Author Topic: Terry Bob's redneck F-ing K2 bitsa project!  (Read 218214 times)
Offline johno
Re: Terry Bob's redneck F-ing K2 bitsa project!
« Reply #1575 on: March 31, 2021, 04:01:54 AM »
oops, had too many covid stress relief drinks, I meant to say;
Bloody hell Per, no wonder you need a 100 hp big bore kit to lug all that around
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
« Reply #1576 on: March 31, 2021, 04:11:23 AM »
Yep, that's a days worth of food for me, at least! ;D
« Reply #1577 on: March 31, 2021, 06:56:12 AM »
Ha-ha!
Not everyday ! ;) Holidays only, brunch! ;)
Now when working, mostly oats porridge or hard bread with butter, caviar, sliced egg and a good cheese like a cheddar type.
Sometimes 2 large fried eggs with bacon on 2 slices of bread from toaster to pan absorbing all tasty bacon grease. Ketchup and chilli powder. A large coffee to that.
Or a 2 large eggs omelette with sandwich.
TV breakfast ! My daily office when not wrenching, riding or sleeping or shopping the essential. Bike parts shipped to me or a close pick-up place.
« Reply #1578 on: March 31, 2021, 01:49:08 PM »
That’s some good looking food Per, you’ve made me hungry just looking at it! I’m liking the look of the K2 bitsa so much at the moment I can’t decide if I want to put the Lesters on it, or on my K1? I rebuilt a master cylinder and another caliper yesterday in anticipation of a twin disc installation, but need to decide which way I want to go. Decisions, decisions...... ;D
« Reply #1579 on: March 31, 2021, 09:53:02 PM »
It look good , Terry.
If it handles well, just ride it. Wrenching time can be replaced by riding time and a riding meal ;D
I remember now that hot sandwich was the favourite around here in the 70's, early 80's at biker and truck stops.
« Reply #1580 on: April 04, 2021, 06:09:16 AM »
So Thursday April the 1st (April fools day) was my last day in the office last week. I love my new work regime, 3 days in the office, and two days working from home. That will save me around $150 AUD ($100 USD) a week in fuel, tolls, parking, coffee and lunch, that I can spend on bike parts. Bargain! As much as I wanted to get out and ride my bike yesterday, I wanted to do some "improvements" including a twin disc front end (with drilled cast iron discs, new organic brake pads, braided lines and a Yamaha "Brembo" MC from an FJR1300.
Now I'm back in the office, I start at 6am, and by 8 I'm hungry. On my second day back I tried eating "Saltana Bran" That was only 6 months out of date, but the carboard box was tastier than this sh1t, so I elected to go across the street to my favourite breakfast restaurant. The young guy behind the counter recognised me and remembered my order, which was amazing since I hadn't been there in 13 months? Regardless, I had the best breakfast in a year. I could only manage half of it, and that took me an hour to get down, but it was on the company dollar, and I loved it.
K2 Bitsa twin disc front end 2 April 2021 2 by Terry Prendergast, on Flickr
Anyhoo, man can't live on delicious breakfasts and work alone, so as soon as I got home I started looking for parts for my twin front disc conversion. The key item is either a modified K1 to K6 speedo drive, or even better, a K0 one. it only took me an hour or so of ratting thru tubs and crawling under my work bench before I located one.
K2 Bitsa twin disc front end 2 April 2021 3 by Terry Prendergast, on Flickr
K2 Bitsa twin disc front end 2 April 2021 4 by Terry Prendergast, on Flickr
Mine was slightly mangled due to a PO not installing the speedo drive into the gearbox before cranking it down tight, but I used an ancient device only known to our forebears called a "file" to clean up the burrs and make it taskworthy again.
Even though I had a new slightly used cast iron drilled rotor I opted to use two "virgin" rotors with new organic "Metal Gear" pads. I used the same pads in my K0 and am impressed that the more I use it the better the front brake works. (for a CB750)
K2 Bitsa twin disc front end 2 April 2021 9d by Terry Prendergast, on Flickr
K2 Bitsa twin disc front end 2 April 2021 9a by Terry Prendergast, on Flickr
I bolted on the new rotors with longer (120mm) grade 8 bolts. It's important that if you're doing this you use bolts with a longer shaft so that you don't have the threaded portion bearing the load, for fear of snapping them off. Yeah, it'll probably never happen, but it only has to happen once, to spoil your day.
