Author Topic: Porous oil filter housing?  (Read 1090 times)
Offline Scott S
« on: May 20, 2017, 05:16:46 AM »
 I have the smallest oil leak around the oil filter housing on my CB500/550 build. But when I wipe my finger across the bolt or where the housing meets the engine case, it seems dry. I had that housing vapor blasted. Is it possible that the oil is actually leaking THROUGH the housing?
 I installed new O-rings and even an NOS bolt. It really seems like the oil is coming from the middle of the housing, between some fins.
 I have some other O-rings and other housings (but with bent or broken fins). I'm trying to get a few more miles on this oil before changing it.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Re: Porous oil filter housing?
« Reply #1 on: May 20, 2017, 05:55:26 AM »
I doubt its porous enough to leak but could have a crack?
Offline flatlander
« Reply #2 on: May 20, 2017, 08:22:05 AM »
i also think a crack would be more likely than it being porous. maybe it was dropped ones and has a hair fissure that's barely visible.
maybe the baby powder trick would work to locate the source?
Offline Bodi
« Reply #3 on: May 21, 2017, 02:47:31 PM »
Put one of your different cases on for now... you only lose about a cup of oil.
Offline Scott S
« Reply #4 on: May 21, 2017, 04:04:40 PM »
 It's weird, it only seems to leak when the engine is cool. Didn't leak a drop when it was hot, and not for about 24 hours....then another couple of drips.
 Maybe I'll swap it out and install a new O-ring when the one Cal is sending gets here.
'71 CB500 K0
'81 Yamaha XS650
« Reply #5 on: May 21, 2017, 07:01:40 PM »
You sure its not dripping onto the filter housing from somewhere higher up?
Offline Scott S
« Reply #6 on: May 22, 2017, 05:30:02 AM »
 No, I'm not sure. The filter housing is dry on top, though. Dry on the front around the bolt (used a NOS Honda bolt.... I opened the package myself). Dry where the filter housing meets the engine case....though the last time I checked there was maybe... *maybe*.... a little moisture there. I don't even see oil "hanging" on the filter housing. It's just wet to the touch or when I stuff a folded shop towel between the fins, and there's a drop or two on the ground, directly below the filter housing. Not at the end, not at the case. Right below the housing.
'71 CB500 K0
'81 Yamaha XS650
