Author Topic: To lead or not to lead  (Read 992 times)
Offline HondaYo
« on: May 20, 2017, 01:16:13 PM »
Struck me as I filled up my -72 K1 today that it might be a good idea to check if I need to put lead-additive in my fuel. The head was refurbished during the past 10 years or so. I´ll check with pre owner. Any input?
Online BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: To lead or not to lead
« Reply #1 on: May 20, 2017, 03:16:26 PM »
NO!!!!
These bikes aren't that old  ;D
Offline HondaYo
« Reply #2 on: May 20, 2017, 03:26:50 PM »
Actually, the owners manual I found online says it´s recommended to add a few percentage. What say You?
Offline drumstyx
« Reply #3 on: May 20, 2017, 03:27:34 PM »
I mean, the answer is indeed no, but I don't think it'd hurt, there's no catalytic converter.
I wouldn't bother obviously, but I've always wondered if it might actually be good for the valve train in all my bikes (which don't have cats) to run leaded fuel. Obviously bad for the environment and all, but would it reduce wear?
« Reply #4 on: May 20, 2017, 03:30:20 PM »
The aluminum heads have hardened valve seats, so lead is NOT strictly required.  Doesn't hurt though, to lube up those seats with lead.
I don't see a requirement, or need to worry about it.
Offline Lostboy Steve
« Reply #5 on: May 20, 2017, 04:47:06 PM »
I don't even run lead additive in my 61 corvair. Just a little mystery oil in the amco top end oiler. A while back on here someone said they used a small amount of 2-cycle oil in their tank at fill up and I've tried that but have reverted to marvel for everything. I used to do belray 2 stroke in my ported rx-7, a qt per fill up.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #6 on: May 20, 2017, 05:01:11 PM »
The biggest problem with lead loss is valve seat recession.  My 72 truck has cast iron valve seats.  Under load, the lubrication loss will cause seat erosion.  I don't even need lead in that truck unless I'm towing a trailer up grades.  I add lead substitute when that occurs.
I don't believe mystery oil works in the gas supply to lube valve seats, as it doesn't contain a lead substitute.  I also don't think a 2 stoke oil has enough lead in it to save valve seats.   But, unless you are working the motor hard, you don't really need it.
The SOHC4 already has hardened seat in the aluminum head.  Just don't strictly need lead for seat lubrication.
« Reply #7 on: May 20, 2017, 05:27:06 PM »
Yeah so does the corvair.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline drumstyx
« Reply #8 on: May 20, 2017, 05:34:33 PM »
On this topic, if I wanted to add a lead/substitute additive, is there any definitive study on real lead vs lead substitute? Being in Canada, of course all we have is lead substitute.
Offline Bailgang
  • Scott
  • Indiana
« Reply #9 on: May 20, 2017, 05:58:16 PM »
I think in regards to Steve using 2 stroke oil in his RX7 it has to do with keeping the apex seals of the rotors lubed and I'm not sure leaded gas would help much in a rotary. I don't know too much about Wankels but I do know that many if not all rotary's have some sort of oil injection system at least I know a friend of mine's RX7 had it.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
« Reply #10 on: May 20, 2017, 06:43:04 PM »
I would never spend the type of money I did on a project like that ever again. Those engines, yet distinctive and fun, are a nightmare in the long run.
The 2-stroke or marvel is just to help with lubrication. Air cooled engines get hot and every bit of extra lube helps.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline HondaYo
« Reply #11 on: May 21, 2017, 02:17:57 AM »
Obviously I spend energy worrying about  unnecessary things, when I should spend more time riding my bikes.
 Northern paranoia perhaps. :o
Thanks guys. Didn´t really know what the actual purpose of lead in fuel was til now.
Enjoy Your weekend!!!