K2 Bitsa twin disc front end 2 April 2021 6 by Terry Prendergast, on Flickr
This is the abridged version of what really happened, I also discovered that I had a blown fork seal, so after degreasing everything to remove the old oil I had to remove both legs and replace both seals, but that's OK, I wanted to remove the engine oil I used in 2017 when I was 120 pounds heavier and needed stiffer front forks. I also discovered that air forks are the best for removing old fork oil when I forgot to deflate them before undoing a drain screw, and spraying 250 ml of oil in a 6 foot jet up my driveway. "Clean up in aisle 3!"
I replaced the (now empty) forks with 250ml of ATF. Apart from that, I also broke a 6mm screw off in one fork leg, so had to drill it out using the small/bigger/biggest drill bit method but couldn't save the OEM thread so installed a thread insert with some loctite, and all was well. It's important when you do this conversion you use bolts with fairly shallow heads, or else the heads will come into contact with the speedo gearbox and destroy it. I've done this conversion many times over the years, but there are still things I forget. Well, maybe that's because I'm old and senile.
K2 Bitsa twin disc front end 2 April 2021 9c by Terry Prendergast, on Flickr
I used a nice caliper with slightly tired OEM paint for my new caliper, and of course it was a K1-early K2 item, which is fine, except that the "swingarm" bracket on the early calipers don't work with the later brackets, so I ended up hunting thru my tub of brake calipers until I found the one and only bracket that would suit. Of course it was attached to a corroded, rusty old caliper whose bolts refused to come out, so I had to drill the heads off. I actually had to do this twice, as I needed the curved "hat" that sits on the brake caliper piston from yet another corroded old caliper to allow the pad to self align with the disc rotor. Only took most of Friday, when it was around 90 degrees and all I wanted to do was go for a ride. Oh well.
When I was going thru my tubs of spares looking for a new piston seal I found a double banjo bolt which was lucky as I would have had to make one otherwise. I also found several bags with new braided brake lines in them that I bought for one of the kawasaki's, and now I've gone back to using a stock set of wheels and brakes on my Z1-B (and already had new replica brake lines) I "borrowed" them and used a 1 metre long line to run from the caliper to the FJR1300 "Brembo" master cylinder, which I won't need for my Kawasaki either, so it was up for grabs. I hope the "Rivet Counters" note my unforgivable use of white aircraft cable ties again, and gnash their teeth with rage......
K2 Bitsa twin disc front end 2 April 2021 9j by Terry Prendergast, on Flickr
K2 Bitsa twin disc front end 2 April 2021 9g by Terry Prendergast, on Flickr
K2 Bitsa twin disc front end 2 April 2021 9i by Terry Prendergast, on Flickr
So I hooked everything up, bled the brakes, and was happy that there were no leaks. I jacked up the front wheel and went to turn it, but couldn't. Great..........
That was Friday. Yesterday I woke up early-ish, ate breakfast, cleaned up my mess from the night before, then jumped in my car. I needed to drive to my Ma's place 200 miles away, and do some other stuff along the way. To do the "other stuff" I needed to hire a cage trailer. As I was turning out of my street into the main road I spotted a guy towing a cage trailer, and followed him to the local Shell station, and watched him return the trailer, which was great as it was the only trailer in the whole place! Woohoo! I filled the car with diesel, hooked up the trailer, and headed down the road.
I stopped first at my mate Fred's place. Like me, Fred is a CB750 nut, but is only interested in K1's. I'd been looking for a low numbers K1 frame to go with my 106XXXX (1970) engine as the frame I got with it (in parts, as usual, with many missing) was a 112XXXX (1971) and I couldn't find one anywhere. JustJohn here saw that I was looking for one and said he had a 108XXXX frame, which was way better than a 112XXXX, so he drove it all the way from Georgia to Sarasota, Florida, to drop it off at my shippers, what a great guy!
Anyway, I'd told Fred about it, and he said that he had a minty 107XXXX frame that would suit my 106XXXX engine, and my 108XXXX frame (which will be here in a week or so) would suit him as he has a 109XXXX engine? Sweet. Fred and I dragged the frame down from the top of the shelving in his garage, then I went thru his fuel tank collection as I need a tank to paint for my K1. I swapped him a late K2-6 head and a stock cam as he needed the valves, springs etc for his next K1 build. We put them in the back of my Ford, and I drove on down to Bairnsdale and out to my cousins' farm. I was picking up a couple of Velo/Solex mopeds from the 1960's to sell for him (I was gonna keep one, but decided that I didn't need one and couldn't think of a use I'd have for one) but first he had to move his 1928 Dodge "Fast Four".
