Author Topic: 77/78 750F petcock rebuild?  (Read 1568 times)
Offline slikwilli420
  • Master of Disaster
« on: May 24, 2017, 06:12:39 PM »
I have a petcock that has been apart and need to know what other years have the right internals? There is a seal for the top nut that goes to the tank and the round seal with 4 holes at the petcock knob. Those are all I need as everything else looks good.
Re: 77/78 750F petcock rebuild?
« Reply #1 on: May 25, 2017, 04:05:02 AM »
Come on guys, anyone? Need to figure out something ASAP for my race bike.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: May 25, 2017, 06:23:47 AM »
I rebuilt mine:
Can anyone tell which one is the new seal?
I reused the mounting posts for the front plate by leaving as much of the nubs as possible:
Voila'! (as opposed to "viola'" which everyone knows is a musical instrument)  ;)
Good for another 40 years! Good thing too, since this can only probably be done once, which is okay... because 40 years from now I won't care!
I don't remember the part number for the valve seal (with four holes) but I might have one in the bag that I can get a part number off of this evening. The seal/gasket inside the nut is included with the new in-tank filter when ordered from Honda. I recommend replacing this in-tank filter. Make sure the old one is removed first since they tend to remain in place when the fuel valve is removed. Looking from the bottom of the tank it will look like a round plastic insert inside of the fuel valve bung on the bottom of the tank. You can also look for the filter screen by shining a flashlight inside the fuel tank (don't use a lighter!) towards the bung. They typically get overlooked and I have removed numerous later model in-tank filters that looked like they were original from they factory. They can be stubborn to remove when left in place for that long and I usually pry the side of the filter inwards from below then grab it with a pair of needle nose pliers and twist/pull.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #3 on: May 25, 2017, 07:18:58 AM »
Thanks MMM! Anyone else know what rebuild kit the rubber washer with 4 holes comes from?
I'd like to order the strainer for the F petcock as well as the other seal and going to get an aftermarket petcock as well. I am out of time in this thing and can't have any more hiccups.
« Reply #4 on: May 25, 2017, 07:42:17 AM »
TAMTF...
Wilbur
Projects:
« Reply #6 on: May 25, 2017, 08:11:04 AM »
http://4into1.com/petcock-rebuild-kit-honda-cb160-cb72-cb77-cb350f-cb500k-cb750k
This looks aftermarket and there is no indication of whether the rubber parts are "Viton" rubber. I have had bad results with aftermarket fuel system rubber parts that were not Viton that quickly disintegrated in ethanol laced fuel. Original Honda parts are best, if available. If not, then I specifically seek out fuel system rubber parts that are made of Viton.
BTDT
TAMTF...
Wilbur
Projects:
« Reply #7 on: May 25, 2017, 08:29:05 AM »
Running non ethanol fuel I'm my race bike so hopefully it won't be an issue. Going to see if the local place has this stuff so I don't have to wait on shipping.
« Reply #8 on: May 25, 2017, 09:22:37 AM »
I still highly recommend Honda parts or Viton aftermarket. You won't know until it's too late...
like at the starting line...
TAMTF...
Wilbur
Projects:
« Reply #9 on: May 25, 2017, 09:27:37 AM »
Just ordered Honda parts from a local dealership. Fingers crossed they show up tomorrow.
« Reply #10 on: May 25, 2017, 10:08:09 AM »
I would let you borrow my F3 petcock, but it has always been kinda shady. Sometime seeps a bit when first put into use and after sitting around, and now has not seen gas in 6 months or so.   I will be out of town all weekend but hit me up if you get in a pinch.  I may have other similar petcocks that could be cannibalized.
« Reply #11 on: May 25, 2017, 10:15:50 AM »
Sean,I have parts on order but no promises there. Do you have the 4 hole seal that goes behind the handle in good shape? Mine is hard as plastic. Even if used it may work for my shakedown run tomorrow.
« Reply #12 on: May 25, 2017, 10:28:14 AM »
I would have to dig up what I actually have and tear them apart to tell you anything for sure.  I am pretty sure several other model/configuration petcocks use the same 4 hole gasket but I really can't remember what I have.  I will be at my shop changing a bunch of oil if you want to come dig for stuff.
