Ok folks,
Thanks for the clarification, so, to reiterate, switching plugs may help eliminate some of the symptoms of rich/lean mix resulting in some maintenance/spark plug benefits, however; would not eliminate the performance issues running lean or running rich may cause and resulting long term maintenance/damage issues.
In the end, work on the jetting, get that tuned, run the recommended heat range plug.
Thanks all!