We pushed the little mopeds into the trailer then drove into town to his other house (he's in the process of moving a huge amount of vintage cars, bikes, parts etc out to the "farm", which is only 5 acres or so, but he does have some sheep, so I guess it qualifies. We then spent another half hour or so filling the trailer full of Puch "Twingle" parts.
Puch's and Velo-Solex pile by Terry Prendergast, on Flickr
The wife had already threatened to murder me if I brought home any more bikes and parts, (and I haven't told her about the K2 on it's way down from Far North Queensland as I type this, as yet) and anyway, I decided I was gonna sell it all and give the money to my cuz, so I took it to Spotty's place and he helped me unload everything into his garage. Spotty is my business manager, so he's going to sell it all, take his fee, and I'll give the rest to my cuz. Spotty is a great seller of things, and being around 7 feet tall and 300 pounds, he rarely gets anyone returning an item.
I thought the wife had gone to her mother's place for an Easter Sunday party, so was in no rush to get home, so drove over to the carwash, gave the Ford a good wash, then dropped off the trailer, drove over to "Dan Murphy's" to buy a box of Ginger Joe, and came home. The wife was home surprisingly so we had a chat while I chugged down a bottle of GJ, then I turned my attention to the sticking front brakes. I wondered about a blocked return vent in the MC, but before I dug into it, I loosened off the bolts on the right caliper, and the wheel spun freely.
The caliper was perfectly lined up with the disc, it had a good piston and new seal, and fresh fluid. It was almost as if the pads were a little too thick? I have had this same situation on another bike, but before I did anything drastic I removed the caliper side pad to make sure the little curved "Hat" hadn't fallen out of the piston, but nope, it was there. Well, it was time for a "haircut". Now I still wasn't 100% sure this was the problem, so rather than bugger my new pads, I found an old one and put it in my lathe and machined it around 2mm thinner than the new pad. The benefit here also, was that I'd removed all the old oil, grease, road grime etc, so it was virgin material again.
K2 bitsa brake pad haircut by Terry Prendergast, on Flickr
I reinstalled it in the caliper, bolted it back onto the bike, jacked the front up, and spun the wheel, this time, there was just a slight drag. I fired the bike up and went for a quick lap around the block, and I couldn't believe how well the brakes worked, bloody magnificent! After 3+ years of "Average" (crap) brakes, all of a sudden, it feels almost as good as the brakes on my modern bikes! Keeping an eye on my mirrors (so I didn't have a car run up my arse) I grabbed a handful of brakes and just about buried the headlight into the asphalt! I couldn't help myself, I had to ride a few more miles, just enjoying my day, and loving my new brakes.
Tomorrow is another public holiday, so I think I better ride the K2 to the Heathcote Bakery for a pie. I haven't been there for a couple of weeks, so I thought I better go back just to make sure they're still there? The holiday traffic coming back into the city will be sh1t on the main roads, so I'll stick to the back roads as much so as possible to avoid getting stuck in bumper to bumper traffic, even on a bike which is a lot easier to cut around traffic, it's still a pain in the butt. Hopefully nothing will fall off, or explode, and it'll be a great ride. More soon. ;D
Offline grcamna2
« Reply #1581 on: April 04, 2021, 12:47:43 PM »
Hi Terry,how's your day?
You're making great progress on your bikes,especially the new front brakes:those pads that say 'Metal' brand,did you say they're organic? or are they sintered metal ? I like the adjustable lever you have on your master cylinder.
Here's hoping you can enjoy running the K2 Bitsa much more even to your work.
75' CB400F/'bunch o' parts'
Offline Trevor from Warragul
« Reply #1582 on: April 04, 2021, 08:31:35 PM »
My comment on the white cable ties had nothing to do with "rivet counting". In my opinion, white cable ties just look bloody awful on a black frame with black hoses. They don't look too bad on an aluminium fork leg.
If I was a "rivet counter" I would have kept the 4 exhaust pipes on my 350F & just not ridden the bike. I would also get rid of the modern master cylinder & braded brake lines, dyna ignition, & I certainly wouldn't have added a grease nipple to the front brake pivot...
