Author Topic: Oil Cooler Thread  (Read 158674 times)
Offline xsmooth69x
Re: Oil Cooler Thread
« Reply #900 on: September 21, 2011, 05:57:22 PM »
my 750 i bought has this oil cooler plate on it. i know this for sure is after market but i think its pulled from another honda motorcycle.
ive seen a whole line of honda motorcycles that have an oil cooler radiator on the frame behind the wheel with this oil cooler plate on the engine.
this is what mine looks like
i build custom PC and we pretty much do the same thing having a heat sink over the cpu die and circulating water over it that flows over the hot cpu diffusing the heat into the water then the water goes into a radiator with computer fans on it where the heat of the water is diffused over the radiator cooling the water in the radiator then circulating it obviously back into a radiator then back to the cpu or gpu or ram
the only thing i have a problem with is that if you trying to cool your oil at stop and go traffic you need to add a fan. the only way to optimally cool your oil is when you bike is moving when the cool air is going over the fins of the radiator. so pretty much only when your going fast.
and from what i get from water cooling computers is that its not only the air going over the radiator CFM (obviously the more is better) but how much total pressure is being exerted
so when you at a stop u need the air to move over the radiator but but but you cant put a fan straight on the radiator. you need a spacer/shroud maybe an inch between the fan and the radiator for the air to be able to diffuse
i think running a mutli fan rad is better leaving space for air to slip in around the fan when your going at speed instead of a cone style rad shroud with one big fan and using 1 big fan wont give you the total pressure of air through the rad even though the fan might be rated and moving a high amount of CFM
you cant decided or compare 2 fans just from the cfm. usually cfm is measure when mmh2o is at 0. that means the fan is tested in a open environment. now move that fan 6 feet from a wall or put something infront of it and the cfm fall dramatically. but knowing the total pressure from the fan with cfm
1975 CB550 (FINISHED?!?!?)
Offline heffay
« Reply #901 on: September 21, 2011, 06:18:20 PM »
That is ToTaLLy what it looks like HAHAHAHAHA  ;D ;D ;D
Offline xsmooth69x
« Reply #902 on: September 22, 2011, 01:57:40 AM »
psshhhh ya my CAD designs are pro!
Offline faux fiddy
  • bike in a box
« Reply #903 on: September 22, 2011, 03:09:59 AM »
If that's right Lloyd, then why did Honda offer a factory oil cooler kit for the SOHC CB750's as an optional extra, along with steering dampers, dual disc conversions, etc, and why did all of the (aircooled) DOHC 750's, 900's and 1100's built after the first SOHC4's all come with oil coolers as standard?
And to placate those who get it in their tiny brains that things found on special purpose race machines also belong on ordinary street machines.
 As I said, if you run at peak power and in hot weather all the time taxing the air cooling system, oil coolers can help the oil live longer.  Do you think an oil cooler would be of primary benefit in an arctic setting?
Regarding the DOHC4 diversional rathole BS.  The extra geegaws were a sales device.  It's called marketing toward competitor offerings or what the consumer demands, rather than what they actually need.  Joe Cool see a Yamaha with an oil cooler on it.  Gee, Yamaha's must be SO powerful that they need an oil cooler just like the race bikes have.  What? Honda does have one?  Well, it must be inferior or underpowered, then.
I heard a story about the yamaha reps comming to town. A couple rich kids had got the new XS's when they came out, and it gave them a reason to skip school, and in the interim, they pulled wheelies , launching at each stop sign in town they came across.
After a month or so they had both snapped /twisted/broken their drive shafts. Both the bikes had come from the same dealer so the reps came to trace it back to the factory and deliveries. It had nothing to do with that, it had to do with dumb kids taking the engineering of the bike to the limits every day, 12 hours a day for months at a time. Something had to give.
« Last Edit: September 22, 2011, 03:26:45 AM by tree fiddy of industry »
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline CBNJ74
  • Sweep the leg!
« Reply #904 on: September 22, 2011, 07:16:00 PM »
Well here she is. If I were to ever sell it. What could I get for it?
« Last Edit: September 23, 2011, 05:21:01 AM by CBNJ74 »
1973 Honda CB750K
1983 Honda VF750 Interceptor
2005 Triumph Thruxton
2012 Ducati Monster 1100evo
Offline xsmooth69x
« Reply #905 on: September 23, 2011, 04:47:39 AM »
Well here she is. If I were to ever sell it. What could I get for?
$50 ?
« Reply #906 on: September 23, 2011, 04:14:07 PM »
That's an old "Derale" kit mate, they worked very well, but I never liked the aesthetics of the radiator, and that one looks a little "tweaked". The adapter looks good though, and I think that one's got an inbuilt thermostat, which is a plus. You'd get 50 bucks for it on EBay, or maybe a little more. Cheers, Terry. ;D
Offline freebiecb
  • cb650c mutt owner
« Reply #907 on: October 28, 2012, 07:57:32 PM »
Should a cb650c owner choose to install a cooler, where are tha longer bolts found?
