Author Topic: Painting fork legs, engine, frame, arm, etc. Recommended paint?  (Read 2741 times)
Offline JBCB500
  • Really enjoying this!
Hello all,
I would like to paint quite a bit of this bike black.  I am considering using VHT roll bar and chassis paint for everything but the engine.  Any comments?
Also, what black spray paint would you recommend for painting the engine?  What primer?  And any tips for engine painting?
Finally, if I have a tank in decent shape, what say you to sanding the current topcoat a bit and then spraying final color over the top of that instead of stripping, re-priming, etc.?
I'm doing this all myself, and while not trying to cut corners, I'd rather not take any unnecessary steps.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Painting fork legs, engine, frame, arm, etc. Recommended paint?
« Reply #1 on: May 10, 2017, 09:56:25 AM »
I like duplicolor aerosols.  Vht is good for many things too.
Its the prep work that will make or break ya.
Offline innovativems
    • Innovative MotoSports
« Reply #2 on: May 10, 2017, 10:56:56 AM »
The vht expoxy paint is very durable.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline Calaya
« Reply #3 on: May 10, 2017, 11:11:11 AM »
I've been researching the same thing and, after considering VHT, POR-15, and Eastwood, I think I'm leaning toward the Eastwood engine paint.  It's a two-part epoxy (in rattle can) which seems to have good reviews.
My concern was flaking and/or using a clear that would eventually yellow.  The Eastwood product seems to suit my needs the best.  Unlike VHT, baking isn't required and, unlike the POR-15 which is a brush-on, the Eastwood is sprayed on ... and everything I hear about 2-part epoxy is very good.  Of course, all of the info that I've come across seems to indicate that the prep is the most important thing.
Offline Court750Cafe
« Reply #4 on: May 10, 2017, 11:27:56 AM »
+1!
1973 CB750k
Offline beemerbum
« Reply #5 on: May 10, 2017, 12:52:14 PM »
Someone here recc'd Rust-0leum appliance epoxy for the frame. Worked great. The degree of gloss seems totally stock.
« Reply #6 on: May 10, 2017, 01:17:21 PM »
VHT for the engine worked great for me.  Clean clean clean before you even think about spraying...and I used primer.
Offline slikwilli420
  • Master of Disaster
« Reply #7 on: May 10, 2017, 01:21:01 PM »
I have found the Duplicolor and VHT items to be hard to apply and awful smelling compared to other paint.
I was burning cans of Duplicolor black on a frame like it was going out of style and it flashed so quickly, good coverage was near impossible.
I finally got sick of it and switched to Rust-oleum black and it flashes slower, meaning it dries to a nicer consistency since I can get all the paint on for that coat before it flashes.
I have grown up with Rust-oleum and it has not let me down yet. I will be doing my frame in standard gloss black, I had my eye on the appliance epoxy but this was cheaper and will do the job just as well.
Offline Scott S
« Reply #8 on: May 10, 2017, 01:28:50 PM »
 Believe it or not, good old Walmart aerosol cans. Looks good, reasonably tough and easy to touch up. I've used their black on frame, swing arm, brackets, etc., plenty of times. It used to be $1 a can, I think it's up to $2 now.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Bankerdanny
  • Endeavor to persevere
« Reply #9 on: May 10, 2017, 01:52:49 PM »
I used a black chassis paint from Harbor Freight on the frame of my project bike. The finish is almost identical to the original black with just the right amount of gloss.
Offline Scott S
« Reply #10 on: May 10, 2017, 02:10:59 PM »
 And VHT silver is a very, very close match to the original silver engine color.
'71 CB500 K0
'81 Yamaha XS650
