Author Topic: Kick Start lever moves freely  (Read 1805 times)
Offline beemerbum
« on: May 07, 2017, 11:02:09 AM »
Just got my K 4 750 motor back from a professional rebuilder. Just for fun, I moved the kick start lever. It moves through an arc smooth as butter, never turning the crank. That just ain't right. Can some one inform me as to the language I should use when I meet him Monday. I can handle the cussing part. What would be the technical terms for what is not happening?
Re: Kick Start lever moves freely
« Reply #1 on: May 07, 2017, 11:26:47 AM »
 Kickstart gear not engaging should get the point across. before the cussing starts  :)
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #2 on: May 07, 2017, 11:33:26 AM »
Before you cuss at the tech - did you grab the clutch lever out of habit?  I've done that and nearly ended up on the ground from a good kick!
Offline beemerbum
« Reply #3 on: May 07, 2017, 11:52:12 AM »
I just looked in a box of "old used parts" that came back with the motor. In the box were a spindle, starter gear, spring, pawl, etc. May I now begin to practice cussing? Obviously, the cases will need splitting to fix this abomination. Although I retired from the practice of law, I did not forget it. Hell hath no fury like a pissed off ex-prosecutor with three guys on death row.
Offline FIREBLADE74
« Reply #4 on: May 07, 2017, 06:49:16 PM »
Damn Beemer, 3!!
06 CBR1000RR, 76 CB550
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #5 on: May 07, 2017, 06:51:47 PM »
Post some picts of the spare parts and members here can likely identify then on sight.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline eigenvector
« Reply #6 on: May 07, 2017, 06:53:17 PM »
Do you actually need to take the engine apart or can you access it from the clutch cover?  for some reason I thought you could get to it from there.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
« Reply #7 on: May 07, 2017, 06:55:49 PM »
Kickstarter repair will require splitting the cases. Electric starter gear can be repaired/replaced by pulling the alternator and the rotor without splitting the cases.
TAMTF...
Wilbur
Projects:
« Reply #8 on: May 07, 2017, 07:33:09 PM »
Well #$%*! If you've been practising all these years you should be good at it by now. Quit practicing and just do it!
  • Holy Cow! I'm a
« Reply #9 on: May 07, 2017, 09:46:47 PM »
I hope these help.
Offline drumstyx
« Reply #10 on: May 07, 2017, 10:24:35 PM »
It's a big ol' pain in the arse getting that spring back in place, maybe he gave up and hoped you wouldn't notice?
I actually found a way to do it without any bloodshed...
Offline DaveBarbier
« Reply #11 on: May 08, 2017, 04:18:58 AM »
I'd love to hear his excuse for not installing it.
On a 550 you can look up through the oil pan and check out what's going on. Might be able to on a 750 also. Just to confirm before you head back to your mechanic.
« Reply #12 on: May 08, 2017, 04:36:49 AM »
 The oil pump runs off some gears behind the clutch cover also around the kick start area, good idea to take a look in there to see what is going on and like mentioned post up some pictures of those 'extra' leftover parts.
Offline drumstyx
« Reply #13 on: May 08, 2017, 07:17:14 AM »
I'm pretty sure the oil pump runs off the kickstart gear. I remember because Hondaman's book said to check for wobble on the kickstart gear because its oscillations have an effect on oil pressure apparently, and in my case there was some wobble, so I just take note of it and pay attention to oil pressure.
