I own a 1973 Yamaha TX750 Twin (as well as a CB750 K7) which has been converted at some point in its life to a single carb, still has standard #45 Pilot jet, #130 Main, Z6 nozzle, 4N8 needle with clip on lowest (nearest needle end) point.........
Carbs are not my strong point.........so my question, as this is a single carb it obviously now needs to draw in enough fuel/air mixture, are there any Guru's out there could tell me if these sizes are correct/good starting point? Assume a #140 jet is larger? would that be the way to go? Trial & error?
any help much appreciated
Roy
