Author Topic: 1974 CB750 Clutch Woes - Stalls When Going into Gear  (Read 2692 times)
Offline whitjonw
  • Motorcycle Maniac
« on: May 21, 2017, 06:52:17 PM »
I have been screwing with my clutch to no end. I have installed a new clutch cable and adjusted the clutch per the manual with no positive results. Does this sound like clutch plates sticking together and not separating ? The engine had set for a few years before I got it running last September. I put about 10 miles on it before putting it away for the winter and it had a tendency at that time to want to clunk into gear and stall out but not like it does now. I'm getting beyond frustrated !
Does this sound familiar to you guys ?
1973 Honda CB500 K2
1974 Honda CL200 Scrambler
1974 Honda CB750 K4
1976 Honda CB750 K6
This is our life, this is our song.....
Offline Jimray23
    • none
Re: 1974 CB750 Clutch Woes - Stalls When Going into Gear
« Reply #1 on: May 21, 2017, 07:08:46 PM »
Does your bike have a center stand?
Jim
1979 kz1000b ltd
    stage 3 cams
    pod air filters
    4-1 open exhaust(no muffler)
    full rewire
    dyna-s ignition
    dyna 3 ohm coils
Offline Jimray23
    • none
« Reply #2 on: May 21, 2017, 07:10:51 PM »
It could be the clutch push rod wore off on the tip or snapped in half
Jim
1979 kz1000b ltd
    stage 3 cams
    pod air filters
    full rewire
    dyna-s ignition
    dyna 3 ohm coils
Offline whitjonw
  • Motorcycle Maniac
« Reply #3 on: May 22, 2017, 09:22:11 AM »
Yes, it does have a center stand. I have run the bike in gear while on the center stand while trying to diagnose this problem.
1973 Honda CB500 K2
1974 Honda CB750 K4
1976 Honda CB750 K6
« Reply #4 on: May 22, 2017, 09:32:10 AM »
If you're sitting on it, does it lurch forward when going into first/stalling?
If yes, clutch plates are sticking. Last oil change?
Offline whitjonw
  • Motorcycle Maniac
« Reply #5 on: May 22, 2017, 05:37:03 PM »
Yes, that is exactly what it does. Last oil change was September of 2016 and no more than 10 miles put on it before winter and present.
1973 Honda CB500 K2
1974 Honda CB750 K4
1976 Honda CB750 K6
« Reply #6 on: May 23, 2017, 07:02:18 AM »
Re-adjust your cable, and change oil.  Those are your first tasks.
This happened to me repeatedly after winter slumber in Bel-ray Mineral 4T 20w50,  so I switched to Spectro 4 (not Golden) motorcycle 20w50, and it stopped after my first long ride.   Love it.  No more sticky plates
Offline whitjonw
  • Motorcycle Maniac
« Reply #7 on: May 23, 2017, 07:48:41 PM »
Readjusted the cable who knows how many times now but will do again and will see if I can get the Spectro 4. Thank you.
1973 Honda CB500 K2
1974 Honda CB750 K4
1976 Honda CB750 K6
Offline Jimray23
    • none
« Reply #8 on: May 23, 2017, 08:20:05 PM »
If you let it set a few months withoit oil in it, you may need to go in the clutch and get the rust out again
Jim
1979 kz1000b ltd
    stage 3 cams
    pod air filters
    full rewire
    dyna-s ignition
    dyna 3 ohm coils
« Reply #9 on: May 23, 2017, 08:35:56 PM »
Start by adjusting the screw in the center of the clutch cover, with the cable adjusters loosened. You should be able to move the lever at the cover about 1/8 inch or slightly less with one finger. Once the screw is set, adjust the slack out with the cable adjusters, but don't rely solely on the "free" travel at the end of the handlebar lever; look at the cover lever when the handlebar lever is pulled in, and fine tune the cable so the cover lever starts to move at the smallest handlebar level movement that will still allow the cover lever to return to it's normal resting position when the handlebar lever is released.
Offline Bodi
« Reply #10 on: May 24, 2017, 04:49:26 AM »
Is it possible someone replaced the clutch plates? Barnett clutch kits were popular as they provide increased torque capacity, BUT the clutch would often be seriously stuck - even when left overnight. Plus the friction material wore off rapidly with short plate life and a lot of fibrous crud in the oil: filters sometimes clogged to be bypassing within a couple of thousand miles.
I had a Barnett. I cut a plywood piece with a notch that fit over the left grip and held the clutch lever in. It wasn't long before I ditched their plates and installed OEM ones.
« Reply #11 on: May 24, 2017, 08:56:13 PM »
the plates will usually unstick if you can get the bike moving and ride it around a little.  Try rolling down a hill, then clunk it in gear and go.  Or even just scoot it into motion with your feet.
Offline whitjonw
  • Motorcycle Maniac
« Reply #12 on: May 25, 2017, 07:15:17 PM »
I've done that a few times prior to starting this thread and a couple since and still no luck. I've got the clutch center nut tool on the way as well as new gasket, springs, etc., so feel inclined to go in and have a look at this point.
1973 Honda CB500 K2
1974 Honda CB750 K4
1976 Honda CB750 K6
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #13 on: May 26, 2017, 01:17:21 AM »
These don't have kickstand sensors do they?  The xj600 had me punk'd like that.
Offline whitjonw
  • Motorcycle Maniac
« Reply #14 on: May 27, 2017, 06:53:22 PM »
I picked up the Spectro 4 today, which I was amazed to find it locally, and will be changing the oil tomorrow. If this doesn't free it up in conjunction with putting several miles on it, I will go in and dismantle the clutch and check every thing out. Thanks for the tip.
1973 Honda CB500 K2
1974 Honda CB750 K4
1976 Honda CB750 K6