« Last Edit: April 04, 2021, 08:35:41 PM by morini »
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
« Reply #1583 on: April 04, 2021, 08:42:33 PM »
Ha ha, I knew that would elicit a response from you Trevor, and we all know about opinions, they’re like areseholes, everyone’s got one! ;D
« Reply #1584 on: April 04, 2021, 10:49:25 PM »
The white ones are very brittle and crack easy after a short time of daylight exposure.  I think heat make them brittle too, as little as +60C.
They were used where I work in the 70-80's but were all replaced by black "outdoor" cable ties that withstand daylight much better.
« Reply #1585 on: April 04, 2021, 10:52:52 PM »
I think you’re generalising Per, these are aircraft quality cable ties, stolen from Qantas, so I seriously doubt they’ll fall apart from exposure to the sun! ;D
« Reply #1586 on: April 04, 2021, 11:02:27 PM »
The ones I have seen and used became brittle. Not made in China back then. Usually Hellerman made in Germany and similar.
Lets hope yours will be good and your bike fast as a wind ;D
« Reply #1587 on: April 04, 2021, 11:56:42 PM »
What do you do when you fall for Terry's sh*t-stirring?  Go for a ride!
My wife's VTR250 wasn't as nice on the dirt roads as my CB350F, but was better around the twisty tarmac.
1971 Kawasaki H1A
1972 Honda CB350F
1978 Honda CBX
« Reply #1588 on: April 05, 2021, 12:20:36 AM »
Ha ha, I was gonna ask if that was your wife's bike Trevor, definitely not something a man would ride! ;D
« Reply #1589 on: April 05, 2021, 01:04:56 AM »
Now I need to go for another ride!  Hold on a sec, I'm retired & can go for a ride anytime the urge hits me!  Have fun at work tomorrow!  ;D
1971 Kawasaki H1A
1972 Honda CB350F
1978 Honda CBX
« Reply #1590 on: April 05, 2021, 01:46:41 AM »
This is Terry's project thread so he is the king around here!  ;D ;D
« Reply #1591 on: April 05, 2021, 02:20:24 AM »
 Good humored male banter.   :) :) :)
1971 Kawasaki H1A
1972 Honda CB350F
1978 Honda CBX
« Reply #1592 on: April 05, 2021, 03:02:59 AM »
Anyhoo, all distractions regarding cable tie colours and girly bikes aside, today was a red letter day for the K2 bitsa. I was happy last night that the bitsa's brakes were working superbly, there were no oil or brake fluid leaks, my fork seals were all good again, and due to either the oil stabiliser or my oil cooler, the oil pressure is stable again.
K0 Bitsa Monday 5 Apr 2021 0 by Terry Prendergast, on Flickr
Today was much milder weather-wise, so I decided a K2 bitsa ride to Heathcote for a pie was in order. I did my "Pre-flight checks" and all was good, so I fired it up and took off. The traffic between my place and the Hume Freeway (5-10 minutes, usually) was mild, so I was cruising at 100 KPH (60 MPH) very early, and the oil pressure was steady on 50 psi. I stopped after 12 miles and filled the bike with Shell 98 RON fuel and it was good to see that everything was as it should be.
I rode to the Wallan turnoff and took the backroads to Romsey, Lancefield, Tooberac, and Heathcote. Being a typical Easter Monday public holiday, the bakery was really busy, but I was still able to find a carpark and table. I ordered the Beef, Mozzarella Cheese and Bacon pie, and it was delicious.
K0 Bitsa Monday 5 Apr 2021 6 by Terry Prendergast, on Flickr
I ate my pie and washed it down with a Mocha drink, then wandered back to the bike. As expected there were a couple of old farts hanging around to tell me that they "Had one just like it" and we had a chat for a few minutes before I fired it up and gave it the berries up the main street, to give them a thrill. I stopped a few miles up the road for some pics.
K0 Bitsa Monday 5 Apr 2021 3 by Terry Prendergast, on Flickr
The traffic, even on the backroads, was building, it was getting busy in Kilmore where I stopped to fill up again (8.19 litres) and by the time I hit the freeway it was down to a crawl with a good 15 miles to go. I took the Beveridge exit, and rode across to another road that runs parallel to the freeway, less the traffic. Was a good move, as the wife was telling me that there was bumper to bumper traffic on her way home from her family's Easter get together today. I got home, parked the bike, did my post-flight checks, was happy there were still no leaks after 140 miles, the oil pressure was fine, and the bike was going great.