Offline ofreen
« Reply #908 on: October 28, 2012, 10:35:46 PM »
It's baaaack -
Greg
'75 CB750F
Offline onepieceatatime
« Reply #909 on: October 29, 2012, 05:00:05 AM »
I took a chance and bought this on ebay: 1986 YAMAHA FZ600 OIL COOLER ADAPTOR BOLT
It is a discontinued part.
This is OEM information for the part:
BOLT,UNION
90401-20089-00
Here are other bikes it was used on.
http://www.boats.net/parts/detail/yamaha/Y-90401-20089-00.html
If you cannot find one on ebay, I found this forum with reproduction ones advertised:
http://xjbikes.com/Forums/viewtopic/t=14561/postdays=0/postorder=asc/start=15.html
Their part number is : HCP3165. it is about 2/3 of the way down the page for around $20.
I did a test fir on my spare engine case, without the filter element, and it seems to work fine. I have yet to test it with the filter element, but if it will not go together, I can grind a little length off the head to make it shorter.
This was for my CB650
« Last Edit: October 29, 2012, 05:07:04 AM by onepieceatatime »
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline madScientist
« Reply #910 on: October 29, 2012, 06:32:57 AM »
Geezuz this thread is over 7 years old...incredible!
You CAN do great things...with enough beer.
78 cb750f
http://forums.sohc4.net/index.php?topic=113293.0
70 CL350 Street Tracker / Cafe
http://forums.sohc4.net/index.php?topic=125641.0
83 KZ1100ltd
76 GL1000
71 Kaw H2 (to be built)
77 cb750A (sold)
74 cb125s (sold)
Offline heffay
« Reply #911 on: October 29, 2012, 12:41:33 PM »
« Reply #912 on: October 29, 2012, 04:16:56 PM »
Offline Killer Canary
  • Typical Bran Muffin
« Reply #913 on: October 29, 2012, 05:36:44 PM »
Why would you post a picture of an inter-stellar tachyon generator on an oil cooler thread?
Kawi GPz900, H1
« Reply #914 on: October 30, 2012, 03:08:54 PM »
Because it improves MPG?
« Reply #915 on: October 30, 2012, 03:27:09 PM »
Because it reverses time and therefore the damage caused by overheated oil.
...in another galaxy.
« Reply #916 on: October 31, 2012, 10:10:45 PM »
My CB 750F came stock with a OIL Cooler? did someone say Honda street bikes did not need them? ............................................CB750E-2600014 and CB750GE-1000014         F2
          new cylinder head with bigger valves (34/31mm i/o 32/28mm), larger combustion chamber, larger carb mount rubbers, stronger cam chain, new camshaft, harder valve springs, new retainers, cotters, new pistons compression ratio 9/1. New rod big end bolts and bearings, harder clutch springs, additional fins on crankcase, larger fins on oil pan, "oil cooler" - finned plate between oil filter case and engine. Final drive 15/43 or 14/43.
CB750E-3100001 F3 http://www.hondachopper.com/engine/engine_mods/modifications.html   B&M Oil cooler brought down my Temp from 230* to 195* and helped with some detonation issues under Boost i was having, I made this setup myself and does not leak or sweat a drop in 7 years ! COOL IT BABY!!!
Have you got any more pics of that Goldwing mate? I've just bought one, and am looking forward to some "Land Yachting". ;D
Offline 74750k4
« Reply #917 on: December 02, 2013, 07:43:02 PM »
Just picked up a Lockhart adapter with the bolt included off ebay for $27. Is that a decent price?
Offline ofreen
« Reply #918 on: December 02, 2013, 08:41:17 PM »
Greg
'75 CB750F
« Reply #919 on: December 03, 2013, 01:08:09 AM »
Yes it is. ;D
Offline heffay
« Reply #920 on: December 03, 2013, 09:03:18 AM »
First post on April 04, 2005, 09:02:29 AM
Offline CBNJ74
  • Sweep the leg!
« Reply #921 on: December 03, 2013, 09:04:45 AM »
Does it really get that hot in Australia?
1973 Honda CB750K
« Reply #922 on: December 03, 2013, 10:26:03 AM »
That's really irrelevant.  The point is that oil coolers look pretty and make the owner feel they did something good for their bike, kinda like big fat tires, knee dents, pods, clubmans, removing fenders, and flat black paint.   ;D  ;D  ;D
Don't cha know you just need an oil cooler on it to make the bike look like it is race bred and have other people think you modded the engine to make more HP.
I crack myself up sometimes.  ;D ;D ;D
Offline CBNJ74
  • Sweep the leg!
« Reply #923 on: December 03, 2013, 10:27:38 AM »
Yeah until the lines snap and spray oil all over the place LOL
1973 Honda CB750K
« Reply #924 on: December 03, 2013, 02:52:55 PM »
And thats why most manufacturers fit them standard from the factory..... ::)
And NO, the heat here isn't irrelevant its bloody hot.... ;D
« Last Edit: December 03, 2013, 11:18:46 PM by Retro Rocket »
