Author Topic: Speedometer Gearbox Help Please  (Read 802 times)
Offline matt s
« on: May 21, 2017, 08:26:45 PM »
I'm stuck. How does the piece on the right go in the piece on the left?  The gear inside the piece on the left just jams against the gear on the right and I can't twist it in or anything. Please help!
1973 CB350F - sold :(
1974 CB750K4 (In progress - forums.sohc4.net/index.php?topic=107272.0)
Offline Jimray23
    • none
Re: Speedometer Gearbox Help Please
« Reply #1 on: May 21, 2017, 08:31:09 PM »
How did u get it out? Did u pull pin/keeper out?
Jim
1979 kz1000b ltd
    stage 3 cams
    pod air filters
    4-1 open exhaust(no muffler)
    full rewire
    dyna-s ignition
    dyna 3 ohm coils
Offline Jimray23
    • none
« Reply #2 on: May 21, 2017, 08:33:33 PM »
You should be able to drop it in and then turn the big gear behind the seal to pull it in.
Jim
1979 kz1000b ltd
    stage 3 cams
    pod air filters
    full rewire
    dyna-s ignition
    dyna 3 ohm coils
Offline matt s
« Reply #3 on: May 22, 2017, 07:33:14 AM »
That's what I thought should happen but when I turn the big gear the thing just jams up.  I assume I shouldn't force it, right?
Offline Smudgemo
  • Maker of Stuff
« Reply #4 on: May 22, 2017, 09:07:01 AM »
Never had one apart, but my rule of thumb is never force it.  I can't offer any advice other than to say I'd look for something internally that's preventing the gears from meshing, or maybe they need to mesh a certain way where you either need to look for marks, or just keep playing with it until you find what works.  Barring that, there seems to be a ton of them on ebay.  If you're trying to clean it up, member noblehops vapor blasted mine w/o taking it apart and it's working fine.
-Ryan
Thread - How to fix your starter button (for real): http://forums.sohc4.net/index.php/topic,163170.0.html
Offline drumstyx
« Reply #5 on: May 22, 2017, 09:14:20 AM »
IIRC there's a cap that screws on one side, no? I only know my '78 though, might be different.
As far as actually getting it in, make sure you're putting it in the right way, make sure everything is clean and greasy, and it should wiggle and mesh into place. Pull (and replace with new) the seal in the centre if you haven't already, so you can get a better look in there.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #6 on: May 22, 2017, 10:56:13 AM »
Some good info here, not sure if it solves your problem though:
http://cb750sandcastonly.com/smf_forum/index.php?topic=720.0
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