It's now done 650 Km, (400 miles) of which the last 450 Km (300 miles) has been trouble free. This is a big thing for me, as I was sure for awhile that this bike was indeed cursed, but in reality, it just had engines that were "built" by amateurs who shouldn't have been allowed to own tools.
K2 bitsa speedo by Terry Prendergast, on Flickr
The engine's good, the suspension is fine, the brakes are awesome, and as soon as JamesH gets those K0 carbs to me, it's gonna feel a lot more perky with the super-light throttle. I did wang it out to 8000 RPM in the lower gears a couple of times, but traffic was pretty horrible, the cops were hiding everywhere, and so I rode like a "responsible adult" for most of the day. All in all, a great day! ;D
« Reply #1593 on: April 05, 2021, 05:57:25 AM »
It really is a fantastic feeling when bike runs fine as these bikes should. But there are some issues that can happen which is known by the experienced guys.
Nice to feel the smell of a recently restored hot engine when stopped without oil smell.
No stinking exhaust due to floading carbs, too rich jetted or oil enter chambers via gasket/o-rings/valve guides with seals.
Upon this ignition, charging, generally corroded connection issues.
I know, I had that very good feeling yesterday.
You'll use the bike as it is now, Terry?
Are the shocks lower?
« Last Edit: April 05, 2021, 06:01:47 AM by PeWe »
« Reply #1594 on: April 05, 2021, 01:50:39 PM »
Thanks Per, yeah it’s got a 16” rear wheel so I used lowering blocks to drop the arse end so it doesn’t look weird with a huge gap between the tyre and the rear fender, and while I’ve also got another Henry Abe 18” rear wheel with a new Stinko tyre that I can install and remove the lowering blocks, the 150/80-16 rear tyre gives it the same OD as the 18 incher with a 120/90-18 tyre, so no real advantage, and I love the stance, and that fat back tyre looks so good, and (just) clears the centre stand, brake stay arm (after I modified it) and the chain, so for the time being, it can stay, my next task is to paint the tank I picked up on the weekend. My first K1 was painted silver and I really liked that bike, so I think I’ll paint this one silver too.
Then I just need a K2 seat so I can put the K1 seat that’s on it now (once I install a new cover) on my early K1 that I’ll be starting in the next few days. Isn’t bike building fun? Thanks to Covid 19 I’m now permanently only working at the office 3 days a week and working from home every Wednesday and Friday, so I’ll still have heaps of time to build my bikes, while getting paid.
It’s almost like being retired, without the boredom, and without having to live off my retirement savings like most of my retired friends who have to make their savings last with no income coming in. Anyway my favourite restaurant opens in 10 minutes so I might wander over for one of their magnificent breakfasts, something I really missed when I was home for the last 13 months. ;D
Offline grcamna2
« Reply #1595 on: April 05, 2021, 02:02:41 PM »
Terry,I'm glad to hear the good news about your K2,it's dependable now !
« Reply #1596 on: April 05, 2021, 02:10:36 PM »
Thanks Bill, yep, and going like a rocket! It’s nice to move it from the “current project” to “ride anywhere” status so I can move on to the next build. Well “builds” actually, because I need to build my 1970 K1 and at least one more K2 for the Harley deal I’m doing with Dion. And then the K2 “Rat” with the apes. Should be a busy winter! ;D
« Reply #1597 on: April 05, 2021, 04:01:07 PM »
....And they all stink!
« Reply #1598 on: April 05, 2021, 04:15:43 PM »
Yay! I just won an Ebay auction for a good looking K2 seat! Personally I hate the later K3 to K6 seats that are everywhere on Ebay, Yamiya etc, they’re just shapeless planks, so when I saw a used one locally (albeit with a repro cover, but that’s fine) I jumped on it like a fat kid on a donut, bid a ridiculous amount, but luckily for me there was no bidding/sniping war at the end of auction, so I got it for a fair price.
Hopefully I’ll have it in my hot little hands in the next few days, so I can install it and take the K1 seat off the bitsa, fit the new cover I bought for it years ago, and replace the stainless steel trim pieces and strap, ready to go on the 1970 K1 I’m about to start! ;D
Offline 71 V12
« Reply #1599 on: April 06, 2021, 01:38:14 AM »
Hi Terry,
Loving your posts as always. I am a big fan of a dual disc conversion on the CB750K, it makes the bikes rideable on our congested U.K. roads.
The drilled, cast disc are interesting. Do they pull up significantly better than the Honda OE’s?
Who makes/ sells them?
