Author Topic: 1978 CB750K skill builder (read: low budget)  (Read 31227 times)
Re: 1978 CB750K skill builder (read: low budget)
« Reply #25 on: June 09, 2017, 10:36:41 AM »
Ok, I'm open to ideas for a tank. I'm having an incredibly hard time finding a F tank, and I need to get this thing going. Has anyone used anything other than 750 tanks on these bikes that don't look too small?
Patience, Dave.  They come up on Fleabay but there are periods of dry spells sprinkled with listings (less frequently than in prior years).  Try to get your other stuff done and do a periodic (2xweek) search.
I'm trying to get the stuff like seatpan done, but wanted to have the tank to use for measurements/mockup. I guess I can offer the guy locally with the rusted out tank 20 bucks and use it for mockup/measurements.
I had a fairly clean spare, but the guy who was pounding in knee dents also pounded in some clip on dents (which should have been cut and welded).  If you don't want knee dents, don't bother.  But, if so, and you don't mind some fab work on the clip-on dents or pulling them out, let me know.
Note: I also had the top filler door cut out to fill, so I could install a Monza cap (which I also have).
Offline Davez134
« Reply #26 on: June 11, 2017, 08:29:58 PM »
I have found a tank. I saw while searching craigslist, and the guy selling was willing to ship it. Pics when it shows up.
« Reply #27 on: June 12, 2017, 08:55:38 AM »
Great find, Dave.  The listing photos looked great, especially for the price!
Offline Davez134
« Reply #28 on: June 16, 2017, 06:22:04 PM »
Got tank and seat today. Amazing condition with NO rust and just a couple small dents. Plan is to shorten seat a bit but still use rear cowl. I saw a thread on doing that somewhere on here and it looked great.
« Reply #29 on: June 16, 2017, 10:03:06 PM »
Wow! That was a score on the tank/seat. The inside of the tank is spotless, too!
« Reply #30 on: June 17, 2017, 01:14:17 AM »
+1.  Your patience paid off...
Offline Davez134
« Reply #31 on: June 17, 2017, 08:35:14 AM »
For sure. I don't have to worry about getting rid of any rust, which makes mt very happy! My plan for the seat is to shorten it a bit like this:
http://forums.sohc4.net/index.php/topic,163983.msg1896577.html#msg1896577
I don't know which pan I'm going to use, the K or F, but I'm going to use the rear cowl for sure.
Offline Davez134
« Reply #32 on: August 31, 2017, 02:57:02 PM »
I've tried making the stock pans and the hinges, but couldn't make it look like I wanted. I ended up getting a fiberglass seat and upholstery pan from air tech streamlining. What have you guys done to mount the seat pan to the frame? I would like it to be easily removable, but don't want to use Velcro. I don't mind making mounts and welding them on, but I'd like it to be clean looking and only want to do it once! The battery, electronics, oil tank will all be in the original locations.
« Reply #33 on: August 31, 2017, 03:39:13 PM »
Bummer.  I REALLY liked that shortened seat that Frode did, too.  I think it can be done and reworked to used the stock hinges, but those are welding skills I do not possess.
I have seen people reinforce the Airtech seats and glass in the stock hinges.  Or a simple way is to weld mount tabs onto the frame rails and bolt on the seat.  Check out this as an idea.  You can cut some sheet metal into these shapes and weld it onto your frame easily enough:
https://www.lossaengineering.com/collections/motrocycle-parts/products/lossa-seat-tab-kit
Offline Davez134
« Reply #34 on: August 31, 2017, 05:25:38 PM »
Thanks for the link Don, that's exactly what I'll do! I like the shortened F seat he did too, I just couldn't get the shape mine done how I liked it. I'm still going to keep it, maybe rework it some more for the next bike. I'm working on new welding skills too. I feel totally competent with my MIG skills so I just bought a Lincoln TIG.
« Reply #35 on: August 31, 2017, 06:57:41 PM »
That's awesome.  Maybe I should come out for a clinic!
Offline Davez134
« Reply #36 on: August 31, 2017, 07:27:15 PM »
Plenty of room in the shop!
« Reply #37 on: August 31, 2017, 10:08:49 PM »
I'll be in Vegas in September and October for work.
Offline Davez134
« Reply #38 on: September 01, 2017, 08:03:40 AM »
Hit me up when you're here.
Offline Davez134
« Reply #39 on: September 01, 2017, 05:46:12 PM »
I cut the hinges off carefully and was thinking about reusing them. When I laid the seat on the frame, I don't think there is any clearance for it to hinge. It is meant to sit on top of the frame rails. I will weld a couple tabs in place that can be easily accessed from under the seat and fasten it with studs and wingnuts. I'm also stripping the paint from the tank and going to begin bodywork on it. I will get some pictures up tomorrow hopefully.
« Reply #40 on: September 01, 2017, 06:15:17 PM »
Did it come with a pan, or do you have to make one?
Offline Davez134
« Reply #41 on: September 01, 2017, 07:44:19 PM »
It came with a pan that fits very nicely
Offline Davez134
« Reply #42 on: September 01, 2017, 08:54:35 PM »
It came with a pan. Here is the frame with the tabs/hinges removed, tank and seat on, then with pan on too
« Reply #43 on: September 01, 2017, 11:07:44 PM »
I was wondering if it was that model. I like how the pan fills the gas tank gap.
Offline Dracon
  • Wannabe Old Timer...
« Reply #44 on: September 02, 2017, 01:27:02 AM »
Do you still have the tabs/hinges for the frame? I'd buy them if they are usable!
Bike looks great also!
Offline Dracon
« Reply #45 on: September 02, 2017, 01:31:51 AM »
Hmmm, just realized this was a K frame - I need them from a 77/78 F frame unless they are the same?
Offline sethmcalister
« Reply #46 on: September 03, 2017, 09:13:04 PM »
I'd take the hinges though if Dracon isn't interested.
Sent from my Nexus 6P using Tapatalk
Offline Davez134
« Reply #47 on: September 03, 2017, 10:31:44 PM »
Yes, it's a k frame. I'm at work the next 2 days, but I'll take pictures of what I was able to save of the hinges and seat lock when I get home.
« Reply #48 on: September 06, 2017, 04:19:18 PM »
+1
Offline Davez134
« Reply #49 on: September 12, 2017, 02:09:56 PM »
Found a color I liked, House of Colors Tangerine pearl. I have rusted out f tank I used for a test spot, so pay no attention to the dents/rust around the area. Looks great in the sun!
