Author Topic: 76 750 charging rotor camshaft thread strip  (Read 644 times)
Offline Chachi
« on: May 13, 2017, 05:36:39 PM »
Asking for a friend... he was attempting to pull out his charging rotor but the tool he was using was the wrong pitch and it stripped the camshaft threads. What are his options?
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline drumstyx
Re: 76 750 charging rotor camshaft thread strip
« Reply #1 on: May 13, 2017, 05:55:23 PM »
Universal jaw-type puller, followed by installing a new rotor? This might be a pain in the arse...
Offline Chachi
« Reply #2 on: May 13, 2017, 05:58:52 PM »
He was using a puller with same diameter bolt but with wrong pitch. Wondering if it can be re-tapped/machined in place, etc.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline Ridem32
« Reply #3 on: May 13, 2017, 06:14:19 PM »
I would try to run the right size tap in it. It might clean up.
« Reply #4 on: May 14, 2017, 04:51:51 AM »
 Your saying that the crankshaft bolt hole for the rotor is stripped ?  If the proper metric will no longer work a switch to the next size SAE bolt tapped and threaded may work.  May be just slightly larger.
« Last Edit: May 14, 2017, 04:55:24 AM by ekpent »
Offline Chachi
« Reply #5 on: May 14, 2017, 07:06:17 AM »
Yes that's what happened. Think it can be done 'in place'? Take bike to a machine shop, etc.?
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
« Reply #6 on: May 14, 2017, 07:58:34 AM »
 The fix, if that was a possible route would be fairly easy,that being said if you don't have the right quality tools, taps etc. and the experience may be best to let someone with more experience give it a go. The job is a quickie but the crank is a very critical part.
