel any closer unfortunately, that's the first thing I tried.
At first it seemed like just riveting a new pin in would be a simple thing to do, but I guess not...
I have thought about getting another clip master link, cut the chain again a few links down and then reassemble with the correct number of links. I just wanted to be sure this was an ok thing to do.
And yeah, eigenvector, I have the same chain in my cart on eBay if all else fails, haha. But that's $73 I don't feel like spending.
Looks like the additional master link is my best, cheapest bet?
Offline DaveBarbier
« Reply #5 on: May 06, 2017, 02:14:07 PM »
These new master links are cheap. Under $10 shipped. Is a rivet master link a better more permanent option? Yes, I'd then have to get a rivet tool.
Offline eigenvector
« Reply #6 on: May 06, 2017, 02:15:07 PM »
I think so.  Pretty ugly hack, but just make sure you don't cut it short again - or you might have nothing but master links for a chain.   ;D
Rob
1977 CB550K
1983 VF750S Sabre
Offline DaveBarbier
« Reply #7 on: May 06, 2017, 02:27:50 PM »
Sounds link a plan. That would be pretty funny to have all master links, haha.
Now, I could easily weld the master link instead of using the clip. Frowned upon?
Edit: eh never mind. Don't want to take the temper out of the link.
  • Holy Cow! I'm a
« Reply #8 on: May 06, 2017, 02:37:51 PM »
You could peen a master link.
« Reply #9 on: May 06, 2017, 02:47:38 PM »
Welding an x ring or o ring chain would unlikely let the rings or sealed in grease survive such extreme temps.  Don't cha think?
Online PeWe
« Reply #10 on: May 06, 2017, 02:51:36 PM »
The chain must keep up with its task. It can cost if it snap. Only extension I should trust is with riveted master link and a good tool doing it with.
Offline DaveBarbier
« Reply #11 on: May 06, 2017, 02:53:18 PM »
Thought about that, but I was thinking a couple quick tacks wouldn't hurt anything. Either way, I'm not going to try and find out.
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #12 on: May 06, 2017, 02:57:21 PM »
Not sure I get the title. Do you mean when you cut it two times it was too long?
I've used half links to overcome that scenario on my Pommie sh1tboxes before, but can't recall ever having the same problem on a Jap bike.
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline DaveBarbier
« Reply #13 on: May 06, 2017, 03:09:57 PM »
Agreed. I ordered the rivet master link for $9. I'll have my buddy at a shop rivet it for me for a 6 pack of brewskies.
Offline DaveBarbier
« Reply #14 on: May 06, 2017, 03:14:12 PM »
Thought brits had a good sense of humor? :))
It's a Polish carpenter joke. I applied it to my chain scenario due to the fact that it dealt with something that is now too short after me cutting it.
Offline Jnel
« Reply #15 on: May 06, 2017, 04:48:12 PM »
I got it... that was funny.  Master link number two coming up.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Online carnivorous chicken
« Reply #16 on: May 06, 2017, 05:36:37 PM »
This.
Offline DaveBarbier
« Reply #17 on: May 06, 2017, 08:12:38 PM »
I still find it strange that I couldn't just get a single solid rivet, push it in and peen it over and be done with it. Is it a limitation of proper tooling? The factory rivets that are in the chain are much more robust than the ones you and I can get?
Offline eigenvector
« Reply #18 on: May 06, 2017, 10:14:46 PM »
No, they aren't more robust (or at least I don't think they are).  You had to split the chain to shorten it - so clearly they can't be super tough.
If you can find a pin to fit in the link go for it.  I could never locate one though.
Rob
1977 CB550K
1983 VF750S Sabre
Online PeWe
« Reply #19 on: May 07, 2017, 12:04:32 AM »
Solid rivet link is PITA to rivet. The chain I have on now has solid master link. I had to buy a really good tool to rivet it, WHALE. Complete kit for solid, hollow links and a cutter, all has it own add-on. It is recommended to grind end off before using the cutter.
DC chain has now replaced the solid link with hollow rivet link. It is only hollow in the ends where it will be riveted.
I'll use spacers next time I'll rivet a chain. It is easy to over rivet and links will be too tight forming a Z. Same distance as the other links have.
Offline DaveBarbier
« Reply #20 on: May 07, 2017, 04:26:06 AM »
I wasn't aware that the hollow rivets were actually only hollow for the rivet portion. That makes sense and seems like a fine alternative. At least manufacturers think so, haha. Thanks guys, I ordered the rivet master link. I won't be making this mistake again!
Offline eigenvector
« Reply #21 on: May 07, 2017, 07:05:34 AM »
Yes you will, don't give us that garbage.   ;)
Why do you think I ride shafties now!
Rob
1977 CB550K
1983 VF750S Sabre
Offline DaveBarbier
« Reply #22 on: May 07, 2017, 07:15:22 AM »
You're right, I'll probably do the same thing in a month.
